CLARION HXD2 muluuuuuus lengkap dus................(sold,thanks modcom....)
Results 1 to 10 of 19
  • Short URL:  http://modifika.si/121140
    Cool CLARION HXD2 muluuuuuus lengkap dus................(sold,thanks modcom....)
    CLARION HXD2 muluuuuuus lengkap dus,bracket,baut,frame body,frame panel,remote,dc/dc converter dan segel...............sold
    Clarion HXD2 24-bit CD Tuner
    Only The Chosen People Are Touched By Original Sounds.
    High-definition sound fills the driver with a sense of superiority. There is a true feeling of joy and emotion when you are face to face with music. In the pursuit of sound that is infinitely near to the original sound and generously supplied with cutting-edge technology, the creation of the HX series has brought Clarion’s exceptional sound to a new high peak. The ultimate sound field and space are produced from Clarion’s cutting-edge technology oriented circuitry, along with individually selected parts and raw materials, all united perfectly with the amplifiers and speakers. For drivers who demand the “real thing”, Clarion offers sound quality that goes one step beyond, for that truly special driving time.
    Clarion’s HX-D2 main unit takes you into the recording studio
    From the pursuit of faithful sound source playback to the body layout, the series flagship model HX-D2 is packed with all of the functions one could possibly want from a modern main unit. The 96 kHz Sampling D/A converter draws out the delicate nuances and reverberations from the sound, while the 5 Band Parametric EQ creates the sound balance that perfectly matches your tastes. Additionally, the Glass Epoxy 4-Layer Circuit Board and external power supply unit DC/DC converter provide stable circuit operation and high-quality sound. Clarion offers sound that reaches the next level to discerning car audio fans who appreciate the subtle differences in sound, and that are searching for the ultimate in car sound quality.
    Clarion HXD2 Features
    Dual 24-bit / 96kHz sampling digital to analogue burr-brown converters and DSP
    Built-in 4-way crossovers
    5-band parametric equaliser
    Digital time alignment for each line level output
    8-channel/4-volt gold plate oxygen-free RCA output
    0.5dB-step electronic volume adjustment circuit
    Copper plated chassis
    External DC/DC converter
    CeNET control of: 6-disc CD changer, and TV tuner
    2 x 2-channel AUX inputs
    Zinc die-cast faceplate
    Fiber optic input/output
    Vacuum florescent display
    18FM, 6AM station presets
    CeNET iPod interface compatible
    Conventional CD players could only reproduce up to around 20kHz.
    Sampling takes place to convert digital signals to analogue. In this process, digitised sound with a frequency range of up to about half the sampling frequency is reproduced. For example, in the case of CDs which are sampled at a frequency of 44.1kHz, playback is possible for up to half that, or 22.05 kHz. Sampling is set at 44.1kHz to achieve reproduction of highs in the neighborhood of 20kHz.
    Harmonic elements included in high range add richness and depth to sound.
    The format specifications for CD deemed the high frequency elements above 20kHz as inaudible by the human ear, and thus they were not recorded. And even if such high frequencies were reproduced during playback, they would be detected as noise elements and removed by a digital filter. Not only that, but phase distortion was introduced as a result of noise cut-off by the filter, thereby inhibiting the accurate reproduction of high frequency sounds. Ironically, it is the harmonic elements contained in this high frequency range that affects the depth and nuance of sound.
    96kHz sampling enables reproduction of sounds faithful to the original source.
    The 96kHz Sampling D/A converter samples at a much higher rate than the usual 44.1kHz to offer reproduction frequencies as high as 48kHz (half the sampling frequency of 96kHz), surpassing the format specifications for CD as the first such D/A Converter for car audio use. By broadening the sampling range, it becomes possible to reproduce the subtle nuances and depth contained in harmonic elements while reducing phase distortion in the high frequency range, delivering the full expressiveness and natural resonation that is inherently present in sound.
    Copper Plated Chassis prevents sound deterioration
    Uses a copper plated chassis to minimize the generation of spurious electrical current which can adversely affect sections that have a bearing on the signal, as well as noise interception caused by electrical shielding effect. By incorporating a zinc diecast panel, with its large specific gravity, high rigidity and low resonance, sound quality deterioration due to vibration is reduced. And by externally positioning noise generating parts such as the power supply, VFD devices for the display and the drive mechanism, the sources of noise are eliminated.
    Burr Brown advanced segment type 24-bit D/A converter
    After high sampling the data is processed by an advanced segment type Burr Brown 24-bit D/A Converter which offers superior dynamic characteristics and is resistant to clock jitter. Since the D/A Converter’s internal structure is a 4DAC configuration which operates on L/R± differential, higher accuracy in D/A Conversion is afforded.
