<ask> P2j vs P08
Results 1 to 10 of 28
  • Short URL:  http://modifika.si/121962
    west end jakarta - west end java
    4 Hrs 51 Mins 44 Secs
    <ask> P2j vs P08
    para suru honda di modcom yang saya segani..mo tanya nie
    kenapa di sini banyak yg lebih mengoptimalkan head P08 dibanding P2J...
    padahal dalam kondisi std mesin d16y8(head P2J) lebih unggul 2hp di banding mesin d16z6(head P08 )
    oia ni gw kutip dikit dari situs luar yg ngebandingin antara 3 mesin d series d16a6, d16z6 n d16y8
    General Specs for 97 cu in (1.6L) D Series
    Bore................2.95"(75mm)
    Stroke.............3.54"(90mm)
    Deck Height.....8.347"
    Rod Length......5.394"
    ______Compression______HP___________TQ
    D16A6.......9 to 1...........108@6000.......100@5000
    D16Z6.......9.2 to 1........125@6600.......106@5200
    D16Y8.......9.6 to 1........127@6600.......107@5500
    Torque Specs
    Camshaft Holder 8mm Bolts.....14-15ft lbs
    Camshaft Holder 6mm Bolts.....104 inch lbs
    Camshaft Pulley Bolt.......27ft lbs
    AEM Cam Gear Adjustment Bolts(3 of them)....15ft lbs..apply Loctite "red" to the three retaining bolts
    Connecting Rod Nut........23ft lbs
    Crankshaft Pulley Bolt.....119ft lbs(D16A6).....134ft lbs(D16Z6)
    Cylinder Head Bolts for D16A6
    step 1.......22ft lbs
    step 2.......48ft lbs
    Cylinder Head Bolts for D16Z6
    Step 1....22ft lbs
    Step 2....53ft lbs
    Cylinder Head Bolts for D16Y8
    step 1(bolts 1-10)....15ft lbs
    step 2(bolts 1-10)....36ft lbs
    step 3(bolts 1-10)....49ft lbs
    step 4(bolts 1 & 2)....49ft lbs
    Cylinder Heads ...All D ARP Studs
    Step 1......15ft lbs
    Step 2......30ft lbs
    Step 3......62ft lbs
    Cylinder Head Bolt Thread Size and Pitch.....10mm x 1.25mm
    Distributor Mount Bolt....17-18ft lbs
    Flywheel Bolt........87ft lbs
    Intake Manifold to Cylinder Head Nut..16ft lbs
    Main Bearing Cap Bolt........47ft lbs(D16A6)..........Step 1...18ft lbs(D16Z6 and Y
    Step 2...38ft lbs(D16Z6 and Y
    Rocker Arm..D16A6
    End Rocker Arm Shaft Cap..9ft lbs
    All Others and all D16Z and Y8s..........16ft lbs
    Throttle Body Nut.......14-16ft lbs
    Timing Belt Adjuster Bolt.....33ft lbs
    Valve Adjustment Nut....10ft lbs(D16A6)....14-15ft lbs(D16Z6 and Y
    Cylinder Head Specs
    Valve Sizes D16A6 Intake......29mm Exhaust....25mm
    D16Z6 and Y8 Intake...30mm Exhaust....26mm
    Valve Clearance
    Stock D16A6,D16Z6 and D16Y8 Cams
    Intake.....007-.009" (.17-.22mm)
    Exhaust...009-.011" (.22-.27mm)
    Head Chamber Volume
    D16A6......................38cc
    D16Z6 and D16Y7.....34.6cc
    D16Y8......................32.8cc
    Throttle Body Sizes
    D16A6..... 55mm
    D16Z6......56mm
    D16Y7......56mm
    D16Y8..... 56mm
    Flow chart of a D16Y head(stock vs street/strip porting)
    A favorite thread i like to visit discussing the Z head vs Y
    http://pub143.ezboard.com/fhon...topic
    Camshaft Specs
    Special Note:You can use a D16Z Cam in a D16Y Head but you have to use the Cam Gear from a D16Z because it'll be a 1/2 timing tooth off..same goes for D16Y cam in D16Z Head,just use Cam Gear for a D16Y..Do NOT buy any aftermarket Cam Gear for a D16Y from a company if they only have one Cam Gear available for the 88 thru 00 Ds.I recommend and use a AEM Gear,they have the right Cam Gears for 88-95s and 96-00s
    D16A6 Cams
    ........................Adv Dur..Dur@.050
    ........................ Int/Exh...Int/Exh...Lobe Separation...Gross Lift
    Stock D16A6.......222/224..194/196........110................333/362
    Crane#251-0010.226/228..200/202........107................384/376
    Crane#251-0012.232/234..206/208........108................394/386
    Crane#251-0014.232/228..206/202........110................394/376
