nakamichi mb-100 kondisi muluuus n normal......(sold,thanks modcom....)
  • Short URL:  http://modifika.si/126955
    Cool nakamichi mb-100 kondisi muluuus n normal......(sold,thanks modcom....)
    nakamichi mb-100 kondisi muluuus n normal...............sold
    MB-100
    MOBILE TUNER / 6 DISC MUSICBANK™ CD CHANGER
    MB-100 SPECIFICATIONS
    DAC/Preamplifier Unit
    Preamplifier Section
    Frequency Response: 15-30,000 Hz ± 2 dB
    Total Harmonic Distortion: 0.008% (1 kHz)
    Output Level: 1.0V/2.0V/5.0V (selectable)
    Tone Controls:
    Bass:± 12 dB @ 20 Hz
    Midrange:± 12 dB @ 3 kHz
    Treble:± 12 dB @ 20 kHz
    Loudness: + 10 dB @ 20 Hz (volume level: 20)
    D/A Converter Section
    Frequency Response: 20-20,000 Hz
    Sampling Frequency: 32 kHz / 44.1 kHz / 48 kHz (autoselected)
    D/A Conversion System: 24-bit D/A converter with 8 x oversampling digital filter
    S/N Ratio: Better than 95 dB
    Dynamic Range: Better than 95 dB
    Tuner/CD Changer Transport Unit
    FM Tuner Section
    87.5-107.9 MHz in 200 kHz steps
    87.5-108.0 MHz in 50 kHz steps
    Usable Sensitivity: 15 dBf (IHF)
    S//N Ratio: 60 dB (mono)
    Stereo Separation: 35 dB
    AM Tuner Section
    Frequency Range:
    530-1,710 kHZ in 10 kHz steps
    531-1,602 kHz in 9 kHz steps
    Usable Sensitivity: 32 dBµ
    CD Transport Section
    Changer Type: 6-Disc MusicBank™ system
    Outer Dimensions (WxHxD) / Approx. Weight
    Tuner / CD Changer Transport Unit:178 x 46 x 176.7 mm / 1.3 kg
    DAC / Preamplifier Unit:178 x 25 x 120 mm / 0.5 kg
    OTHER ADVANCED PREAMPLIFIER FEATURES
    • Bass/midrange/treble tone controls provide precise adjustment capability over a +12dB range at 20Hz, 3kHz, and 20kHz.
    • Two coaxial digital inputs and two analog AUX inputs are provided to accommodate an external Nakamichi CD changer and other source components. (You can select AUX 2 or digital input 2, but not both.)
    • All input and output terminals are gold-plated.
    • Loudness and audio mute functions are provided.
    OTHER ADVANCED HEAD UNIT FEATURES
    • 3-inch (8cm) CDs can be played without adapters. (They can be played in any open slot but cannot be stored in the changer.)
    • High-Performance PLL synthesizer tuner has 18 FM and 12 AM station prestets, Auto Memory, Auto DX/Local Switching, Preset Scan.
    • Wireless remote control included.
    • Front panel can be detached to deter theft.
    • Available with either green or amber panel illumination.
    • Quartz digital clock built in.
    • MA75 installation kit available for mounting in European automobiles (Not available in U.S.A.).
    call
    081388575788
    up...............
    up..............
Venom 300x250 MBtech
  1. Replies: 2
    Last Post: 4th March 2010, 06:14
  2. NAKAMICHI EC-204 kondisi muluuus............(sold,thanks modcom....)
    By MR.GASOLINE in forum Bursa Audio Lainnya
    Last Post: 24th February 2010, 07:16
  3. Replies: 34
    Last Post: 17th January 2010, 21:41
  4. Replies: 23
    Last Post: 26th November 2009, 02:14
