WTS > SHURE SCL2 Sound Isolating Earphone
Results 1 to 8 of 8
  • Short URL:  http://modifika.si/117266
    20 Hrs 43 Mins 18 Secs
    Smile WTS > SHURE SCL2 Sound Isolating Earphone
    Dear All,
    sesuai dengan judul, WTS> Shure SCL2 Sound Isolating Earphone
    Brand New In Box, Price List-nya : 830-850rb-an [U$79]
    Saya Jual dengan harga -SOLD-
    yg berminat bisa menghubungi :-SOLD-
    Thanks In Advance
    - Sound Isolating Sleeves
    Because every ear is different, the Fit Kit includes three sizes (S, M, L) of the orange foam, clear and gray flex sleeves. Experiment with the size and style that creates the best fit for you -- a good seal is key to optimizing sound isolation and bass response as well as maximizing comfort during extended wear.
    - Carrying Case
    A durable and compact carrying case is included with the SCL2 to provide a convenient, tangle-free solution to store your earphones.
    - Wax Removal Tool
    If you notice a change in sound quality, remove the sleeve and check the nozzle of your earphone. If nozzle is blocked, clear obstruction by using wire loop end of cleaning tool.
    Frequency Range: 22Hz – 17.5kHz
    Sensitivity: 105dB SPL/mW (@ 1kHz)
    Impedance: 16 Ohms (@ 1kHz)
    Weight: 30g (1oz)
    Input Connector: 3.5mm (1/8”)
    Color Options: Black (-K), Clear (-CL)
    Cable Length: SCL2-K: 141 cm (56”), SCL2-CL: 157 cm (62”)
    http://www.shure.com/ProAudio/Produc...o_SCL2_content
    Sound Isolating Technology
    Sound Isolation Demo
    Hear how Sound Isolating Earphones block out more real-world noise than noise cancelling headphones in the Shure Virtual Sound Lab.
    http://www.shure.com/groups/public/@...dlab_html.html
    Why sound isolating earphones?
    Sound isolating earphones provide sound quality far beyond the technical ability of the most expensive earbuds and isolation that's superior to the best headphones. By creating a secure fit between the sound source and your ear canal, unwanted background noise is blocked out while the music comes straight in.
    How are Shure's sound isolating earphones different from other headphones?
    The primary difference is their listening position - where they are worn in relation to your ear. Headphones generally enclose your ear or rest on top of it. Regular earphones (like the earbuds often packaged with CD players) sit on the outside of the ear. Sound isolating earphones are different. They are designed to fit inside your ear canal, where they create an isolated listening area that is responsible for their superior acoustic properties.
    How do in ear sound isolating earphones work?
    By selecting from an assortment of included soft, flexible sleeves, you're able to personalize the fit of the earphones to your ears. The sleeves conform to the unique shape of your ear, creating a seal that isolates you from ambient noise.
    Why is isolation important?
    Sound isolation makes it possible to hear greater detail at a lower volume than is possible with earbuds or most headphones intended for portable use. Lower-volume listening means less fatigue over extended periods and is safer than trying to overcome background noise by turning up the volume. This makes sound isolating earphones the ideal choice for commuting, travel, exercise, study, or work - any activity where you desire portable, hi-fidelity sound.
    What are sound isolating earphones?
    Sound isolating earphones were originally developed as Personal Monitor Systems to allow musicians to hear their own performances in loud onstage environments. Sound isolating earphones work by using soft, pliable sleeves to block background noise, allowing small, high-performance drivers to deliver incredibly precise sound directly to the ear. These professional-quality earphones are now available for use with all of your portable digital devices.
    Is isolation different from noise cancellation?
    The seal created by a sound isolating earphone physically blocks most frequencies of background noise. Active noise cancellation "headphones" are generally larger, heavier and battery-driven. The active cancellation process negates selected frequencies through a complex process that can even introduce unwanted artifacts into the resulting audio. The natural sound isolation properties of a properly fitted in ear earphone exceeds the performance of even the most expensive active noise cancellation alternatives.
    Jakarta Selatan
    1 Wk 4 Days 23 Hrs 49 Mins 31 Secs
    barang baru apa 2nd nih?
    Karma does exist
    Thumbs up Brand New In Box
    Quote Originally Posted by letnan_poppy View Post
    Brand New In Box boss =)
    berminat ?
    barang tinggal 1 bos =)
    Thanks.
    Thumbs up
    Upz... Upz... Upz...
    Thumbs up
    Upz....
    sebelom bobo
    Bumpz...
    Bumpz...
    BumpZ...
    BumpZ...
    Cool -L A K U-
    -SOLD-
    Thanks ModCom
  1. WTB:Shure Earphone 535
    By Detailling_addict in forum Diskusi Audio Lainnya
    Last Post: 10th December 2011, 08:36
