collector's item LINEAR POWER 8002SW (sold,thanks modcom...)
Page 1 of 14 12345 ... LastLast
Results 1 to 10 of 137
  • Short URL:  http://modifika.si/126601
    Cool collector's item LINEAR POWER 8002SW (sold,thanks modcom...)
    VERY RARE LINEAR POWER 8002SW kondisi muluuuuus,lengkap dengan cover dan fan original......sold
    24 pieces TO3
    new price : US$ 3.200
    1 x 800W @ 8 or 4 ohms (12.5V - 0.08% THD)
    Maximum / peak power : 2400 watts
    Damping Factor: 220 / 110 (8 ohms / 4 ohms)
    2 Ohm St 4 Ohm Mono Capable
    S/N Ratio: 85 dB
    Fuse: External 60A
    Dimensions: 14.5" x 9.5" x 3" (36.8cm x 24.1cm x 7.6cm)
    * The fuse must be a slow blow style fuse, the peak rating on each of these amps are much higher than the fuse rating.
    ** Mono Rating @ 4 Ohms is tested with the power supply taps moved to 2 Ohms setting where applicable.
    call
    081388575788
    DKI/BSD
    1 Wk 3 Days 2 Hrs 12 Mins 24 Secs
    wahhhh ada LP 8002...rare banget ni....
    mulus dan msh ada fan...
    warnanya juga item sama kaya gw punya yg lbh mini...
    mmmmmm
    ____________
    0812-951-3972
    thanks om gege.......
    di PoNDoK BaMBoe
    2 Hrs 29 Mins 47 Secs
    Smile
    :opOWer iDAMaN:o semenTaRa iNi bantu up doeloe s0b ....
    btw minta aLamat lo na s0b ...
    thanks bos masyanku.....
    alamatnya di mega glodok kemayoran lt 6 blok f1-6 bos..
    thanks.....
    up................
    di PoNDoK BaMBoe
    thanks.....
    ok thx bos ... mungkin minggu2 depan gw ksna d,
    btw bs bikin passive crossover bos?
    sekalian gw mau instal ulang audio gw ..
    saLam,
    masYanKu ...:cool:
    ok bos masyanku....
    buat passive n install g ga terima bos,cuma ada barang2 aja nich bos masyanku.....
    tapi temen2 installer banyak,nanti tinggal sesuaikan sama karakter bos n saya kenalin ke bos masyanku...
    thanks.......
    ok bos masyanku....
    thanks.......
    up................
Venom 300x250 MBtech
  1. Replies: 56
    Last Post: 3rd January 2011, 14:54
  2. Replies: 5
    Last Post: 16th July 2010, 11:47
  3. Replies: 119
    Last Post: 27th February 2010, 08:16
  4. Replies: 8
    Last Post: 16th June 2009, 03:37
  5. Replies: 61
    Last Post: 13th April 2009, 17:00
