[SOLD OUT !! ] ARC Audio SE4100 - Signature Edition
Results 1 to 10 of 119
  • Short URL:  http://modifika.si/121297
    Medan
    9 Hrs 57 Mins 52 Secs
    SOLD OU T!! SOLD OUT !!
    Dijual Power untuk SQ.. seri TOP alias Pemungkas dari ARC Audio USA, ARC Signature Edition; Design by Robert Zeff (Perancang Car Amplifier TOP Dunia)
    Kalau kualitas suara boleh ditanya tuh
    Kelengkapan Unit Doank.. No Box No Manual.. Masih Segel by Massindo.
    dijual berhubung boil mau di jual.. sayang juga hiks hiks
    Harga nya : SOLD OUT !!
    Overview :
    * Audiophile sound quality based design
    * Designed by Robert Zeff
    * Class A/B switching design
    * Microprocessor controlled design
    * Microprocessor controlled Code based flashing diagnostics
    * Concealed adjustment controls
    * Open architecture adjustable crossovers on all channels HP/BP/LP/FP
    * 12/24Db per octave selectable crossover slopes on all channels
    * Internal chassis force cooled speed controlled fan for optimum cooling
    * Hi/Low level balanced switchblade RCA inputs for maximum system integration
    * RJ45 Ethernet input connections for true balanced input connections
    * Block type terminal connections
    * 256 color user selectable illumination circuit
    * Combined Bias circuit and temperature regulation circuit to regulate bias and lower THD at any point in total thermal cycle
    * Microprocessor high voltage power supply allows the amplifier to optimize power output at different ohm loads without the loss of efficiency or sound quality
    * Vdrive based preamp stage improves efficiency lower internal signal loss
    * Hand picked output devices used on all SE amplifiers.
    Spesifikasi :
    4 Channels @ 4 0hms 4 x 65 watts
    4 Channels @ 2 0hms 4 x 110 watts
    4 Channels @ 1 0hms 4 x 86 watts
    2 Channels @ 8 0hms 2 x 125 x 2watts
    2 Channels @ 4 0hms 2 x 215 watts (bridged)
    2 Channels @ 2 0hms 2 x 146 watts (bridged)
    Frequency Response : 4Hz - 100KHz
    Crossover Range : 30Hz - 550Hz (x10 300Hz - 5500Hz)
    Bass Boost : 0 - 15dB @ 20Hz-80Hz
    Fuse : 40A x 2
    S/N Ratio (a wtg) ref 1Wall 40hm : >93 dB
    Seperation @ 1kHz : >70 dB
    Dampeninig (25W 2x40hm 100Hz) : >1200
    Low Level Imput Sensitivity .3V - 4V
    Balanced Input Sensitivity .6V - 8V
    High Level Input NA
    Idle Current 1.50A
    Dimensions 15 1/2 "(L) X 8"(W) X2 1/2"(H)
    Diskusi Tentang SE 4100 :
    http://www.modifikasi.com/showthread.php?t=67755
    http://www.modifikasi.com/showthread.php?t=67044
    http://www.modifikasi.com/showthread.php?t=67484
    Siapa cepat dia dapat....
    Monggo....
    Peminat Serius boleh SMS ke : 08126446888
    Dagangan Lainnya:
    Subwoofer Genesis Audiophile 25.01 - Barang Hi-End Langka
    Subwoofer ARC XTREME 12.4 DVC - SOLD OUT
    Medan
    Ayo.. buruan.. barang langka nih... siapa cepat dia dapat !!
    Medan
    up up up up up.... ayo ayo ayo..
    klaten,jogja,solo
    4 Hrs 35 Mins 52 Secs
    nettnya aja bos,g tau pasarannya..
    Jakarta-Semarang-Pontianak
    2 Days 3 Hrs 44 Mins 3 Secs
    pm net bos..?
    Medan
    PM Sent bos..
    1 Wk 5 Days 18 Hrs 25 Mins 55 Secs
    bantu up, barang mantab
    DKI/BSD
    1 Wk 2 Days 19 Hrs 57 Mins 59 Secs
    mantapppp........
    ____________
    0812-951-3972
    2 Hrs 32 Mins 42 Secs
    keren banget
    19 Hrs 45 Mins 27 Secs
    nett nya berapa bos...boleh di pm ?
Venom 300x250 MBtech
  1. [WTB]: ARC 2300 Signature Edition
    By flipz in forum Power Amplifier
    Last Post: 18th June 2010, 10:12
  2. WTS : Midbass RS Audio Signature Series
    By TJ_TJ in forum Speaker - SubWoofer
    Last Post: 12th February 2010, 19:38
  3. Replies: 59
    Last Post: 26th September 2009, 06:52
  4. super rare clarion hxd-2 signature edition (sold,thanks modcom.......)
    Last Post: 8th September 2009, 05:09
  5. Replies: 4
    Last Post: 20th February 2009, 18:16
