hi-end scanspeak R2904/7000 ring radiator (sold,thanks modcom....)
Results 1 to 10 of 31
  • Short URL:  http://modifika.si/124303
    Cool hi-end scanspeak R2904/7000 ring radiator (sold,thanks modcom....)
    hi-end scanspeak R2904/7000 ring radiator kondisi muluuuus sekali,baru pakai 2 minggu,lengkap dus dan no seri berurut................sold
    ScanSpeak R2904/7000-00 Ring Radiator, Silver Face Plate
    The Scan-speak R2904/7000 tweeter is the new flagship tweeter in the Scan-speak line. This tweeter incorporates many innovative design concepts.
    The first notable difference is the use of a phase plug. The dome is attached to the phase plug, so the radiating area is now concentrated around the voice coil. This offers more control and reduces distortion and loss that occur at the center of the dome on dome tweeters. The phase plug also acts as a wave guide, reducing high frequency cancellations. A specially designed venting system uses a needle to cut down on turbulence in the air cavity. Better dynamics are achieved by not using ferrofluid, voice coil cooling is performed by the venting system and conduction through copper rings. The new SD-2 neodymium magnet system improves transient response.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 94.5dB
    Free air resonance Fs 520 Hz
    DC resistance 3.0 ohm
    V.C. inductance 0.01 mH
    Power 12dB@Hz 150W@2.7K
    Effective cone area 5.6 cm2
    V.C. diameter 28 mm
    Lin. & max. excursion 0.2 / 1.6mm
    Force factor BL Product 2.8 Tm
    Moving mass incl. air 0.3 g
    Net weight 0.42 kg
    Outside diameter: 104mm
    Cut out: 70mm
    Depth: 30.9mm
    25.4mm = 1" = 2.54cm
    call
    081388575788
    up.................
    3 Hrs 3 Mins 17 Secs
    numpang ngiler bro chris, sumpah... ini barang bagus bin mulus abis...
    klaten
    huhuyyy.....barang mulus banget....pasti cepet ilang nih...
    bantu up bosss.....
    6 Hrs 38 Mins 5 Secs
    bntu uppp boz,,,,,,,,,,,,,,
    thanks a lot ya bos bayu,bos danny n bos v@5h......
    Ikutan ngiler euy.. Ha2, bantu up aja lah bro chris. Pengen tp ga ada doku..
    wah jangan ngiler donk bos rinal,mending dilamar aja ke pulau dewata bos.....
    he..he..he...
    up.............
    Ngelamarnya mah gampang bro, cuma bayarnya yg susah, hi hi..
GT Radial NGK Busi
  1. Replies: 54
    Last Post: 28th April 2010, 09:33
  2. [Sold] Scanspeak R-7000 Ring Radiator (Mulus, No Service)
    By seraphim in forum Speaker - SubWoofer
    Last Post: 27th February 2010, 22:58
  3. Replies: 22
    Last Post: 4th September 2009, 07:11
  4. Replies: 13
    Last Post: 10th August 2009, 18:13