    Crane#251-0016.242/244..216/218........110............... 425/416
    D16Z6 Cams
    Comp Cams and Zex #59100
    Adv Duration Duration@.050
    ___Int/Exh__Int/Exh_Lobe Sep_Gross Lift
    PRI..228........186........111..........285
    SEC.232........190........115..........300
    VT..256.........215........103..........440
    EXH.252........210........111..........400
    Comp Cams and Zex #59300
    PRI..232........190........111..........300
    SEC.236........194........115..........310
    VT...260........220........107..........455
    EXH.268........216........111..........430
    D16Y8 Cams
    Stock D16Y8 Cam
    PRI..211........183........115..........300
    SEC.215........187........113..........319
    VT...247........217........114..........397
    EXH.235........204........110..........370
    Crane#252-0010
    Adv Duration Duration @ .050
    ____Int/Exh__Int/Exh__Lobe Sep___Gross Lift
    PR.....214.........186.........108.............319
    SEC...218.........190.........106.............327
    VT.....258.........224.........106.............423
    EXH...238.........210.........114.............386
    Crane#252-0012
    ____Int/Exh__Int/Exh____Lobe Sep__Gross Lift
    PRI...214.........186..............112...........3 19
    SEC..218.........190..............110...........32 7
    VT....266.........232..............110...........4 43
    EXH..246.........218..............114...........40 6
    dari yg gw baca di atas terlihat mesin d16y8 lebih unggul sedikit,tetapi knapa banyak pemakai d series mengganti head p08??bahkan ferio pun yg mesin stdnya dah d16y8 banyak yg ganti k p08
    mohon petunjuknya
    TYPE ONE garage
    17 Hrs 21 Mins 39 Secs
    mohon pencerahannya juga...................
    Tangsel
    1 Wk 34 Mins 21 Secs
    sama sekalian tanya p2j itu ada brapa macem??kalo yg di city z itu yg seri yg mana?
    Quote Originally Posted by Mr.Qq View Post
    ni ada sedikit info ttg head mesin
    D16Z6
    92 Si D16Z6 5sp------- P08-2 (9/2) stamped on RS of code.
    93 Si D16Z6 5sp-------P08-4 (9/3) stamped on rs of head
    93 EX D16Z6 5spd----- P08-4
    93 EX D16Z6 5sp-------P08-3
    94 EX D16z6 5 spd---- PO8-2
    94 Si D16z6 5sp-------- P08-3
    94 EX D16Z6 5sp--------P08-4
    94 SI D16z6 5sp -------P08-5
    95 EX D16Z6 Auto------P08-2
    D16Y4
    96 GLi D16Y4 5sp........P2A-2 "96" stamped on right
    D16Y7
    97 LX D16Y7 5sp-------P2F-HA-2
    97 LX D16Y7 Auto------P2F-HA-4 also had USA and (9/6) stamped on it
    98 DX D16Y7 5sp------P2F-HA-3 also has USA and (9/7) stamped on it
    00 DX D16Y7 Auto -----P2F-HA-7
    D16Y8
    96 EX D16Y8 Auto------P2J-2 stamped 95 on rs of head
    97 EX D16y8 5spd-----P2J-4 --- "97" stamped on the right
    97 EX D16Y8 Auto-----P2J-6 "97" stamped on rs of head
    97 EX D16Y8 Auto-----P2J-7
    97 EX D16Y8 5sp-----P2J-6 "96" stamped on right side
    98 EX D16Y8 Auto-----P23-2
    99 EX D16Y8 5sp------P2J-4
    00 EX D16Y8 5sp------P2J-3 "99" stamped on right side
    Tangsel
    brarti yg p2j-3 yah??hehe... trus bedanya apa ama p2j yg seri laen??
    Palembang.
    6 Days 10 Hrs 51 Mins 52 Secs
    mungkin krn di p08 vtecnya udah murni, sedangkan di p2j msh banci (vtec-e)
    jadi mesin d16y8 bisa dimaksimalin dengan pake p08.
    iya yah tp gw bingung jg kok engine bawaan p08 cuma 125hp
    heheh
    SOHC VTEC
    ehm...
    gw rasa vtec pada d series gada yg murni d,coz banyak yang bilang klo mo rasain vtec sejati ya di mesin dohc...
    tapi klo diliat spec head yang membedakan cuma durasi cam ( P08 lebih tinggi) dan volume chamber (P08 lebih besar)
    up..up..up..
    1 Day 23 Hrs 11 Mins 2 Secs
    to Mr Qq---------> city z 1.5L bkn 1.6L. mesin D15 bkn D16.
    Jak-Sel
    3 Wks 2 Days 20 Hrs 35 Mins 22 Secs
    permisi... kalo P08-6 speknya begimana pak..?? gua pake p08-6 soalnya...
GT Radial NGK Busi
