SOLD Rare BMC Carbon Air Filter for BMW E39 5 series
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/117782
    1 Wk 1 Day 14 Hrs 40 Mins 32 Secs
    SOLD SOLD thx modcom
    Jual Air FIlter Carbon BMC + Piping utk BMW seri 5 E39 .
    Kondisi seperti baru , dipake ga lebih dari 50km saja.
    Buat yg belom tau , BMC bikin air filter utk mobil2 formula 1/balap. Konsepnya aliran udaranya masuk dari depan ke box air filter dr bahan carbon. Kenapa pake carbon supaya udara yg masuk ke intake tetep dingin
    Lubang Aliran udara didepan supaya udara lebih lancar masuknya.
    Beda dgn model open air filter yg bikin ngempos diputaran bawah.
    CMIIW....
    See to believe..
    harga? email : koolrider@telkomsel.blackberry.com
    FACTS about BMC Filters:
    There Are 2 Reasons Why Formula 1 Choose BMC Over K&N
    BMC Air Filters are designed and manufactured in Italy and were oringinally developed in assocaition with the Ferrari F1 Team. They are now used by 8 out of 11 F1 Teams
    Since 1996, BMC Air Filters have equipped some of the most important teams in F1 and Le Mans including Ferrari, BMW, Mercedes Benz, Toyota, Porsche, Bentley and Audi.
    BMC Air Filters involvement in a large number of championship wins in V8 Supercars, Formula 1, 24 Hours Le Mans and the American Le Man Series, prove that BMC Air Filters provide the best performance even in extreme conditions
    The BMC Filtration Systems give better engine performance, both in power and torque.
    Why You Should Change Your Factory Standard Filter
    The core function of an air filter is to supply clean air to the engine by reducing the amount of dirt that gets into the engine.
    Common types of factory standard filters include paper and foam
    Paper and foam filters are cheap but tend to have only a short life time, are turbulent and allow for only a low airflow volume and poor filtration, which causes a loss of power and fuel economy
    What Is It Made From ? How Does It Work ? When Do I Clean It ?
    Unique Filtering Element: 4 Ply special cotton gauze is soaked in specially formulated oil which is sandwiched between 2 aluminium nets which are treated with an epoxy coating.
    This unique filtering element traps event the most minute particles ensuring maximum protection from dirt particles, petrol fumes and oxidisation while allowing for maximum airflow
    Unique "Full Moulding" support to hold the filter: BMC Air Filters are made using a system called "Full Mould" single stamping with red
    Polyurethane rubber.
    With this unique support, there are no joins that can cause breakages or deformation and the air filter fits perfectly into the air box shape. It is also highly heat resistant with superior sealing
    The unique construction of the BMC Air Filters results in both increased POWER and FUEL ECONOMY.
    Cleaning and re-oiling with BMC washing kits will ensure the extra long life span of a BMC Air Filter. The necessity for washing and re-oiling is dependant on the road/track conditions. For dusty Indonesian roads, a servicng interval of approximately 25,000 km will ensure continued optimum performance.
    like new..............
    ini bisa untuk bmw e46 gak?
    Quote Originally Posted by bluemonyet View Post
    Klo yg 6 silinder sepertinya bisa
    1 Wk 4 Days 3 Hrs 10 Mins 52 Secs
    ini bisa untuk e36 yang 6-cylinder ga yah?....tolong pm harga nett nya bro...kebetulan lagi nyari juga...
    bump....... bump.................
    4 Days 15 Hrs 25 Mins 20 Secs
    jual brp bos?gw sih pake e46 325, bs ga y?
    Quote Originally Posted by L_2636 View Post
    mesin BMW 6 cyl IL bisa bos
    bump up.........
    bump it up
  1. WTS:filter KN&N carbon+selang KN&N rare item
    By wellyge8 in forum Jual Beli Mesin Lainnya
    Last Post: 31st January 2012, 13:18
  2. (SOLD) WTS : air filter ferio+box cover carbon (SOLD)
    By M 0 dif in forum Jual Beli Mesin Lainnya
    Last Post: 8th July 2010, 12:15
  3. WTS==> Replacement Air Filter Livina series SOLD !! THNX MODCOM
    By maestro in forum Jual Beli Mesin Lainnya
    Last Post: 31st August 2009, 22:36
  4. WTS:Open Air Filter Simota carbon yaris(SOLD)
    By fahminurrahman in forum Jual Beli Mesin Lainnya
    Last Post: 17th August 2008, 03:18
  5. FS : Air Filter Carbon Simota Civic...2nd(SOLD OUT)
    By BL4CK_50UL5 in forum Jual Beli Mesin Lainnya
    Last Post: 5th April 2008, 21:32
