Silikon Motorsport
RS Speed
ACM 242x90 Hasta Otostereo
Page 1 of 82 12345 ... LastLast
Results 1 to 15 of 1218
    Represented Member Lieutenant Captain
    Pondok Kelapa - Jakarta Timur (CDMA: 021-9866.1978)
    3 Days 12 Hrs 34 Mins 27 Secs
    ULTRA RACING STRUTBAR Indonesia Dealer
    ULTRA RACING The Chassis Tuning Specialist
    stability..!
    ABOUT ULTRA RACING
    Established in 2002, Ultra Racing is a Malaysian-based specialist manufacturer in Chassis Handling and Tuning components. We research, design, test and manufacture high quality bars for all types of passenger vehicles.
    Through intensive research, follows by street and race track testing, bars are proven to provide much improved dynamic safety, ultimate road holding and sensational driving experience.
    You will find most kind of bars for your chassis tuning needs, ranging from Front Strut Bars, Rear Strut Bars, Side Fender Bars to Torsion Bars. All the products are designed for safety and superior handling.
    This year, Ultra Racing has marked yet another important journey in the growth of the company by winning the prestigious award of Asia Pacific Super Excellent Brand, Books of Record 2007/2008, presented by Asia Entrepreneur Alliance (AEA). This award truly reflects the company reputation and recognition for delivering the best and highest quality products in the Asia Pacific region.
    THE PHILOSOPHY:
    • DESIGN PHILOSOPHY - Enhance and Strengthening the chassis of the vehicle without altering or affecting the original chassis specifications. Improve driving dynamics and drive comfort.
    • SAFETY PHILOSOPHY - Individually designed products to suit to different vehicles. The shape, material thickness and material strength is specially selected and chosen to minimize chassis damage and passengers injuries during incident.
    Every materials used are carefully selected to ensure the best performance and safety. The brackets are made of 4mm to 5mm thick steel plates. While the hollow steel tubes and oval tubes are made of 1,2mm to 1,6mm thick steel.
    These materials are selected to ensure the bars are rigid and strong to maintain constant geometry at all times, yet safe enough to crumble during an impact for safety reason.
    We powder coat all of our bar's surface to protect against the corrosion with an aesthetically pleasing white color.
    STEEL VS ALUMINUM
    Why we use steel instead of aluminum?
    First, steel is stronger than aluminum at the same size and thickness. In order to have the same strength as steel, aluminum alloys have to double the thickness (steel 4mm=aluminum 8mm).
    When that happens, weight saving is not so apparent anymore. Of course there are also exotic materials and alloys that can match the strength of steel, but then the cost are astronomically high and therefore not very effectively to bring into mass production.
    TECHNICAL INFORMATION
    Strut Bars and Chassis Strengthening Technology
    If you're serious about your car's handling performance, you will first be looking at lowering the suspension. In most cases, unless you're a complete petrolhead, this will be more than adequate. However, if you are a keen driver, you will be able to get far better handling out of your car by fitting a couple of other accessories to it. The first thing you should look at is a strut brace. When you corner, the whole car's chassis is twisting slightly. In the front (and perhaps at the back, but not so often) the suspension pillars will be moving relative to each other because there's no direct physical link between them. They are connected via the car body, which can flex depending on its stiffness. A strut brace bolts across the top of the engine to the tops of the two suspension posts and makes that direct physical contact. The result is that the whole front suspension setup becomes a lot more rigid and there will be virtually no movement relative to each side. In effect, you're adding the fourth side to the open box created by the subframe and the two suspension pillars.
    Is there a need to have our vehicle chassis strengthened?
    The answer is YES..!
    The chassis of a car is the part which experiences the most of the abuse from the driver. It is particularly due to the weight transfer of the vehicle body during fast cornering, hard braking or hard acceleration.
    In some instance, the weight transfer during cornering may cause one side of the vehicle experience as much as 3 times more force than the other side of the vehicle, which causing enormous chassis flex/vehicle body deformity and twist, consequently causing tires to lose grip.
    Deformity and twisting of the vehicle chassis during cornering may cause negative handling traits such as understeering and oversteering.
