POLK MOMO MM465 2 way speaker component system (sold,thanks modcom....)
Results 1 to 10 of 30
  • Short URL:  http://modifika.si/123874
    Cool POLK MOMO MM465 2 way speaker component system (sold,thanks modcom....)
    POLK MOMO MM465 2 way speaker component system muluuuuus.........sold
    MM465
    6 1/2" Two-way Component System
    American Power, Italian Finesse
    retail price : USD350
    Housed in a diamond-polished MOMO Arrow cast aluminum basket, the MM465 6.5" driver features a poly/mica composite cone, airtight Elastomer rubber surround and flat, bulletproof (we mean, they make bulletproof vests out of this stuff, honest!) Aramid Fiber spider for more than torture-proof durability; you'll hear rock solid mid-bass response and lifelike midrange detail, all pouring forth through the unique "billet-style" open grille. Polk/MOMO is built tough and backed by a three year Parts and Labor warranty, the best warranty in the car speaker world.
    The component system features the MM400 Dome Tweeter, and the beautiful new Polk Audio/MOMO Crossover.
    You can plainly see (and hear) the benefits of the new MM System Crossover: Mylar capacitor/air core inductor tweeter components for better transparency. Polypropylene capacitor/laminated steel midrange components handle high current without saturation for more dynamic impact. 12dB/octave slope with midrange bypass, 3-position tweeter attenuation for the ultimate in flexibility. Gold signal traces and gold-plated terminals for exact connections.
    Polk Audio/MOMO High Performance Car Audio Speakers are built by Polk Audio with ultra high-tech materials for competition-level performance and durability. They're styled exclusively by MOMO, the world's preeminent designer of racing accessories, to look as good as they sound. And for motor sports enthusiasts the world over, a MOMO product is a charismatic symbol of the finest quality.
    When you consider your car an extension of your personality, Polk Audio/MOMO High Performance Car Audio is the perfect synthesis of technology and design.
    Driver Complement :
    Mid/Woofer 1 - 6-1/2" Diameter (16.51cm)
    cast aluminium diamond polished baskets with Poly Mica composite cone
    Tweeter 1 - 1" Diameter (2.54cm)
    silk composite dome with ULV fluid cooled voice coil with neodymium magnets
    Electrical
    Overall Frequency Response 50 Hz - 20 kHz
    Nominal Impedance 4 ohms
    Power Handling (continuous) 25 w
    Power Handling (peak) 150 w
    Efficiency 87 dB
    Crossover LPF/HPF 4200Hz second order Butterworth
    Crossover Dimensions 3-3/8" x 4-3/4" x 1-5/8"
    (8.57cm x 12.06cm x 4.13cm)
    Voice Coil Diameter: Driver 1-1/2" (3.81cm)
    Voice Coil Diameter: Tweeter 1" (2.54cm)
    Magnet Weight 14.40 oz.
    Driver Mounting Depth
    Top Mount 2-13/16" (7.14cm)
    Bottom Mount 3-1/16" (7.78cm)
    Tweeter Mounting
    Flush Mount Depth 7/8" (2.22cm)
    Surface Mount Height 1" (2.54cm)
    Grille
    Height 3/4" (1.91cm)
    Diameter 7-1/4" (18.41cm)
    Cut-out
    Driver Cut-out Diameter 5-15/16" (15.08cm)
    Tweeter Cut-out Diameter 2-1/16" (5.24cm)
    call
    081388575788
    UP............
    up....................
    Kebun Jeruk
    Question PM
    Brapaaa net price nya Boss? thx
    klaten
    model nya keren and mantab...
    apakah suara nya semantab penampilannya boss....??
    skalian bantu up....
    pm sent bos yochi...
    monggo didenger langsung bos danny....
    thanks...
    up.....................
    up.................
Mega Glodok Kemayoran Tekiro
  1. Replies: 27
    Last Post: 31st May 2010, 12:22
  2. Replies: 26
    Last Post: 2nd March 2010, 11:34
  3. Replies: 17
    Last Post: 8th August 2009, 01:52
  4. Replies: 12
    Last Post: 11th July 2009, 16:15
