midrange scanspeak revelator 12m/4631-G00 kondisi muluuus...(sold,thanks modcom....)
Results 1 to 10 of 33
  • Short URL:  http://modifika.si/122216
    Cool midrange scanspeak revelator 12m/4631-G00 kondisi muluuus...(sold,thanks modcom....)
    midrange scanspeak revelator 12m/4631-G00 kondisi muluuus ex garansi nexindo........sold
    Scan-speak Revelator 4.5" Midrange
    The 12M/4631G is a Revelator driver using the “slit cone" technology. Some of the slits are used to control cone resonance and the other set of slits add rigidity. This speaker also has the new dynamic linear suspension for lower compression and higher linearity. Every facet of this driver is designed to reduce resonance in all structures. A neodymium magnet has been chosen to reduce the depth, yet increase the magnetic energy. The short field length of a neodymium magnet also allows this driver to by used for A/V.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 89dB
    Free air resonance Fs 75 Hz
    DC resistance 3.2 W
    V.C. inductance 0.22 mH
    Power 40W
    Effective cone area 49 cm2
    V.C. diameter 38 mm
    V.C. height -
    Air gap height -
    Lin. & max. excursion 3/ 7 mm
    Air gap flux density -
    BL 5.3 Tm
    Moving mass incl. air 6.5 g
    Net weight 0.51 kg
    Outside diameter: 115.5mm
    Cut out: 92mm
    Depth: 48.4mm
    25.4mm = 1" = 2.54cm
    call
    081388575788
    klaten
    bantu up boss buat barang manteb
    thanks bos danny...
    3 Hrs 3 Mins 17 Secs
    bantu up, bro chris... barang bagus, kondisi mulus abis neh...
    thanks ya bos nanami....
    up................
    up.............
    Jakarta - Surabaya
    7 Hrs 40 Mins 53 Secs
    cuma bisa ngiler bos
    bisa aja nich bos william..
    thanks ya bos...
    up...................
  1. wts: scanspeak 12m 4631 midrange 1 biji saja
    By kykyhalim in forum Speaker - SubWoofer
    Last Post: 27th January 2014, 01:40
  2. WTB : Scanspeak revelator 12M 4631
    By newbieaudio88 in forum Speaker - SubWoofer
    Last Post: 1st December 2011, 05:50
  3. Replies: 1
    Last Post: 11th November 2009, 03:13
  4. Replies: 40
    Last Post: 28th July 2009, 07:12
