scanspeak revelator 15w/4531-G00 (sold,thanks modcom....)
Results 1 to 10 of 13
  • Short URL:  http://modifika.si/127176
    Cool scanspeak revelator 15w/4531-G00 (sold,thanks modcom....)
    scanspeak revelator 15w/4531-G00 kondisi mulus............sold
    The Scan-speak 15W/4531G-00 is a 5-1/4" Revelator mid/woofer. It features a slit-paper uncoated non-resonant cone and dust cap structure, dynamic linear suspension, SD-1 magnet system, "Grasshopper" cast chassis with maximized air flow, glass fiber voice coil former and resonance terminating mounting system. The 15W/4531G provides a more extended frequency response than it's brothers, but still fantastic bass down to the mid 50's in a vented enclosure. This version is only available in 4 ohm.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 87 dB
    Free air resonance Fs 39.5 Hz
    DC resistance 3.4 ohm
    V.C. inductance 0.25 mH
    Power 12dB@Hz 60W
    Effective cone area 95 cm2
    V.C. diameter 38 mm
    Lin. & max. excursion 6.5 & 9mm
    Air gap flux density -
    Force factor BL Product 5.7 Tm
    Moving mass incl. air 13 g
    Net weight 1.6 kg
    Vas 16 ltrs
    Qms 4.6
    Qes 0.34
    Qts 0.32
    Outside diameter: 148mm
    Cut out: 125mm
    Depth: 71mm
    25.4mm = 1" = 2.54cm
    call
    081388575788
    3 Hrs 59 Mins 5 Secs
    :smt023:smt023bos yg stu ni brangnya ajib2:smt023:smt023
    thanks ya bos wndy......
    up.............
    up.............
    up...........
    up..............
    up................
    up..................
    up..............
  1. Replies: 3
    Last Post: 31st December 2009, 05:34
  2. Replies: 1
    Last Post: 11th November 2009, 03:13
  3. hi-end scanspeak 23w revelator subwoofer.....(sold,thanks modcom....)
    Last Post: 17th September 2009, 06:05
  4. Replies: 32
    Last Post: 31st July 2009, 00:44
