.::de Auto Motorsport::. RUNSTOP Performance Disc Rotor & Rear Conversion Kit
Page 1 of 63 12345 ... LastLast
Results 1 to 10 of 624
  • Short URL:  http://modifika.si/125316
    RUNSTOP BRAKE SYSTEM MADE IN THAILAND
    For more than twenty years we have relied on very special test benches to develop our products. Confidence and trust is something you only earn over a period of years. It's a necessity to deliver to promises; it's a requirement to exceed expectations. Around this simple concept we at B.J. have built our reputation. A fine example of Thai industrial renaissance during the eighties, we have always thought it’s essential to combine culture with innovation.
    The most elegant street brake rotor on the market that combines outstanding performance with aggresive and purposeful appearance.
    Each rotor is analyzed for its specific application, vane structure, and construction to determine the ideal and optimum design and pattern.
    The drill and slot patterns designed using a 3D CAD application to ensure all the design specification and running in CNC machines for the productions.
    RunStop Rotors are engineered to enhanced braking performance by keeping the temperature of your brake stays cool, which improve the pad's bite and also reduces brake distance.
    Brake Diagram:
    FRONT BIG BRAKE KIT 4 POT CALIPER
    Improve braking performance as much as twice as OEM Brake System..!
    Content in 1 Set Front Big Brake Kit :
    - Iron Caliper 4 Pot Monoblock Mini (Available in Red Color Only)
    - Performance Brake Pads (Street)
    - Bracket Caliper
    - Disc Rotor (Slot & Drill)
    OVERSIZE FRONT ROTOR KIT
    This expansion front rotor is compatible plug & play with stocks calipers and brake pads. Minor change with better braking performance.
    1 Set Oversize Front Kit = 1 pasang oversize rotor (kiri & kanan) dan Replacement Bracket Caliper.
    Contoh 320mm Rotor for Honda New Civic 2001-2005:
    Contoh Rotor 320mm pada Honda New Civic 2001-2005:
    OEM SIZE FRONT AND REAR DISC ROTOR
    This performance front/rear rotor is OEM Size, so it's compatible with stocks calipers and brake pads. Better braking performance without any modification with the standard braking system or standard wheel and it's plug & play!
    1 Set Performance Front or Rear Kit = 1 Pasang Rotor (kiri & kanan)
    Model Available:
    Curve Slotted with Drilled Rotor Model
    REAR CONVERSION BRAKE KIT WITH 2 POT CALIPER
    This rear conversion kit is replacing the conventional rear drum brake system and it's fully plug & play kit.
    By changing rear drum brake system, braking performance will be improved.
    1 Set Rear Conversion Kit:
    Disc Rotor 285mm (min. 15inch wheel required)
    2 Pot Caliper (blue caliper color)
    Bracket
    Brake Pads
    Hand Brake Wire
    Caliper 2 Pot Top View:
    Installed On Toyota New Vios:
    TOYOTA FORTUNER (2004-2011) BRAKE UPGRADE KIT
    FRONT EXPANSION ROTOR KIT
    REAR CONVERSION KIT 2 CALIPER
    Bolt on upgrade kit sistem rem belakang Toyota Fortuner dari model Drum ke model disc lengkap dengan 1 Piston atau 2 Piston Caliper Type, Brake Pad, Disc Rotor, Bracket dan Brake Line.
    RUNSTOP HIGH PERFORMANCE BRAKE SYSTEM
    when stopping is the only thing that matters..!
    Kontak :
    Coki Siboro - de Auto Motorsport
    0815 1330 1978
    Khusus untuk aplikasi RUNSTOP Front Big Brake Kit & Rear Conversion Kit mobil-mobil berikut:
    TOYOTA FORTUNER
    TOYOTA INNOVA
    MITSUBISHI PAJERO SPORTS EXCEED & DAKAR
    Kontak : 0816 1919 911 atau 021 937 03 789
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    LIST OF STOCKS :
    Model : FRONT BIG BRAKE KIT
    Caliper : Iron Monoblock 4 Pot
    Caliper Color : Red (Available in Red Color Only)
    Disc Rotor Pattern : Slotted & Drilled
    Installation : Direct Bolt-on the Listed Car Application
    List of Stocks:
    - Honda New Jazz GE8 08-up Oversize 285mm (min. 15inch wheel)
    - Honda New Jazz GE8 08-up Oversize 305mm (min. 16inch wheel)
