SUB DLS (sold)
Thread: SUB DLS (sold)
  • Short URL:  http://modifika.si/117127
    surabaya
    SUB DLS (sold)
    Di jual santai aja sub dls mw 12D (2nd)...kondisi istimewa,harga 950 rb..,tertarik silakan PM,sms hub: 081703019551.... COD SBY...kalo d luar sby ongkos kirim d tanggung sendiri ya....
    gambarnya...
    speknya....:
    MW12 is a 12" subwoofer in REFERENCE magnesium series with die cast basket. Magnesium one cone body. Dual spiders and dual magnet system.
    Speaker type : Subwoofer
    Impedance : 4 ohm
    Size : 12" (30 cm)
    Power handling capacity : 400 W RMS / 600 W max
    Frequency range : 20-2000 Hz
    Sensitivity : 91 dB (1W/1m)
    Magnet size : 180 mm (7,1"), 140 oz
    Outer diameter : 310 mm (12,2")
    Installation depth : 142 mm ( 5,59")
    Mounting hole : 282 mm (11,1")
    Weight : 8,9 kg (19,6 lb
    X-max : +- 9 mm (0,35")
    Fs: 31,7 Hz Re: 3,57 Qes: 0,24 Qms: 2,14 Qts: 0,21 BL: 18,94 Vas: 60,2 l (2,12 cuft)
    Recommended vented enclosure : Volume 32 liter/1,13 cuft, Port: 4" diameter with length 37 cm/14,5". F3= 49,1 Hz
    Recommended sealed enclosure : For best result, use vented enclosure
    Recommended bandpass enclosure: Speaker in Vb1, playing into Vb2 where the ports are. The port fully inside the box. If you want to install the port more or less on the outside, the volume of Vb2 must be reduced with this volume (the volume of the port that is on the outside of the box).
    Vb1: 27,02 lit/0,95 cuft Vb2: 18,18 lit/0,64 cuft Port Vb2: 3 x 3" tube Tube length: 20 cm/7,8"
    All given volumes in the examples are for one (1) subwoofer.
    surabaya
    up................................
    jakarta selatan
    2 Days 4 Hrs 10 Mins 5 Secs
    SUB DLS MW12
    ro tawar 750 ribu ..ke jakarta boleh ? thx
    kabarin 0813-80799600
    H.U : ALPINE 9853
    Front : DLS UR6S
    Rear : DLS C426
    Sub : JL 10' W1V2 x 2
    Power : Phoenix Gold M440/ XTR Monoblok
    Gadget : IPOD Video + KCA 420i
    surabaya
    sold....................
    thx modcom........
GT Radial MBtech
  1. Replies: 37
    Last Post: 30th April 2010, 12:49
  2. Replies: 40
    Last Post: 19th April 2010, 21:12
  3. Replies: 65
    Last Post: 22nd December 2009, 16:06
  4. Great OFFER TURBO KIT D-series HONDA SOLD SOLD SOLD SOLD OSLD SOLDSOLD SOLD SOLD
    Last Post: 21st September 2008, 14:58
  5. WTS AURFA coilover (HONDA FD1/newcivic)SOLD SOLD SOLD SOLD SOLD SOLD SOLD
    By autofever.starlet ep70 in forum Bursa Kaki Lainnya
    Last Post: 12th July 2008, 22:33
