White Ferio Spoonsport
Results 1 to 10 of 62
  • Short URL:  http://modifika.si/118132
    8 Hrs 23 Mins 20 Secs
    Suspension System
    Tanabe street spec fix type
    RSR coil spring
    Vision front adjustable chamber arm
    Vision rear adjustable chamber arm
    Vision rear adjustable rear toe arm
    J'S racing roll center adjuster (ball joint)
    Spoonsports wheel 16 x 7
    Bridgestone potenza G III 195/50/16
    Spoonsports wheel lug nut (blue color)
    OEM honda civic type R rear anti roll bar/rear stabilizer
    Body Reinforcement
    Tanabe front strut bar
    OEM honda civic EK4 front chassis bar
    J'S racing inner fender bar
    Tanabe rear strut bar
    Alex trunk bar
    Sergeant rear chassis bar
    Tanabe front lower arm bar
    Tanabe rear lower arm bar
    Do-luck rear cross bar
    Brake system
    Brembo max front slotted rotor
    Ferodo front brake pad
    Ferodo rear brake pad
    APP brake hose
    Spoonsports reservoir tank cover
    Cusco master cylinder brake stopper
    Intake & exhaust
    Spoonsports air cleaner & HKS hybrid air filter
    Spoonsports carbon fiber direct air flow pipe
    Billion thermo cloth
    4-2-1 kansai sports exhaust manifold system (dari header sampai sebelum muffler)
    Buddyclub racing spec IV muffler (silent type)
    Power Unit
    P2J D15B cylinder head (SOHC 3 stage VTEC) with dual VTEC solenoid
    Cometic 2 ply thin head gasket
    Cusco oil catch tank
    Spoonsports magnetic drain bolt set
    P2J D15B injector
    Buddyclub volt stabilizer & ground wire
    Carbing radiator cooling plate
    Mugen reservoir tank cover
    Pivot spark earth
    Pivot ignition earth
    Pivot raizin spark type S
    Pherma cool oil cooler 150 HP remote type
    Apexi AFC neo
    Buddyclub oil cap
    J'S racing engine torque damper
    Tein engine hood damper
    Silver's max power fuel magnetic system
    Silver's air power
    NGK power cable
    HKS super fire racing spark plug
    Sard silicone hose
    Drive train
    OEM honda LSD kit
    Spoonsports clutch slave hose
    Buddyclub quick shifter
    OEM honda civic estillo EG6 flywheel
    Cooling system
    Billion radiator hose set
    Spoonsports radiator stay
    Buddyclub radiator cap
    Spoonsports thermoswitch
    Spoonsports thermostat
    Spoonsports heat barrier tape
    Greedy breather tank set
    Interior & exterior
    Spoonsports steering wheel
    HKB steering boos kit
    Triple Z quick release
    Spoonsports shift knob (duracon type)
    Mugen pedal set
    Carbing foot rest
    Custom honda floor mat
    OEM honda civic type R EK9 shift boot red stiching
    Pivot 5 in 1 gauge
    Apexi RSM + G sensor
    OEM honda S2000 engine start button
    Mugen rear wing
    Modulo honda access rear spoiler
    Modulo honda access front spoiler
    Modulo honda access door side visor
    OEM honda civic type R EK9 front grill
    OEM honda stream fog lamp + switch
    @ Corolla ZRE143
    6 Hrs 34 Mins 16 Secs
    PERTAMAX!!!
    Wahhh Sendok!!!
    Ajibb euy liat sendok..
    mantaphhh bos teruskan..
    MAmpir bos ke GD3 saya...
    bintaro
    1 Mth 15 Hrs 11 Mins 36 Secs
    "GILA"
    gw ampe ngerasa malu ngeliat ferio gw
    well done bro.
    ホンダモータースポーツ
    bintaro
    btw P2J 3 stage vtecnya dapet berapa HP nih broer.
    ホンダモータースポーツ
    http://www.modifikasi.com/showthread.php?t=112526
    5 Days 22 Hrs 14 Mins 53 Secs
    wow..
    manteb nh boss ferio nya!
    brp hp nh??
    plat R
    2 Days 7 Hrs 1 Min 47 Secs
    wiw manteb bener om...
    Blm tahu boss , pasangnya di bengkel ndeso blm punya dyno test ..he..hee
    ID Ini Dicurigai Melakukan Penipuan
    Saarbrücken
    4 Days 22 Hrs 29 Mins 45 Secs
    da cukup cakep bosss..
    Sebagian ada yg blm terpasang , masih harus banyak belajar dr temen2 Modcom ........ Tengkiu
    4 Hrs 8 Mins 20 Secs
    wuaahh..
    mantab bos ferionya..
    mirip ama punya temen saya di sby,hee..
    btw, velg SPOONnya replika ato asli?
    overall..nice..
  1. jdm•garage : plate japan [ ..95 ] spoonsport !! 1pc sale murah!
    By renzv in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 15th January 2014, 12:02
  2. Replies: 150
    Last Post: 30th April 2013, 12:59
  3. WHITE CIVIC FERIO
    By speedfreaks in forum Honda
    Last Post: 13th March 2013, 01:52
  4. WTS : WHITE FERIO SPOONSPORT
    By bangsatsat in forum Merk Lainnya
    Last Post: 29th January 2011, 09:41