    - Honda All New City 09-up Oversize 285mm (min. 15inch wheel)
    - Honda All New City 09-up Oversize 305mm (min. 16inch wheel)
    - Honda Freed Oversize 285mm (min. 15inch wheel)
    - Honda Freed Oversize 305mm (min. 16inch wheel)
    - Honda Civic ES 01-05 Oversize 285mm (min. 15inch wheel)
    - Honda Civic ES 01-05 Oversize 305mm (min. 16inch wheel)
    - Honda Civic Ferio 96-00 Oversize 285mm (min. 15inch wheel)
    - Honda Civic Ferio 96-00 Oversize 305mm (min. 16inch wheel)
    - Honda Civic FD1 1.8L Oversize 320mm (min. 17inch wheel)
    - Honda Civic FD2 2.0L Oversize 320mm (min. 17inch wheel)
    Model : OVERSIZE DISC ROTOR
    Disc Rotor Pattern : Slotted & Drilled Complete with Bracket
    List of Stocks:
    - Honda Jazz GD3 idsi/vtec 04-07 Oversize 285mm (min. 15inch wheel) DEPAN
    - Honda New City idsi/vtec 04-07 Oversize 285mm (min. 15inch wheel) DEPAN
    - Honda Civic ES 01-05 Oversize 314mm (min. 16inch wheel required) DEPAN
    - Honda Civic Ferio 96-00 Oversize 314mm (min. 16inch wheel required) DEPAN
    - Honda All New Jazz GE8 08-up Oversize 314mm (min. 16inch wheel required) DEPAN
    - Honda All New Jazz GE8 08-up Oversize 300mm (min. 16inch wheel required) BELAKANG
    - Honda All New City 09-up Oversize 314mm (min. 16inch wheel required) DEPAN
    - Honda All New City 09-up Oversize 300mm (min. 16inch wheel required) BELAKANG
    - Honda Freed Front Oversize 314mm (min. 16inch wheel required) DEPAN
    - Honda New Civic FD1 2.0L 06-up Oversize 300mm (min. 16inch wheel required) BELAKANG
    - Honda New Civic FD2 2.0L 06-up Oversize 300mm (min. 16inch wheel required) BELAKANG
    - Toyota Fortuner 04-11 Oversize 330mm (min. 17inch wheel required) DEPAN
    Model : Rear Conversion Kit for Honda Jazz GD3 (IDSI)
    Rotor Size : Oversize
    Bracket
    Brake Pads
    Hand Brake Wire
    Tersedia juga Performance Brake Pads, Brake Line untuk Rotor2 diatas : CALL..!
    Kontak :
    0815 1330 1978
    NOTIFICATION...!
    TOYOTA FORTUNER
    TOYOTA INNOVA
    CP : Coki Siboro
    7 Hrs 59 Mins 21 Secs
    Selamat malam juragan. Saya mau tanya kalo buat lancer evo 4 ada gak?
    Atau mungkin musti ngerombak lg ya?mohon infonya.
    Saya minat ma front rotor diameter 320mm and pcd 4x100.Center hole kalo gak salah sih sekitar 60mm.
    Kalo ada harga nettnya dong boss.Slotted atau crossdrilled masing2 berapa?
    tebal rotor berapa mm ya boss?
    And bantu up juga boss.
    up...up...up.....
    1 Wk 4 Days 4 Hrs 52 Mins 32 Secs
    kl yang buat civic 01 tipe nya yg mana bos? cross drilled, slotted?
    minta hrg bagusnya ya bos...
    Quote Originally Posted by Hendra14 View Post
    buat civic 01-05 ada stock yg OEM Size rotor depan & belakang.. dua2nya hanya yg slotted & drilled.
    harga nya 1.750.000 / set depan (kiri & kanan)
    CP : Coki Siboro
    Quote Originally Posted by vanesha View Post
    buat evo 4 gak punya stock bos.. stock yg 320mm juga cuma untuk honda jazz gd 3 dan new city aja.
    CP : Coki Siboro
    dinaikin lagi...
    CP : Coki Siboro
    Improve your brake performance with RUNSTOP performance rotor..!
    CP : Coki Siboro
    高浜町,志賀町,羽咋郡,石川県
    1 Wk 1 Day 12 Hrs 32 Mins 22 Secs
    Boss....diskriminasi amat....kok cuma ada buat toyota ama honda doang....buat mitsubishi gak ada kah??
    Byk yg punya mitsubishi mau pake jg kan....termasuk gw....
GT Radial Venom 300x250
  1. [- RUNSTOP -] Performance Brake Disc Rotor & Rear Conversion Kit ::.
    By coki.de auto in forum de Auto Motorsport
    Last Post: 7th March 2016, 19:28
  2. .::RC MOTORSPORT::. BREMBO - Performance Disc Rotor
    By iDSImania in forum Bursa Kaki Lainnya
    Last Post: 14th May 2013, 13:09
  3. RUNSTOP - Suzuki Swift Performance Disc Rotor OEM Size
    By coki.de auto in forum Per & Shockbreaker
    Last Post: 16th April 2013, 12:04
  4. -RUNSTOP- PERFORMANCE OVERSIZE DISC ROTOR
    By zoom-bodyworks in forum Bursa Kaki Lainnya
    Last Post: 25th November 2012, 13:44
  5. .::RC MOTORSPORT::. BOSCH - Performance Disc Rotor
    Last Post: 12th June 2012, 10:36
