nakamichi ec-302 muluuuuuus.............(sold,thanks modcom....)
  • Short URL:  http://modifika.si/123521
    Cool nakamichi ec-302 muluuuuuus.............(sold,thanks modcom....)
    nakamichi ec-302 kondisi muluuuuuus dan lengkap bracket...........sold
    Electronic Crossovers With Unsurpassed Sonic Performance And Flexibility
    The EC-204 and EC-302 are extremely versatile electronic crossovers that ensure the highest level of performance in a wide variety of multi-amp system configurations. Both feature state-of-the-art circuitry and are constructed of the finest materials and components. Examples of Nakamichi's attention to detail include fully balanced internal circuit configurations that permit phase inversion without additional stages. All level controls precede the active filters so that output impedance is unaffected by their settings. Bypass outputs provide unaltered throughput of the input signals, ensuring the simplest, highest quality signal path when the EC-204 and EC-302 are combined in more sophisticated multi-way systems. The bypass provision also makes it possible to adjust one part of the system without affecting subsequent parts of the chain.
    Both units incorporate DC-DC converter bipolar power supplies, which make it possible to use the most advanced, low-distortion, wide-dynamic-range circuitry. Both also feature floating ground and Nakamichi's Isolated Ground topology to maintain high signal purity and virtually eliminate the effects of external interference. 18dB/octave filters are used to minimize multi-source interference across driver ranges. And low-impedance outputs increase resistance to inductive noise pickup.
    The EC-204 is a 2-way, 4-channel network designed specifically for multi-amp systems using the SP-1010 or SP-80 subwoofer. It provides front and rear left/right inputs; front and rear left/right outputs; plus constant bass outputs. The front and rear bass-to-mid/high crossover frequencies can be independently adjusted in 10Hz increments from 10Hz to 310Hz.
    The EC-302 is a 3-way, 2-channel design that can be used in two types of multi-amp systems: woofer/midrange/tweeter or subwoofer/bass-midrange/tweeter. In the latter case two EC-302 units can be used to allow the head unit's front/rear fader to control the bass-midrange drivers and tweeters while the subwoofer operates in constant bass mode. A multiplier switch permits the low-mid crossover frequency to be selected from the 10Hz to 310Hz range in 10Hz increments or the 100Hz to 3.1kHz range in 100Hz increments. The mid-high crossover frequency can be adjusted from 500Hz to 15.5 kHz in 500Hz increments.
    call
    081388575788
    up................
    up..........................
  1. Replies: 5
    Last Post: 25th January 2010, 15:24
  2. Replies: 112
    Last Post: 15th December 2009, 04:19
  3. Replies: 54
    Last Post: 6th September 2009, 04:31
  4. Replies: 10
    Last Post: 28th July 2009, 08:54
  5. Replies: 18
    Last Post: 19th June 2009, 20:43
