5ch DLS ultimate A7 (the big five) seri tertinggi DLS (sold,thanks modcom...)
Results 1 to 9 of 9
  • Short URL:  http://modifika.si/121051
    Cool 5ch DLS ultimate A7 (the big five) seri tertinggi DLS (sold,thanks modcom...)
    5ch DLS ultimate A7 (the big five) seri tertinggi DLS super muluuuus 98% dan lengkap dus,buku manual,bass control n kabel,bracket n baut.........sold
    retail price: US$ 1499,99
    Descriptions:
    ULTIMATE series A7 Five-channel amplifier rated at 4 x 60 Watts on the stereo channels plus 1 x 300 Watts from the mono sub channel.
    Built to provide a complete in car entertainment system system with all necessary crossovers, all in one amplifier. For detailed information about the crossover possibilities please read the technical specifications.
    Internal switches connects all amplifier inputs if you prefer to use only one RCA cable.
    Built-in fan control. Remote sub level control with phase shift is included.
    - RMS output per channel at 13,8 volts, 20 Hz - 20 kHz , < 0,1% distortion.
    Specification:
    Number of channels 5
    Amplifier class AB
    Output power in 4 ohm 4 x 60 W
    Output power in 2 ohm 4 x 100 W
    Mono bridge mode 4 ohm 2 x 200 W
    Mono sub channel 4 ohm 300 W
    Mono sub channel 2 ohm 440 W
    Mono sub channel output in 1 ohm 600 W
    Frequency range 10 Hz - 50 kHz
    Damping factor > 200
    S/N ratio, A-weighted > 100 dB
    Low level output No
    Input impedance, high level N/A
    High level input with auto start No
    Input sensitivity 0,3 - 7 V
    Input impedance > 10 kohm
    Filters channel A & B HP: 80 - 400 Hz / 1,6 - 8 kHz (x20)
    Filters channel C & D HP: 80 - 400 Hz. LP: 0,3 - 4 kHz / 3 - 40 kHz (x10)
    External cooling fan terminal Yes
    Remote bass level control Yes
    Remote phase shift control Yes
    Power consumption (idle) 1,1A
    Power consumption (max) 120 A
    Rec. power cable Minimum 4AWG / 21 mm2
    Fuses 2 x 35 A + 2 x 20 A
    Dimension (W x D x H) 605 x 240 x 73 mm (23,82 x 9,45 x 2,87 inches)
    Weight 8,1 kg ( 17,86 lb)
    call
    081388575788
    Yogyakarta
    1 Day 11 Hrs 37 Mins 55 Secs
    Wadduh.....Chris.....telat..........kemaren butuh bgt..........Barangnya top!!!!
    yach,telat ya bos?
    udah bos rafiq,beli 1 lagi aja buat koleksi,he...he...he...
    up..............
    up...............
    up...............
    up.............
    1 Day 17 Hrs 59 Mins 27 Secs
    ngiler.. (mode : on)
    Phone CDMA : 021-92930243
    Phone GSM : 08129945462
    thanks bos nin......
  1. JUAL SUB seri tertinggi CRESSENDO 5.12 (V2)
    By copo in forum Speaker - SubWoofer
    Last Post: 16th February 2010, 14:11
  2. Replies: 8
    Last Post: 31st July 2009, 00:51
  3. Replies: 37
    Last Post: 24th July 2009, 02:16
  4. Replies: 7
    Last Post: 10th July 2009, 07:30
  5. FLUX seri tertinggi vs Fabulous FA3
    By mr.pulsa in forum Diskusi Speaker
    Last Post: 1st May 2007, 19:17
