No.1 WORLD SPL SUBWOOFER
Results 1 to 10 of 79
  • Short URL:  http://modifika.si/116734
    PIN: 28C74CA7 HP:08112509829
    2 Days 22 Hrs 30 Mins 11 Secs
    Butuh biaya belajar SQ...jual pusaka SPL
    Rada2 sayang karena set ini cuma ada 1 di Indo
    HAND MADE SUBWOOFER
    -videonya DDZ: http://www.emssiweb.com/tv-emssi.php?v=131
    -midbass nya (ini baru midbass) : http://www.youtube.com/watch?v=QV2eZY7NKCo
    WORLD RECORD 180.5db by ALLAN DANTE
    World dB drag SPL records:
    * 2007
    o 180.5 dB, Alan Dante's concrete filled Volvo with a single Digital Designs 9918Z 18" subwoofer (3" dual voice coil 0.5 ohms) and four Stetsom 7KD amplifiers (26 kW) and fifteen Powermaster 16V batteries and a 61 Hz sine signal source.
    * 1998
    o 172.2 dB, Alma Gates' Bronco has 64 PPI Pro 10" drivers and 32 PPI PC2350 amplifiers (45 kW). The 1" thick plate glass windows have survived 172.8 dB. Her signal source is track 61 on the dB jams CD, which is a 39 Hz Triple Tone Burst (unclipped sine, 50%, 100% clipped square) which was then ran thru a tripling gimzo to generate a 117 Hz tone. From the outside, Alma Gates' Bronco was described as like "metal being beat to death, it sounds like a machine gun or something." Rumor is that she is adding another 20 PPI 10" subs.
    o 171.3 dB, 2nd place, Jeff ???, 12 Stroker 15D2's and 7.2 kW of power, only 0.9 dB behind team Gates with a fraction of the drivers and wattage.
    1sub DDZ (9912)
    2 monoblok DD Z1a
    Review:
    The Z1a makes incredible amounts of power from stock electrical systems; it was designed to make the most power from limited current supplies. The high efficiency comes from paying close attention to every stage through the amp circuit. Multiple power supplies, high speed controller chipsets, efficient power devices and precise thermal management were key to the Z1a design.
    These attributes make the Z1a at home in world record spl cars or high powered subwoofer systems where 400 pounds of battery bank aren’t possible. One Z1a amp can power several big-time subwoofers to stupid loud levels when called upon, or dazzle with rock solid control of complicated bass lines. Z1a's are limited production, high-end amplifiers for customers who want the best.
    Sub Spec:
    Series Z
    Voice Coil Diameter..................76.2mm
    Magnet Weight.......................7 kilotons
    Power Handling RMS/Music/Peak...if you need to ask...
    Suspension............................check
    Nominal Impedance..................various
    DC Resistance........................ditto
    Sub DDZ12 / 9912 berapa watt ???
    baca ini aja, cuma beda size conus:
    Alan Dante from Lorton, Virginia, set a new world record on August 31st in a dB Drag competition with a 180.5dB peak using a single Digital Designs subwoofer. Dante’s concrete filled Volvo contained a Digital Designs 9918Z 18″ subwoofer receiving 26,000 watts of power from four Stetsom 7KD amplifiers.
    lebih jelasnya baca: http://futuremusic.com/blog/?p=1879
    CALL/SMS 085290734107
    # INI BUKAN BARANG ECEK2 YG BERHARGA MURAH !
    #NB: SIAPKAN KACA CADANGAN !!!
    BISA TT dengan barang SQ
    u p
    Bali
    1 Hr 24 Mins 45 Secs
    bantu up boozz...
    biar cepet laku
    1 Day 16 Hrs 53 Mins 28 Secs
    wew brg mantap nih..
    baca reviewnya aja serem..
    Quote Originally Posted by bomber View Post
    bantu up boozz...
    biar cepet laku
    thx bro bomber
    Quote Originally Posted by 1501VT View Post
    lbh serem yg nawar seharga braxton
    Jakarta nieh..!!
    4 Wks 22 Hrs 2 Mins 17 Secs
    whiawihaihwhiahiwa..barang gini seharga braxton sieh udah banyak yang pake..wkakwakwakwkawkakwa..
    LoweringKit 2nd..
    GSM : 0878 800 36000
    Quote Originally Posted by codot View Post
    kl brax ama braxton kesleo lidah sih masih maklum
    malah ada yg bilang gini: "OK pak, ntar ditanyain dulu ke installernya apa bener wattnya segitu" :eek:
    Jakarta nieh..!!
    wkakwakwakwakwakwakwawa..installernya aja blum tau ini barang..hihiehiaehiahiehiae...
    barang RARE bgini..!!!!!
    LoweringKit 2nd..
    u p
Venom 300x250 MBtech
  1. [PIC] police car around the world...
    By kambingbiru in forum Diskusi Otomotif Lain-Lainnya
    Last Post: 27th June 2015, 04:41
  2. The world most expensive...
    By kambingbiru in forum Automotive
    Last Post: 21st May 2009, 19:18
  3. WORLD DUMBEST
    By redbimmer323i in forum Automotive
    Last Post: 26th November 2008, 17:01
  4. THE BEST HID IN THE WORLD??
    By AP in forum Diskusi Aksesoris
    Last Post: 18th July 2008, 03:23
  5. World of Warcraft !!
    By evan in forum Automotive
    Last Post: 12th July 2008, 21:43