    UNDERSTEER
    As most modern cars go, car manufactures employ the FF (Front engine, Front wheel drive) setup for improving driver and passenger safety. The natural behavior of FF car is to have a slight understeer, due to its heavier front end. Understeer happens when the front wheels lose their traction and won't turn any sharper, even when steering is being corrected to turn the car more. This will cause the car to go wide instead of following the line.
    Understeer can be corrected by stiffening the rear end of the vehicle by adding a REAR SRUTBAR and a REAR ANTI-ROLL/SWAY BAR.
    OVERSTEER
    Oversteer happens when the rear tires lose grip and causing the rear end of the vehicle slides out a corner. This phenomenon happens particularly to FR (Front engine, Rear wheel drive) cars. Oversteer can be corrected by stiffening the front end of the vehicle by adding FRONT STRUTBAR and a FRONT ANTI-ROLL/SWAY BAR.
    There are various types of strut bars
    FRONT STRUT BARS
    Mounted at the front chassis for strengthening purposes. To eliminate all the suspension noise and more stability during acceleration, hard driving and braking ( simulating race track conditions ).
    Every vehicle’s front chassis is different therefore designs and develops the front bars based on the actual conditions of the vehicle, repeatedly testing and proving to its perfection. High attention is taken during the design and development stage to ensure the chassis is able to withstand the load when a bar is being installed.
    Ultra Racing is proud to bring to you the first of its kind in the country, the MULTI-POINT Front Strut Bar. The Front Strut Bar is installed to minimize the weight transfer of the vehicle body, therefore the vehicle will not loose traction easily during cornering.
    REAR STRUT BAR & REAR UPPER BAR
    Mounted at rear section of the car chassis (boot). Similar to the function of the front strut bar. The rear strut bar is use to support the rear section of the chassis, so that the force generated during hard braking and driving can be reduced.
    The Rear Strut Bar is particularly useful for an FF vehicle. The Understeer behavior can be corrected by stiffening the rear chassis by installing a Rear Bar.
    High attention is taken during the design and development stage to ensure the rear chassis is reinforced and strengthened in a proper way that it will not cause the vehicle body to undergo too much stress.
    Rear Upper Bars is designed for vehicles with high roof and high CG (Centre of Gravity) such as MPV's, mini MPV's, SUV's and Hatch Backs.
    Initially, Rear Upper Bar is invented specially for the 5 Doors Hatch Back cars. The 5 Door Hatch Back cars have weaker rear upper body due to their wide opening rear door. Under extensive investigation and actual road proving, it corrected the shortcoming of the vehicle’s swaying rear upper body.
    SIDE FENDER BAR
    Installed at the left and right side of the vehicle wheel arch or fender. Fender bars can give extra support and strength to the chassis especially during cornering.
    As most of the vehicle’s front chassis over hanging is designated to carry the vertical loads from the front suspensions, it is vital that this part of the chassis is strong enough to take the bounce and rebound force of the suspension. Else, the effort of a good suspension will lose its meaning if the chassis absorbs all the forces from the suspension and not letting the suspension does what it suppose to do.
    Therefore, these high quality 3-Point Fender Bars strengthen and reinforce these essential areas of your car and help maintain the suspension in position from all kind of vertical loads.
    As a matter of fact, Fender Bars come as a standard feature on most of the high performance vehicles such as MITSUBISHI EVO and SUBARU WRX. Now, you can have the same feature on your car too!
    Advantages of the fender bar:
    - Improve handling, stability at high speed and cornering, hence safer driving.
    - Provide a better braking and stopping performance.
    - Reduce NVH (Noise, Vibration and Harshness).
    - Increase stiffness of vehicle front chassis.
    ANTI-ROLL BAR / SWAY BAR
    Anti Roll Bars (also known as anti-sway bars, sway bars or lower tie bars) affect the handling of the car on the lower end of the suspension. Sway bars tie the lower suspension components together across the front or back, and affect a car's over steer and under steer. Sway bars will keep your car flat in turns instead of leaning over to one side. They distribute energy from the side of the car with all the force from the turn on it to the other side of the car, bringing the whole car down flat instead of leaning to one side. Of course the car will still lean some, but not as much.
    Sway bars provide better cornering especially at high speeds and work very well in conjunction with strut tower bars. However, they can have an adverse affect in off-road situations by leaving one tire completely off the ground.
