2pcs xtant monoblock audiophile class 1.1i (sold,thanks modcom..)
Results 1 to 10 of 74
  • Short URL:  http://modifika.si/117032
    Cool 2pcs xtant monoblock audiophile class 1.1i (sold,thanks modcom..)
    2pcs xtant monoblock audiophile class 1.1i kondisi muluuus no service...............sold
    new price $349/pc
    Specifications :
    Number of Channels 1
    Watts per Channel 4 Ohm 1 x 100
    # Watts per channel 2 Ohm 1 x 100 Distortion <1% THD Measured at 20-20KHz at rated power all channels driven
    # Signal to Noise Ratio >100dB A-Weighted in 20KHz
    # Frequency Response 17Hz-21KHz +0, -2dB
    # Input Sensitivity 100 mV - 8.5V Unbalanced, 200 mV-17V balanced
    # Operational Voltage 10-16V
    # Dimensions 6.5 L x 5.81" W x 1.63" H
    # Fully Regulated PWM power supply
    Requires 10A Fuse
    "Small wonder: At a svelte 6 x 1 5/8 x 5 inches, it isn't much bigger than your typical CD jewel case - diminutive enough for such hideaway mounting positions as under the dash, under a seat, in a glove box, or even in a center console."
    -Mike Mettler, Editor in Chief, Mobile Entertainment Magazine as seen in Sound & Vision Magazine, May 2003
    AUDIOPHILE FULL SPECTRUM CLASS D TECHNOLOGY
    The Xtant1.1i adds local and global multiple nested feedback loops with premium MOSFETs and OPAmps for switching stability and audio signal accuracy within the full range spectrum. This results in an extremely high switching speed—over 1MHz.
    Because the switching speed is over 1MHz, we are able to set the output filter frequency high enough to avoid any phase related distortion within the higher frequency range of the audio signal. This enhances the musical reproduction by ensuring the higher frequencies (cymbals and the like) compliment the entire frequency range to bring new realism to the Class D amplifier sound experience.
    The Audiophile Full Spectrum Class D Technology with Xtant’s attention to detail results in a Class D amplifier that sounds better than many audiophile Class A/B amplifiers. It exhibits an extremely low noise floor eliminating the “hiss” common to many Class D amplifiers. The improved dynamic range enables the accurate reproduction of every loud and quiet passage within the musical range. This makes the amplifier exceptionally suited for musical and theater applications.
    Features
    * Xtant amplifiers feature a Fully Regulated, Pulse Width Modulated power supply. This power supply technology provides high efficiency and consistent output performance even when battery voltage is less than optimum.
    * The Balanced input circuit increases common mode noise rejection and eliminates ground loop noise while allowing for 100mv to 17 volts of signal input. This circuit also makes interfacing with any factory head-unit easy.
    * Both Thermal and Overcurrent protection are incorporated into Xtant amplifiers. In the event of a problem, the amplifier will reduce its power to maintain operation.
    * These small footprint mono-block amplifiers are ideal for vehicles that have limited space and allows for unlimited installation creativity in any application. The mono-block concept also allows for easy audio and/or video system configuration (2-, 3-, 4-, 5-, 6-, or 7-Channel).
    http://www.modifikasi.com/pb/s-i707/f-albums/ww73/mr_gasoline/Xtant11i.jpg
    call
    081388575788
    Jakarta nieh..!!
    1 Mth 1 Day 10 Hrs 46 Mins 2 Secs
    loh koq jadi mR GASOLINE..??
    LoweringKit 2nd..
    GSM : 0878 800 36000
    di banned gara2 audison bit1 99,9999999% bos codot,he..he..he....
    up.................
    up...................
    u.p.............
    up..............
    up..............
Venom 300x250 Tekiro
  1. Replies: 9
    Last Post: 18th March 2010, 20:12
  2. Replies: 14
    Last Post: 6th January 2010, 10:13
  3. Replies: 152
    Last Post: 26th November 2009, 22:31
  4. Replies: 104
    Last Post: 19th October 2009, 03:19
