CLARION HXD-1 mulus n segel,lengkap dc/dc converter................sold
* Clarion high fidelity CD player without built-in amplifier
* CeNET control of: 6-disc CD changer
* Dual 24-bit D/A converter
* HDCD disc playback
* High-capacity DC/DC converter ( 15 V)
* 4-volt / 4-channel RCA output (Max 9 V)
* High purity OFC cable
* 2-channel AUX input
* High visibility blue-white VF display
* Copper plated chassis
* Optical input terminal for connection with DCZ625
* Aluminium analogue rotary volume control
* 18 FM, 6AM station presets
* FM diversity
TUNER SECTION
Frequency bands
FM: (MHz) 0.05MHz steps 87 to 108
MW: (kHz) 9 kHz steps 531 to 1629
LW: (kHz) 3 kHz steps
FM usable sensitivity (dBf) 9
FM 50 dB quieting sensitivity (dBf) 15
FM alternate channel selectivity (dBf) 60
FM stereo separation @1 kHz (dB) 35
FM stereo freq. resp. @ 3 dB (Hz) 30 to 15,000
CD SECTION
Wow/Flutter (WRMS) Below measurable lmits
S/N ratio (dB) 110
Frequency response (Hz) 5 to 20,000
Dynamic range (dB) 100
Harmonic distortion (%) 0.005
GENERAL
Dimensions (W H D), mm 178 50 182
Weight (kg) 1.6
Power consumption: less than 1.1 A
Speaker impedance 4Ω(4Ω to 8Ω allowable)
Next-generation technology that spins the captivating crystallisation of sound
call
0813885757888