    LOWER ARM BAR
    The Ultra Racing Lower Arm Bar is designed to reduce the flex of the vehicle chassis where it is connected by the Lower wishbone of the suspension system, thus to lessen the distortion of the vehicle lower suspension when it is under load, especially during hard cornering. It is installed at the lower mounting points between the left and right suspension and the vehicle chassis. Tremendously improving the stiffness at the area where the lower arm is connected to the vehicle chassis. The Ultra Racing Lower Arm Bar also keeps camber accurate during hard cornering.
    ROOM BAR / SIDE FLOOR BAR
    It is the bar linking both the B-Pillars within the passenger compartment. The effect of room bar is particularly obvious for a four-door sedan. This is because four-door sedan has a longer body than the hatch-back or coupe, the chassis is by nature weaker than the later two.
    COMPRESSION TEST:
    Ultra Racing at 100 psi
    Honda Civic EK 2 Points
    Bracket Thickness: 4mm
    Weight: 1,5 KG
    Compression Impact: 3mm @100psi
    Other Product at 100 psi
    Weight: 1,4 KG
    Compression Impact: 70mm @100psi
    THE THEORY:
    BODY ROLL fixed with ANTI ROLL BAR
    before:
    after:
    FENDER BAR
    before:
    after:
    SIDE LOWER BAR & MIDDLE LOWER BAR
    before:
    after:
    FRONT STRUTBAR
    before:
    after:
    FRONT LOWER BAR AND FRONT BAR
    before:
    after:
    ULTRA RACING CHASSIS:
    Tersedia untuk banyak aplikasi kendaraan.. BMW, Subaru, Nissan, Honda, Toyota, VW, KIA, Hyundai, Daihatsu, Audi, Mitsubishi, Suzuki, Ford, Mazda, Peugeot, Volvo, dll
    We, de Auto Motorsport - The Only Authorized Dealer for Indonesia Since 2007..! click here to verify..!
    Buy Genuine Ultra Racing products to improve your safety and car handling!
    untuk part yang kita tidak ada stock bisa available by order yang akan masuk setiap awal bulan.
    just call : coki siboro - 0815 1330 1978
    Imitation is The Best Form of Flattery..!
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pondok Kelapa No.11
    Duren Sawit - Jakarta Timur
    CDMA : (021) 9866.1978
    GSM : 0815.1330.1978
    Update Stocks List on 02.04.2013:
    Honda New Jazz GE8
    - Front Strutbar 2 Points > 850.000
    - Rear Strutbar 2 Points > 850.000
    - Fender Bar 3 Points (Set Right & Left) > 1.400.000
    - Front Lower Bar 2 Points > 800.000
    - Front Lower Bar 4 Points > 1.200.000
    - Middle Lower Bar 2 Points > 1.000.000 ---> temporary out of stock
    - Rear Upper Bar 2 Points Adjustable > 1.000.000
    - Room Bar 2 Points Adjustable > 1.100.000
    - Front Sway/Anti Roll Bar 24mm > 2.800.000
    - Rear Sway/Anti Roll Bar 16mm > 2.000.000
    - Rear Sway/Anti Roll Bar 19mm > 2.250.000
    Honda CRZ 1.5L 2010-Up
    Honda Freed 1.5L
    - Middle Lower Bar 2 Points > 950.000 ---> temporary out of stock
    - Rear Lower Bar 2 Points > 850.000
    Honda Jazz GD3
    - Front Lower Bar 4 Points > 1.250.000 ---> temporary out of stock
    - Rear Lower Bar 4 Points > 1.450.000
    - Rear Sway/Anti Roll Bar 16mm > 2.000.000 ---> temporary out of stock
    Honda All New City 2009
    - Front Strutbar 2 Points > 900.000
    Honda New City GD 04-07
    - Rear Lower Bar 2 Points > 900.000
