subwoofer hi-end eton 8-800/37 hex kondisi NOS.......(sold,thanks modcom...)
Results 1 to 10 of 14
  • Short URL:  http://modifika.si/121054
    Cool subwoofer hi-end eton 8-800/37 hex kondisi NOS.......(sold,thanks modcom...)
    2pcs subwoofer hi-end eton 8-800/37 hex kondisi NOS.........sold
    eton engineering series 21 cm bass driver with kevlar cone.
    * power handling (continuous/programme) = 120 / 180 W
    * resonance frequency fs = 36 Hz
    * impedance R = 8 Ohm
    * sound pressure level SPL = 89 dB (2,83V; 1m)
    * DC resistance Re = 5,5 Ohm
    * force factor BL = 9,3 N/A
    * voice coil inductance L = 0,75 mH
    * effective piston radiating area Sd = 235 cm2
    * effective mechanical mass incl. air load 31 g
    * equivalent volume of compliance Vas = 45,5 l
    * total Q factor Qts = 0,39 (Qms=2,44, Qes=0,46)
    * maximum peak linear excursion vibration xlin = +/- 3 mm
    * mounting diameter d = 203 mm
    * overall diameter d = 216 mm
    * mounting depth (not countersunk) t = 89 mm
    recommended cabinet 1:
    closed cabinet with 11,7 L volume
    from 74/47 Hz (-3dB/-8dB)
    recommended cabinet 2:
    43 L volume bass reflex cabinet
    with HP100 reflex tube, 30 cm long.
    from 37/30 Hz (-3dB/-8dB).
    call
    081388575788
    up...............
    up..............
    up.................
    up.................
    up...............
    3 Hrs 16 Mins 23 Secs
    slllrruuuppppp.... numpang ngiler sekalian numpang bantuin up ya, bro chris...
    thanks bos nanami....
    sama2, bro chris... sekalian bantu up lagi......
    thanks lagi nich bos nanami...
    he..he..he...
MBtech GT Radial
  1. Replies: 14
    Last Post: 4th March 2010, 08:10
  2. Replies: 21
    Last Post: 13th January 2010, 05:30
