--selling-- KSPORT COILOVER KIT
Page 1 of 35 12345 ... LastLast
Results 1 to 10 of 345
  • Short URL:  http://modifika.si/116815
    1 Wk 3 Days 2 Hrs 57 Mins 1 Sec
    K SPORT COILOVER KIT
    Website:
    www.ksportusa.com
    www.ksport.co.uk
    ---> Harga KSPORT Coilover Kit Type Street Mulai dari 8,5jt-11,5jt
    Tentang Coilover Kit KSPORT:
    - 1 set 4 buah shock breaker depan & belakang + 4 buah per depan dan belakang
    - bisa adjust/setting tinggi & rendah (manual dengan kunci khusus)
    - bisa adjust/setting keras & empuk sebanyak 36 klik settingan (manual dengan alat khusus)
    - perlengkapan dalam 1 set termasuk 2 buah kunci untuk setting tinggi rendah dan 4 buah kunci untuk setting keras empuk)
    - materialnya terbuat dari bahan berkualitas alumunium 6061 dengan tingkat kekuatan alumunium T6
    - untuk beberapa tipe kendaraan akan dilengkapi dengan pillow ball uppermount untuk penyetelan sudut kemiringan/chamber roda
    Sedikit Lebih Jauh Tentang KSPORT:
    Ksports Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. Made from high quality 6061 Aluminum with T6 for increased hardness.
    Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
    Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
    The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavitations are a lot less common in a Monotube design, which results in a better ride.
    The Ksport control Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
    1. 36 levels of adjustable dampening
    2. Made from high quality 6061 aluminum with T6 for increased hardness
    3. Compression/Rebound adjustable
    4. Adjustable spring perch for height adjustment
    5. Adjustable body allowing maximum suspension travel
    6. Pillowball top mount with adjustable camber (not available for some models)
    7. Monotube high pressure design reduces oil leakage
    8. Electroplated body for protection from corrosion and rust
    9. One year limited warranty
    waiting orders from you guys..
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    jakarta-bandung-semarang,jauh euy..
    3 Days 9 Hrs 10 Mins 6 Secs
    pak bos mau tany..kalo buat greco kena brp ya??di PM in aja pak bos kl boleh..nuhun...
    in the middle of nowhere
    untuk honda accord cielo nett brp?
    5 Hrs 41 Mins 35 Secs
    jazz gd 3 brapa bos?ini barangnya baru ya bos?pm yahh...
    50 Mins 26 Secs
    Bos, klo utk Mitsubishi Ck4 thn 2000 berapa duit bos? pm yah, Thanks
    Quote Originally Posted by xthan View Post
    harga nya sekitar USD985 bos..
    CP : Coki Siboro
    Quote Originally Posted by wiblacksono View Post
    harga nya sekitar USD965 bos..
    CP : Coki Siboro
    Quote Originally Posted by sles_o_em_ge View Post
    iya dong barangnya baru bos..
    kebetulan saya masih ada stock bos.. harganya 9,5jt. thx
    CP : Coki Siboro
    Quote Originally Posted by evo4_85 View Post
    utuk CK4 di ksport gak ketemu bos..
    kalo lancer tahun 2000 yg ada CJ4A dari tahun 97-01 gak tau deh sama gak ke CK4.
    kalo iya bisa, harganya USD965.
    CP : Coki Siboro
    1 Day 34 Mins 36 Secs
    Kalau Buat Camry G6,2008 ( toyota ) berapa?
Venom 300x250 MBtech
  1. [selling] KSPORT Big Brake Kit
    By coki.de auto in forum Bursa Kaki Lainnya
    Last Post: 6th December 2014, 07:39
  2. [selling] Coilover Kit KSPORT
    Last Post: 3rd December 2012, 18:36
  3. FS::: Ksport Kontrol Pro Coilover V2.2 Golf GTI Mk5
    By roadstaz in forum VolksWagen
    Last Post: 5th December 2011, 11:36
  4. --.WTS.-- KSPORT Coilover Kit Honda New Jazz GE8
    Last Post: 31st May 2009, 01:09