    Honda City Type-Z & Persona
    - Rear Lower Bar 2 Points > 650.000
    Honda New Civic FD 06-up
    - Front Strutbar 2 Points > 950.000
    - Fender Bar 3 Points (Set Right & Left) > 1.500.000 ---> temporary out of stock
    - Rear Lower Bar 2 Points > 650.000 ---> temporary out of stock
    Honda Civic ES D17 VTi 01-05
    Honda Stream 1.7L & 2.0L
    - Rear Lower Bar 4 Points > 1.400.000
    Honda Civic EG Estilo/Genio
    - Front Strutbar 3 Points > 1.000.000
    - Fender Bar 2 Points > 800.000
    - Fender Bar 3 Points > 1.400.000
    - Rear Strutbar 4 Points > 1.100.000 ---> temporary out of stock
    - Rear Lower Bar 2 Points > 700.000
    - Room Bar 2 Points Adjustable > 950.000
    - Rear Upper Bar 2 Points Adjustable (Khusus Estilo) > 950.000
    Honda Civic EK Ferio
    - Fender Bar 3 Points > 1.450.000 ---> temporary out of stock
    - Rear Lower Bar 2 Points > 750.000
    - Room Bar 2 Points > 900.000
    Honda Civic EF Nouva
    - Front Strutbar 2 points > 850.000
    - Rear Lower Bar 2 Points > 800.000
    Honda New CRV 07-up
    - Front Strutbar 2 Points (Khusus New CRV 2.0L) > 1.000.000
    - Front Lower Bar 4 Points (Khusus New CRV 2.0L) > 1.300.000
    - Side Lower Bar 6 Points > 1.700.000
    - Rear Sway/Anti Roll Bar 23mm > 2.350.000
    Honda Accord Cielo - SV4
    - Fender Bar 3 Points > 1.500.000
    Acura Integra DC2
    Acura Integra DC5
    Toyota Innova
    - Front Strutbar 2 Point > 1.100.000
    - Room Bar 2 Point > 950.000
    - Rear Upper Bar 2 Point > 900.000
    - Rear Sway/Anti Roll Bar 19mm > 2.350.000
    Toyota Fortuner
    - Front Lower Bar 4 Points > 1.450.000
    - Rear Lower Bar 4 Points > 1.800.000
    >>> SPECIAL OFFER Paket 3 item diatas : 4.750.000
    Toyota New Avanza Veloz
    - Front Strutbar 4 Points > 1.200.000
    - Rear Sway/Anti-Roll Bar 16mm > 2.000.000
    - Rear Sway/Anti-Roll Bar 19mm > 2.250.000
    Toyota Avanza
    - Front Strutbar 4 Points > 1.100.000
    - Fender Bar 3 Points (Avanza 1.3L) > 1.400.000 ---> ON SALE 500.000
    Toyota Rush & Daihatsu Terios
    - Rear Lower Bar 4 Points > 1.350.000
    Toyota Starlet EP80/82 & EP90/91
    Toyota Prius C 1.5L 2011-Up
    - Middle Lower Bar 2 Points > 500.000
    - Rear Lower Bar 2 Points > 950.000
    - Side Lower Bar 6 Points > 1.850.000
    - Rear Sway/Anti Roll 16mm > 2.000.000
    - Rear Sway/Anti Roll 19mm > 2.350.000
    Toyota Corolla AE101/AE111
    Toyota Vios 2004-2007
    - Front Strutbar 2 Points > 850.000 ---> temporary out of stock
    - Rear Lower Bar 4 Points > 1.450.000 ---> temporary out of stock
    Toyota New Vios 2007-up
    - Rear Sway/Anti Roll 19mm > 2.250.000
    Toyota Yaris
    - Side Lower Bar 8 Points > 1.850.000 ---> temporary out of stock
    Suzuki Swift 05-up
    - Rear Sway/Anti-Roll Bar 19mm > 2.200.000
    Mitsubishi Galant VR4/Eterna
    Mitsubishi Galant Hiu 8thGen 2.4L 99-Up
    Mitsubishi Lancer CB4/CB5 92-95
    Mitsubishi Lancer CK4 96-01
    - Front Strutbar 3 Points > 1.000.000 ---> temporary out of stock
    - Rear Strutbar 3 Points > 1.000.000
    - Front Lower Bar 4 Points > 1.350.000
    Mitsubishi Lancer EVO I II III
    Mitsubishi Lancer EVO IV V VI
    - Front Strutbar 3 Points > 1.200.000
    - Rear Strutbar 2 Points > 1.000.000
    Mitsubishi Pajero Sport & Dakar 2009-up
