3 way HERTZ HI-ENERGY HSK 163 lengkap n muluuuus.........(sold,thanks modcom...)
  • Short URL:  http://modifika.si/121662
    Cool 3 way HERTZ HI-ENERGY HSK 163 lengkap n muluuuus.........(sold,thanks modcom...)
    3 way HERTZ HI-ENERGY HSK 163 kondisi lengkap dus,kartu garansi,manusl book n muluuuus,grilles belum pernah dipakai.......sold
    HERTZ HSK 163
    Preço por Unidade (piece): €290.00
    Tem Dúvidas Sobre Este Produto
    Three way system deriving from the combination of HV 165L woofer, HL 70 midrange and HT 25 tweeter. 3W.10 crossover, specially designed for it, is compact and easy to use; it has high quality components and provides optimized crossover points, insuring the best results in whatever car compartments thanks to the independent adjustment of midrange and tweeter emission level. Given with a rich mounting hardware, HSK 163 is very versatile and can meet various needs.
    Technical Specifications
    -Size – 165mm (6”1/2) Woofer, 70mm (3”) Mid., 25mm (1”) Tweeter
    -Comp – 3 Way system: HV 165, HT 70, HT 25 Factory provided separate crossover 3W. 10
    -Sensitivity – 92 dB/SPL
    -Power Handling – 300W Peak Power, 150W Continuous Program Power
    -Frequency Range – 40Hz – 22Khz
    -Impedance – 4 Ohm
    * Woofers: cones made of pure paper with cotton fibres, phase plugs new profile, exclusive DWR® surround with improved mix of rubber, latex and silicone, baskets special anti-scratch finishing, exclusive support for connectors and lead wires, grilles Included.
    * Midranges: REN® neodymium double magnet, polypropylene cone and central phase plug, three layer copper voice coil wound on kapton former.
    * Tweeters: dome made of pre-coated TETOLON®, rear acoustic chamber, neodymium magnet, revolving support and accessories for factory location and flush mounting.
    * Crossovers included.
    * Grilles included.
    call
    081388575788
    UP..............
    up,...............
NGK Busi GT Radial
  1. Midbass Hertz Energy 6.5 inch EV165 (sold,thanks modcom...)
    Last Post: 3rd February 2010, 06:07
  2. Replies: 25
    Last Post: 4th January 2010, 15:31
  3. Replies: 15
    Last Post: 28th December 2009, 05:20
  4. Replies: 29
    Last Post: 17th July 2009, 00:45
  5. alpine cda 9887 kondisi muluuuus dan lengkap....(sold,thanks modcom..)
    Last Post: 16th June 2009, 03:33
