SOLD-- KSPORT Coilover Kit Honda Jazz GE8--SOLD
Page 1 of 5 12345 LastLast
Results 1 to 10 of 46
  • Short URL:  http://modifika.si/116812
    1 Wk 2 Days 19 Hrs 34 Mins 22 Secs
    KSPORT KONTROL PRO COILOVER KIT FOR HONDA NEW JAZZ GE8
    Ksports Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. Made from high quality 6061 Aluminum with T6 for increased hardness.
    Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
    Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
    The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavitations are a lot less common in a Monotube design, which results in a better ride.
    The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
    1. 36 levels of adjustable dampening
    2. Made from high quality 6061 aluminum with T6 for increased hardness
    3. Compression/Rebound adjustable
    4. Adjustable spring perch for height adjustment
    5. Adjustable body allowing maximum suspension travel
    6. Monotube high pressure design reduces oil leakage
    7. Electroplated body for protection from corrosion and rust
    8. One year limited warranty
    Price: SOLD..!!!
    Minat??? Sekarang mesti order lagi..
    Call,
    Coki - de Auto Motorsport
    CDMA: 021.9866.1978
    GSM: 0815.1330.1978
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
  2. Autopro
    naikin terus sampe laku..
    CP : Coki Siboro
    naikin lagi...
    CP : Coki Siboro
    naikin lagi biar keliatan..
    CP : Coki Siboro
    CP : Coki Siboro
    CP : Coki Siboro
    1 Day 13 Hrs 46 Mins 19 Secs
    boleh tau dong oom harganya
    Quote Originally Posted by speedy66 View Post
    9,750,000 rp bos.
    CP : Coki Siboro
    surabaya aja
    6 Mins 10 Secs
    kalo buat estilo ada bos? nyampe berapa ya? trims
    Quote Originally Posted by sienbe View Post
    ada, tp by order bos..
    harga nya sekitar USD950an.
    kontak langsung hp saya aja bos kalo minat, nomornya di signature dibawah ini.. thx
    CP : Coki Siboro
  1. Replies: 90
    Last Post: 18th May 2013, 17:12
  2. Replies: 12
    Last Post: 19th March 2011, 02:36
  3. Replies: 94
    Last Post: 31st January 2010, 23:30
  4. --.WTS.-- KSPORT Coilover Kit Honda New Jazz GE8
    By coki.de auto in forum Bursa Kaki Lainnya
    Last Post: 31st May 2009, 02:09
  5. WTS AURFA coilover (HONDA FD1/newcivic)SOLD SOLD SOLD SOLD SOLD SOLD SOLD
    By autofever.starlet ep70 in forum Bursa Kaki Lainnya
    Last Post: 12th July 2008, 23:33