    - Front Lower Bar 4 Points > 1.300.000
    - Front Sway/Anti-Roll Bar 28mm with PU Bushing > 3.000.000
    >>> SPECIAL OFFER Paket 3 item diatas : 4.500.000
    Proton Gen 2
    Proton Waja
    Nissan Cefiro A32
    - Rear Strutbar 2 Points > 900.000
    Nissan Grand Livina/Livina/Latio
    Nissan March K12
    - Front Strutbar 2 Points > 900.000 ---> ON SALE 500.000
    Nissan X-Trail 2.0L
    Nissan New X-Trail 2.0L 2008-Up
    Mazda 2
    - Front Strutbar 2 Points > 1.000.000
    - Front Lower Bar 2 Points > 900.000
    Ford Fiesta
    Chevrolet Captiva
    - Rear Sway/Anti-Roll Bar 20mm > 2.250.000
    BMW E30
    - Front Strutbar 2 Points Adjustable > 1.100.000
    BMW E36 318 4 Cyl - Timing Chain
    BMW E36 318 4 Cyl - Timing Belt
    BMW E36 325/328 6 Cyl
    BMW E39
    BMW E46 Facelift 320 2002-2005
    - Rear Strutbar 2 Points > 950.000
    BMW E46 6cyl 325/328
    BMW E90 320/325
    VW GOLF MK5 & MK6
    - Front Strutbar 2 Points > 1.100.000
    - Middle Lower Bar 4 Points > 1.350.000
    kontak : Coki Siboro - 0815 1330 1978
    de Auto Motorsport, Authorized ULTRA RACING Dealer for Indonesia Since 2007
    Sergeant
    Middle of Nowhere
    pm nett buat CK4 bro coki, thanks, sekalian PICnya yak...thanks
    Sergeant First Class
    8 Hrs 20 Mins 6 Secs
    pm nett utk Honda City Type Z
    - Front Bar 2 Points
    Quote Originally Posted by pikcuy View Post
    cek pm bos. thx
    Quote Originally Posted by RedLineSRG View Post
    sori, lagi gak bisa upload bos, postimage yg biasa saya pake lagi error nih..
    udah saya cocokin di ck4 masuk plug.
    Bos, tolong PM yg buat Innova, udh sm pasang blon?Pemasangan brp lama..Thanks
    Quote Originally Posted by buzzer64 View Post
    stock innova saya tinggal:
    rear sway/anti roll 19mm
    rear lower 2 points
    pemasangan untuk 2 item itu sekitar 1 jam.
    harga nya cek pm bos. thx
    dinaikin dulu biar keliatan..
    First Lieutenant
    West Jakarta
    5 Days 14 Hrs 42 Mins 27 Secs
    boss.... pls pm price nya buat grand livina smua jenis strutbar nya yaa....thnx alot bro
  12. #11
    Quote Originally Posted by maestro View Post
    ultra racing untuk livina ada:
    - front bar 2 titik
    - front lower bar 4 titik
    - rear lower bar 4 titik
    - rear sway/anti roll bar 16mm
    udah di pm bos. thx
  13. #12
    dinaikin dulu...
  14. #13
    dinaikin lagi..
  15. #14
    First Sergeant
    Batam
    3 Days 19 Hrs 51 Mins 55 Secs
    strutbar depan (mesin) utk starlet ada bos?
  16. #15
    Quote Originally Posted by qlooth View Post
    starlet mesti order bos..
Tritala Rajawali Autogallery Banner Available 242x90
  1. /// ULTRA RACING STRUTBAR ///
    By coki.de auto in forum Per & Shockbreaker
    Last Post: 7th May 2013, 15:13
  2. strutbar ultra racing GE8
    By Davl08 in forum Bursa Eksterior Lainnya
    Last Post: 11th August 2012, 10:54
  3. Strutbar Kit ULTRA Racing GD3
    By 8ight in forum Per & Shockbreaker
    Last Post: 2nd May 2011, 10:02
  4. FS : STRUTBAR ULTRA RACING GD3
    By evan in forum Bursa Eksterior Lainnya
    Last Post: 25th September 2010, 16:49
  5. WTS strutbar ultra racing for GE8
    By Davl08 in forum Jual Beli Mesin Lainnya
    Last Post: 26th February 2010, 06:38
Cartens
