monoblock class ab DLS ULTIMATE A6 MONO AMP..(sold,thanks modcom...)
Results 1 to 6 of 6
  • Short URL:  http://modifika.si/126130
    Cool monoblock class ab DLS ULTIMATE A6 MONO AMP..(sold,thanks modcom...)
    monoblock class ab DLS ULTIMATE A6 MONO AMP muluuuuus n lengkap bass remote (belum pernah dipakai),dus,buku manual......sold
    DLS: Ultimate A6 - Mono Amplifier
    Product Features
    * RMS output per channel at 13,8 volts, < 0,1% distortion.
    * Mode : AB
    * Number of channels : 1 (for subwoofer use)
    * Output power in 4 ohm : 500 W
    * Output power in 2 ohm : 870 W
    * Output power in 1 ohm : 1200 W
    * S / N ratio, A-weighted : > 100 dB
    * Damping factor : > 200
    * Input impedance : > 10 kohm
    * Input sensitivity, variable : 0,2 - 7 V
    * Filters : Lowpass: 50-125 Hz. Subsonic: 25 Hz
    * Terminal for external cooling fan : Yes
    * Dual DC-inputs : Yes
    * Phase control 0-180 degrees : Yes
    * Remote sub level control with phase shift : Yes
    * Current draw, idle : 0,6 A
    * Current draw, maximum : 140 A
    * Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
    Product Description
    ULTIMATE series A6. A 1 ohm stable monoblock thatīs perfect. Extremely powerful power supply. The output power in 4 ohms are 500 thrue RMS watts. A cooling fan is built in but the amplifier also provides a built-in fan control for external cooling fan.
    Built-in, variable 50-125 Hz low-pass filter for subwoofers plus a 25 Hz subsonic filter with an 18 dB/octave slope. Dual power terminals where you can connect dual power feeds or a DLS Power Cap. Extra features are a phase control variable 0-180 degrees continiously.
    A remote sub level control is included. Adjust the sub level and phase from the front seat!
    call
    081388575788
  2. Bandargua88
    klaten
    bantu up buat monoblock nya boss .....
    thanks bos danny............
    up.................
    up................
    up..............
  1. SALE: Genesis Dual Mono Class A (DMA) SOLD
    By ace911 in forum Power Amplifier
    Last Post: 1st September 2009, 14:00
  2. Replies: 73
    Last Post: 25th August 2009, 14:39
  3. Replies: 37
    Last Post: 24th July 2009, 02:16
  4. Replies: 55
    Last Post: 12th July 2009, 00:23
  5. Replies: 0
    Last Post: 9th July 2009, 05:31
