JL AUDIO 300/4 kondisi no service...............(sold,thanks modcom....)
  • Short URL:  http://modifika.si/117055
    Cool JL AUDIO 300/4 kondisi no service...............(sold,thanks modcom....)
    JL AUDIO 300/4 kondisi no service.................sold
    Specifications:
    # Rated Power (stereo): 75 W RMS x 4 @ 1.5 ohm-4 ohm (11V-14.5V)
    # Rated Power (bridged): 150 W RMS x 2 @ 3 ohm-8 ohm (11V-14.5V)
    # THD at Rated Power: <0.03% @ 4 ohm
    # S/N Ratio*: >108.5 dB below rated power
    # Frequency Response: 5 Hz-30 KHz (+0, -1dB)
    # Damping Factor: >200 @ 4 ohm per ch./50 Hz
    # Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
    # Dimensions: 13.4"L x 9.25"W x 2.36"H
    # Differential-Balanced Input Topology: (2 pairs of inputs)
    # Front Crossover: fully-variable (50 Hz-5 KHz),
    # selectable-slope LP or HP (12 or 24 dB per octave)
    # Rear Crossover: fully-variable (50 Hz-5 KHz)
    # Speaker output connections: accept up to 8ga. wire +12V
    # Ground connections: accept up to 4ga. Wire
    call
    081388575788
    up..................
  1. Replies: 14
    Last Post: 4th March 2010, 16:14
  2. Replies: 2
    Last Post: 31st December 2009, 10:34
  3. Replies: 142
    Last Post: 20th November 2009, 01:26
  4. Replies: 9
    Last Post: 7th September 2009, 13:36
  5. Replies: 74
    Last Post: 9th August 2009, 18:39
