ECLIPSE SC 8365 - 3 WAY COMPONENT SPEAKER SYSTEM
Results 1 to 5 of 5
  • Short URL:  http://modifika.si/127593
    IG @ascentti
    1 Wk 2 Days 16 Hrs 27 Mins 42 Secs
    Thumbs up ECLIPSE SC 8365 - 3 WAY COMPONENT SPEAKER SYSTEM
    READY STOCK !!!
    MSRP RP 3.500.000
    *. Specification :
    RMS power handling: 100W
    Max. power handling: 300W
    Sensitivity (1Watt/meter) SPL: 88dB
    Crossover frequencies:
    woofer/midrange 1400Hz,
    midrange/tweeter 5kHz
    Mounting Depth: 2-7/8
    Woofer driver
    solid aluminum cone
    (SC8365: 6-1/2 )
    (SC8355: 5-1/4 )
    Aluminum diecast baskets
    Santoprene surround
    Porous flat spider
    Aluminum voice coil former
    Very narrow voice coil gaps
    Vented pole piece
    Midrange driver
    1-1/2 solid aluminum hard dome
    Neodymium magnet
    Ferro-fluid cooled
    Flush-mounting kit
    Tweeter
    3/4 solid aluminum hard dome
    Neodymium magnet
    Ferro-fluid cooling
    Flush-mounting kit
    Crossover
    Audiophile-grade, speaker-specific matched component passive crossover with clear lexan cover
    12dB/octave high-pass, 6dB/octave low-pass Butterworth Optimum Q crossover filters
    OFC wirewound air core inductors and metallized polypropylene capacitors
    Tweeter protection circuit
    Variable tweeter sensitivity (-3dB/0dB/+3dB)
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    YouTube Channel = ascentti
    1 Wk 1 Day 20 Hrs 6 Mins 10 Secs
    bro ascentti,
    gw lg nyari 3 way speaker budget bersahabat buat daily use..
    bole tau kalo ngandelin HU cukup ga buat ngangkat speaker ini dan kalo buat honda jazz apa instalasi plug and play ato mst ada ubahan?
    HU mungkin pake kenwood 8016
    IG @ascentti
    Quote Originally Posted by B2029 View Post
    bro ascentti,
    Hello, pakai Crescendo 3 Way aja bos, diangkat pakai HU Kenwood bisa koq.. harga juga bersahabat
    BTW ada nomor HP atau BBM ? Nanti saya hubungi untuk ngobrol2 lebih lanjut
    Trims
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
    Quote Originally Posted by ascentti View Post
    Trims
    bos alvin,
    udh di-PM yaks nomor HP
    IG @ascentti
    bos alvin,
    Siap boss, PM Replied
    INSTAGRAM @ascentti
    LINE @ascentti
    BBM PIN = ascentti
MBtech Venom 300x250
