BEST SPL stuff
Results 1 to 10 of 52
Thread: BEST SPL stuff
  • Short URL:  http://modifika.si/116731
    PIN: 28C74CA7 HP:08112509829
    2 Days 22 Hrs 30 Mins 11 Secs
    BEST SPL stuff
    Butuh biaya belajar SQ...jual pusaka SPL
    Rada2 sayang karena set ini cuma ada 1 di Indo
    HAND MADE SUBWOOFER
    -videonya DDZ: http://www.emssiweb.com/tv-emssi.php?v=131
    -midbass nya (ini baru midbass) : http://www.youtube.com/watch?v=QV2eZY7NKCo
    WORLD RECORD 180.5db by ALLAN DANTE
    World dB drag SPL records:
    * 2007
    o 180.5 dB, Alan Dante's concrete filled Volvo with a single Digital Designs 9918Z 18" subwoofer (3" dual voice coil 0.5 ohms) and four Stetsom 7KD amplifiers (26 kW) and fifteen Powermaster 16V batteries and a 61 Hz sine signal source.
    * 1998
    o 172.2 dB, Alma Gates' Bronco has 64 PPI Pro 10" drivers and 32 PPI PC2350 amplifiers (45 kW). The 1" thick plate glass windows have survived 172.8 dB. Her signal source is track 61 on the dB jams CD, which is a 39 Hz Triple Tone Burst (unclipped sine, 50%, 100% clipped square) which was then ran thru a tripling gimzo to generate a 117 Hz tone. From the outside, Alma Gates' Bronco was described as like "metal being beat to death, it sounds like a machine gun or something." Rumor is that she is adding another 20 PPI 10" subs.
    o 171.3 dB, 2nd place, Jeff ???, 12 Stroker 15D2's and 7.2 kW of power, only 0.9 dB behind team Gates with a fraction of the drivers and wattage.
    1sub DDZ (9912)
    2 monoblok DD Z1a
    Review:
    The Z1a makes incredible amounts of power from stock electrical systems; it was designed to make the most power from limited current supplies. The high efficiency comes from paying close attention to every stage through the amp circuit. Multiple power supplies, high speed controller chipsets, efficient power devices and precise thermal management were key to the Z1a design.
    These attributes make the Z1a at home in world record spl cars or high powered subwoofer systems where 400 pounds of battery bank aren’t possible. One Z1a amp can power several big-time subwoofers to stupid loud levels when called upon, or dazzle with rock solid control of complicated bass lines. Z1a's are limited production, high-end amplifiers for customers who want the best.
    Sub Spec:
    Series Z
    Voice Coil Diameter..................76.2mm
    Magnet Weight.......................7 kilotons
    Power Handling RMS/Music/Peak...if you need to ask...
    Suspension............................check
    Nominal Impedance..................various
    DC Resistance........................ditto
    Sub DDZ12 / 9912 berapa watt ???
    baca ini aja, cuma beda size conus:
    Alan Dante from Lorton, Virginia, set a new world record on August 31st in a dB Drag competition with a 180.5dB peak using a single Digital Designs subwoofer. Dante’s concrete filled Volvo contained a Digital Designs 9918Z 18″ subwoofer receiving 26,000 watts of power from four Stetsom 7KD amplifiers.
    lebih jelasnya baca: http://futuremusic.com/blog/?p=1879
    PM or 085290734107
    #NB: SIAPKAN KACA CADANGAN !!!
    BISA TT dengan barang SQ
    Jakarta nieh..!!
    4 Wks 1 Day 3 Hrs 35 Mins 52 Secs
    ......... .... spechless......
    LoweringKit 2nd..
    GSM : 0878 800 36000
    Quote Originally Posted by codot View Post
    ya....sms aja bro
    u p
    u p
    2 Wks 3 Days 1 Hr 21 Mins 48 Secs
    yg mao byk bos, tp begitu dsuruh siapin kaca cadangan jd gemeteran hahahaha
    Quote Originally Posted by NAKAMICHI View Post
    gpp daripada nyiapin bini cadangan :o
    u p
    u p
    u p
  1. E46 stuff
    By 3dwind in forum Bursa Eksterior Lainnya
    Last Post: 19th October 2012, 21:55
  2. [EK9] JDM EK4 / EK9 Stuff
    By auto cepot in forum Bursa Eksterior Lainnya
    Last Post: 12th January 2012, 22:26
  3. WTS : BMW E90 Stuff
    By gardfield in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 21st February 2011, 12:18
  4. SOLD OUT-=WTS : RARE STUFF OEM AE101/AE111 UPDATED STUFF=-SOLD OUT
    By al_corleone in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 30th April 2010, 14:21
