STEG Q-MOS 75.6mx muluuuuuus.............(sold,thanks modcom....)
Results 1 to 10 of 11
  • Short URL:  http://modifika.si/127518
    Cool STEG Q-MOS 75.6mx muluuuuuus.............(sold,thanks modcom....)
    STEG Q-MOS 75.6mx muluuuuuus.............sold
    All Steg QM range amplifiers are designed to give uncompromising sound quality. The QM range features regulated power supplies, meaning they will produce the same power whether your car is on or off. They are built to exacting standards with great quality internals. If you want unparalleled performance without sacrificing on sound quality, the QM range from Steg should be first on your list.
    Type : Class A/B
    Channels : 6
    RMS Power @ 4 Ohm : 6 x 75RMS
    RMS Power @ 2 Ohm : 6 x 125RMS
    RMS Power @ 4 Ohm Bridged : 3 x 250RMS
    High Pass Filter : 22Hz - 8500Hz
    Low Pass Filter : 22Hz - 8500Hz
    Filter Slope : 12dB/oct
    Bandpass Capable : Yes
    Phase Control : 0-180
    RCA Input : 150mV - 3.5V
    Total Harmonic Distortion : Less than 0.05%
    Signal to Noise Ratio : Greater than 95dB
    Average Efficiency : Greater than 60%
    Dimensions (W x H x L) : 207mm x 52mm x 394mm
    Fuse Rating : 60 Amp External
    Power Connection : 4 Guage
    Speaker Connection : Fork Terminal
    Price:
    $775.00
    call
    081388575788
  2. Ysbjaya88
    up............
    up............
    up..................
    up...............
    2 Days 10 Hrs 30 Mins 19 Secs
    cocok untuk SQ dan harga ga terlalu mahal.......
    thanks bos ntoeng......
    up...........
    up...............
    up/............
  1. Replies: 54
    Last Post: 6th September 2009, 03:31
  2. SUBWOOFER MMATS PRO 12 inch muluuuuuus........(sold,thanks modcom...)
    Last Post: 5th July 2009, 19:40
  3. nakamichi ec-302 muluuuuuus.............(sold,thanks modcom....)
    By MR.GASOLINE in forum Bursa Audio Lainnya
    Last Post: 30th June 2009, 13:49
  4. Replies: 18
    Last Post: 19th June 2009, 19:43
  5. pioneer cd-ib100II muluuuuuus dan lengkap...(sold,thanks modcom...)
    Last Post: 10th June 2009, 03:30
