WTS : Scanspeak 12M Midrange
Results 1 to 10 of 59
  • Short URL:  http://modifika.si/117743
    2 Mins 52 Secs
    Sesuai Judul :
    PM or SMS 081 651 9999
  2. Jayapoker
    city of heroes
    2 Hrs 59 Mins 7 Secs
    net brp bos?
    PM yah!
    2 Mins 52 Secs
    Buat yang pada nanya, speakernya used bukan baru, nanti gue di ban lagi
    16 Mins 14 Secs
    Yg ini diameter brp ya Bro? boleh dong minta pm harga super nett , thanks.........
    1 Wk 5 Days 18 Hrs 15 Mins 35 Secs
    Quote Originally Posted by sadikit alon View Post
    sama ama yang diatas, harganya donc
    2 Mins 52 Secs
    Ini specnya dari Madisound, orang sini sih bilang 4", tapi specnya 4.5" :
    Scan-speak Revelator 4.5" Midrange
    The 12M/4631G is a Revelator driver using the “slit cone" technology. Some of the slits are used to control cone resonance and the other set of slits add rigidity. This speaker also has the new dynamic linear suspension for lower compression and higher linearity. Every facet of this driver is designed to reduce resonance in all structures. A neodymium magnet has been chosen to reduce the depth, yet increase the magnetic energy. The short field length of a neodymium magnet also allows this driver to by used for A/V.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 89dB
    Free air resonance Fs 75 Hz
    DC resistance 3.2 W
    V.C. inductance 0.22 mH
    Power 40W
    Effective cone area 49 cm2
    V.C. diameter 38 mm
    V.C. height -
    Air gap height -
    Lin. & max. excursion 3/ 7 mm
    Air gap flux density -
    BL 5.3 Tm
    Moving mass incl. air 6.5 g
    Net weight 0.51 kg
    Outside diameter: 115.5mm
    Cut out: 92mm
    Depth: 48.4mm
    25.4mm = 1" = 2.54cm
    2 Mins 52 Secs
    PM sent, check inbox
    5 Days 4 Hrs 44 Mins 10 Secs
    lho bos, kapan belinya? :smt003
    JOIN THE UnSCAC'S!!!!
    New Avexis FU6s on:
    E-MAIL: unscac@yahoo.com
    Whatsapp, Cell : 082141139097
    Line: Hwely
    Please DON'T sent via PM!!!
    pedalaman
    19 Hrs 3 Mins 19 Secs
    PM net n lokasi, thanks
    2 Mins 52 Secs
    Quote Originally Posted by denkris View Post
MBtech Venom 300x250
  1. MIDRANGE 12W4434 SCANSPEAK TERBARU
    By shark in forum Diskusi Speaker
    Last Post: 13th August 2012, 22:26
  2. WTS like New, midrange Seas Lotus RM 120 M + Sub Scanspeak 23W
    By ric_signature in forum Speaker - SubWoofer
    Last Post: 7th March 2011, 12:09
  3. FS : MIDRANGE SCANSPEAK 12M/4631G00
    By mokosaurus in forum Speaker - SubWoofer
    Last Post: 3rd January 2011, 21:30
  4. [SOLD] Midrange Scanspeak 10 F
    By seraphim in forum Speaker - SubWoofer
    Last Post: 1st May 2010, 13:06
  5. Midrange baru: Scanspeak 10F
    By UnSCAC in forum UnSCAC- Hwely Audio
    Last Post: 29th December 2009, 22:02
