[help] oil pump rb20det & rb20e, sama kah?
Results 1 to 10 of 11
  • Short URL:  http://modifika.si/12395
    Earth
    1 Day 1 Hr 51 Mins 14 Secs
    oil pump gw pecah.. mesinnya rb20det.. sama ga ya sama rb20e.. kalo sama kan gw bisa kanibal jadinya.. thxxxx..
    jakarta timur
    9 Hrs 9 Mins 19 Secs
    sama gw tanya tadi..
    batre gw abis gak bisa nelpon lu.....
    aheuehauhuea..
    udah giotu gw cas di bengkel ketinggalan lagi sampe rumah baru inget hp gw ilang.....
    eahuheauhuehauhuea
    purchasing
    Quote Originally Posted by avanza-ku cupu
    aheuehauhuea..
    eahuheauhuehauhuea
    Jumat baru gw anterin HP lo wiz ^_^
    Earth
    aheuehauhuea..
    eahuheauhuehauhuea
    pulsa gw jg tgl bbrp ratus perak.. xl jg lg kosong.. hahaha.. pasti sama ne..?
    purchasing
    Coba tanya authorized dealer part-nya aja bro, dia punya buku sparepartnya lengkap tu sapa tau bisa dibantu.
    nomornya 351-6452, 92864717
    Earth
    kaga ada dia.. hoalah.. dimana lagi ya..
    5 Hrs 4 Mins 21 Secs
    emangnya ga sama ga??..
    udah bayarin mesinnya owis ahjeee....
    kgk masuk. oil sump turbo sama non turbo beda ntar malah kalo lo pake non turbo sump turbonya kgk dapet oli.
    Earth
    mau ga mau pesen dr luar deh.. hikz..
    hihhii sapa suruh punya mobil aneh2 :p HAHAHA jk's
    kalo oil pump cari yang baru bos. btaran kalo rusak berabe lagi.. coba cari kontak orng di Ausie ato jepang.. barang nya banyak yang baru2 buat sparepart
  1. jual RB20e ORI cefiro94
    By cefiroku in forum Jual Beli Mesin Lainnya
    Last Post: 14th May 2012, 13:37
  2. Barang std Nissan RB20E
    By B936CA in forum Jual Beli Mesin Lainnya
    Last Post: 4th January 2011, 22:00
  3. wtb : oil pump rb20e
    By kingofscript in forum Jual Beli Mesin Lainnya
    Last Post: 25th June 2010, 11:17
  4. CARI : Timing Belt Sama Water PUMP B18C Dohc VTEC honda
    By D21FT in forum Jual Beli Mesin Lainnya
    Last Post: 18th February 2008, 09:51
  5. Cari : WTB : Timing Belt sama Water pump B18C
    By D21FT in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 14th February 2008, 14:17
