ada yang pernah pake power ini ngak... butuh informasi donk.
Results 1 to 10 of 12
  • Short URL:  http://modifika.si/11899
    jak bar
    8 Hrs 19 Mins 2 Secs
    http://www.modupload.com/pics/4cad0fc077b1e0952000d151f0d1916b.JPG
    kasih saran donk... mengenai power ini??? gw mau pasang power ini... bagus ngak ya....?
    http://www.onlinecarstereo.com/CarAudio/ProductReview.aspx?ProductID=12838
    Product Description
    Monoblock subwoofer only amplifier. Liquid Cooling Optional MOSFET output devices, optional remote bass control modules (ELA-BCM).
    Technical Specification
    * RMS Power Range : 500 Watts
    * Number Of Channels: 1
    * Maximum Power: 750 Watts
    * Low Frequency response: 20 Hz
    * High Frequency Response: 250 Hz
    * Built In Crossovers: Yes
    Features
    * Power Output: 500W
    * Frequency Response: 20-250Hz
    * Fuse 60
    * Crossover: yes
    * Protection Thermal, Short Circuit, Overload
    * Max Power Output: 750W
    * Power @ 4 OHM: 500W
    * Power @ 2 OHM: 750W
    * Signal To Noise Ratio 115
    * Battery Voltage Range: 10.5-14.4 volt
    * Bass EQ yes
    * Remote Control optional
    jak bar
    UPS..... ngak ada komentar nih dr para suhu.....
    Administrator
    9 Mths 3 Days 13 Hrs 34 Mins 53 Secs
    jarang yg pake kali yah
    3 Mths 11 Hrs 11 Mins 41 Secs
    namanya kayak senjata
    hahahahaha
    jak bar
    gw ngak gitu ngerti spek... dari speknya gimana menurut kalian bagus ngak....
    Somewhere In The Earth
    4 Hrs 30 Mins 11 Secs
    wah ga tau bos bantu up aja deh
    J - Town
    1 Hr 48 Mins 42 Secs
    no comment...
    Alpine F#1 Status
    LCY K130 Tweeter
    Accuton C886 Midbass
    Scanspeak 23W Subwoofer
    Zelos Full Tube
    ELNA 1.0F Capacitor
    Synergistic Research
    Analysis Plus
    jak bar
    Jakarta Bogor Bandung
    1 Day 20 Hrs 59 Mins 13 Secs
    wah, bazooka..
    Ane sih blum pernah tau bos..
    J - Town
    mungkin bisa mencoba merek lain...
    Alpine F#1 Status
    LCY K130 Tweeter
    Zelos Full Tube
    ELNA 1.0F Capacitor
    Analysis Plus
  1. Replies: 4
    Last Post: 18th February 2014, 01:20
  2. WTA: Ada yang pernah pake atau masih pake ZAFIRA?
    By dirtworkshw in forum Diskusi Otomotif Lain-Lainnya
    Last Post: 10th September 2012, 21:34
  3. tanya donk pengalaman member yg pernah pake HU Avelino
    By b3ll_41r in forum Diskusi Head Unit & Processor
    Last Post: 12th April 2012, 11:03
  4. ada yang butuh alat ini ngak ya? D-E-T-I
    By anekarupa in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 30th June 2010, 09:53
  5. ada yang pernah pake power ini??
    By picanto in forum Diskusi Power Amplifier
    Last Post: 3rd March 2008, 10:20
