CUSCO LSD for Honda Jazz GD3 M/T (Manual Transmission) *SOLD*
Results 1 to 10 of 19
  • Short URL:  http://modifika.si/120361
    22 Hrs 8 Mins 4 Secs
    For sale CUSCO 1 Way (35 Degree) LSD RS Type (LSD 385 F)
    *3 months used* - EXCELLENT CONDITION (See pictures below) -
    Cusco RS Type LSD, available in 1, 1.5 and 2 ways. This LSD is most suited to the street, whereas the Type MZ is suited to the track.
    Type RS for low initial torque.
    With the Type RS, the initial torque is absorbed by the RS springs therefore the initial torque comes on gently compared to the Type MZ which comes on stronger as it uses cone plates and response of the LSD is better, as the friction is lower.
    *Lower initial torque *Lower power loss *Reacts well to delicate pedal work *Durable and develops initial torque steadily
    The Cusco RS type LSD is designed with low initial torque in order to improve response while reducing clutch plate wear. A chromemoly casing with forged internal components and a unique "through oil system" provide increased durability under severe use.
    One way L.S.D. specially suited for front wheel drive cars and 4WD car front axles.
    Activates under acceleration, and acts as a true LSD when the throttle is off. A great chance for improved lap times.
    A two cam type is available for FWD cars.
    With CUSCO's One Way LSD for FWD cars, you can choose from two angles of activation: 35 degrees or 45 degrees. Angles may be selected on purchase or changed when the LSD is in for maintenance.
    PM for price...
    Parts Ranking in Japan (dapet dari salah satu Speed Shop di Jepang via internet, tau bener apa gak..wkwkwkwk)
    Parts : LSD
    Rank 1 CUSCO
    Rank 2 NISMO
    Rank 3 KAAZ
    Rank 4 TRD
    Rank 5 TOMEI
    Rank 6 ATS
    Om nett price brp?
    Quote Originally Posted by Tanggo View Post
    Om nett price brp?
    PM sent bro..
    1 Wk 1 Day 20 Hrs 28 Mins 28 Secs
    Quote Originally Posted by theddhie View Post
    PM sent bro..
    bos fungsinya utk apa ya? bs psg di swift matic ngk?
    Quote Originally Posted by Nukefire View Post
    Sori, yg ini khusus buat Honda Jazz GD3 Manual bro...
    Parijs van Java
    1 Mth 2 Wks 1 Day 3 Hrs 30 Mins 39 Secs
    tolong di pm harganya bro..
    H3LL
    51 Mins 15 Secs
    Pm net bro..
    Quote Originally Posted by 73617 View Post
    cek PM bro...
    Quote Originally Posted by darkambassador03 View Post
    Pm net bro..
    PM sent bro...
    23 Hrs 55 Mins 16 Secs
    bos pm netnya y...
    ini klo belok ada bunyi bletak bletak ga bos? thanx.
Venom 300x250 GT Radial
  1. Replies: 9
    Last Post: 10th August 2012, 13:28
  2. Replies: 4
    Last Post: 27th March 2011, 16:35
  3. Replies: 6
    Last Post: 26th March 2010, 16:37
  4. CUSCO Strut bar, lower arm utk Honda GE / All new Jazz 1,7jt
    By boedjang.corp in forum Jual Beli Mesin Lainnya
    Last Post: 29th November 2009, 15:34
  5. Replies: 23
    Last Post: 23rd March 2009, 16:44