    Display OFF function
    Turns off the display circuits when a CD or other source is being played, preventing pulse noise from the display section from affecting sound quality.
    Keeping great sound in and noise out: The HX-D2’s DC/DC converter
    Consisting of only the highest quality components – from the chassis to the wiring and fuses – the HX-D2’s external power supply is the heart of this audiophile-grade main unit. With its six-sided shielded casing, this design thoroughly keeps out noise, even during high load bursts. And to prevent any vibration, Clarion wraps this high-quality power supply in an aluminum diecast casing, and a copper-plated chassis. Internally, the HX-D2’s power supply utilises toroidal choke coils, which minimise car noise and power loss. The unit also utilises a large-capacity, low-impedance condenser, which allows this external component to supply pure power. Clarion takes this a step further by equipping the power supply with a gold-plated connection terminal, which minimises power loss.
    World’s finest 0.7cm-step Digital Time Alignment
    This function lets you set each speaker in a maximum 8-channel system to deliver the same acoustic effects with pinpoint accuracy, regardless of the listener’s seat position (FRONT-L, FRONT-R, FRONT, REAR, and FULL SEAT position selectable). The Front L/R, Rear L/R, Centre speaker and Subwoofer work in harmony to create a seamless soundscape. It’s possible to quickly and easily select the acoustic pattern of the system, or choose different settings according to the number of passengers or type of vehicle. (Adjustable range: 0 – 500cm, in 7mm steps)
    Specification
    TUNER SECTION
    Frequency bands
    FM: (MHz) 0.05MHz steps 89.0 to 108
    MW: (kHz) 9 kHz steps 531 to 1629
    LW: (kHz) 3 kHz steps
    FM usable sensitivity (dBf) 9
    FM 50 dB quieting sensitivity (dBf) 15
    FM alternate channel selectivity (dBf) 70
    FM stereo separation @1 kHz (dB) 35
    FM stereo freq. resp. @ ±3 dB (Hz) 30 to 15,000
    CD SECTION
    Wow/Flutter (WRMS) Below measurable lmits
    S/N ratio (dB) 112
    Frequency response (Hz) 5 to 20,000
    Dynamic range (dB) 100
    Harmonic distortion (%) 0.003
    GENERAL
    Dimensions (W × H × D), mm 178 × 50 × 178
    Remote control (W × H × D), mm 52 × 125 × 12
    Weight (kg) 1.7
    Power consumption: less than 1.4 A
    Speaker impedance 4Ω(4Ω to 8Ω allowable)
    call
    081388575788
    Yogyakarta
    1 Day 11 Hrs 37 Mins 55 Secs
    Photonya kerrenn.....detail banget......moga cepet laku.................
    [option] Jakarta
    1 Wk 5 Days 16 Hrs 9 Mins 13 Secs
    mantab....................
    cepet laku bos...
    dimana hatiku senang
    4 Hrs 53 Mins 23 Secs
    barang2nya mantap gan....
    1 Day 4 Hrs 42 Mins 11 Secs
    hu idaman bgt nih
    tp sayang ga kebeli nih bos
    bantu doa aja yah bos
    btw kan katanya nih hu mau dipake, knp dijual?
    Quote Originally Posted by CBR 1000 RR View Post
    hu idaman bgt nih
    heheh.. ga kebeli,mksdnya ga sempet beli.. kalo 1 msti minim 2 kontainer..
    6 Hrs 38 Mins 5 Secs
    pm hrg net nya bro?
    thanks bos rafiq,bos cupu n bos golo.......
    emang nich om kevin,si bos gede jemmy belgi aje........
    bos gede jemmy,saya ga sanggup pake hxd-2 yang muluuuuusnya kaya begini,paling dapetnya yang buduk2 aja bos,itu aja nyicil 3 taon bos....he...he..he....
    cek pm bos v@5h.....
    31 Mins 17 Secs
    Bikin ngileerrr.... bantu up aja deh
    2 Days 13 Hrs 1 Min 59 Secs
    paling bisaaa luuu...
    pm dong nett nya.
  1. WTS : CLARION HXD2 (SOLD thx MODCOM)
    By denkris in forum Head Unit & Processor
    Last Post: 29th June 2010, 23:12
  2. Replies: 26
    Last Post: 11th November 2009, 02:44
  3. Replies: 3
    Last Post: 3rd August 2009, 00:54
  4. WTS HI END CLARION HXD2 LENGKAP DUS BUKU-(SOLD>>>>)
    By ric_signature in forum Head Unit & Processor
    Last Post: 25th July 2009, 09:01
  5. pioneer cd-ib100II muluuuuuus dan lengkap...(sold,thanks modcom...)
    By MR.GASOLINE in forum Bursa Audio Lainnya
    Last Post: 10th June 2009, 03:30
