hi-end seas crescendo t29cf002 brand n**
  • Short URL:  http://modifika.si/116476
    Talking hi-end seas crescendo t29cf002 brand n**
    hi-end seas excel crescendo tweeter t29cf002 kondisi brand n** belum pernah tersentuh aliran listrik (stock terakhir di indo saat ini)..............6jt nett
    harga madisound $335,9 x 2 per set
    The T29CF002, ”CRESCENDO” is an Ultra High End 29mm soft dome tweeter with a
    HEXADYM magnet system.
    An optimally shaped dome and integrated wide surround manufactured by SEAS
    from SONOMEX ensure excellent performance and consistency.
    A high efficiency HEXADYM magnet system (US Patent 6020805) based on 6
    radially magnetized NdFeB magnet blocks provide efficient ventilation and damping
    of cavities behind the dome, surround and voice coil. Moderate magnetic stray fields
    represent no problems in AV installations.
    A generously underhung voice coil with flexible lead-out wires, ensures low
    distortion even with low crossover frequencies.
    A 6mm precision machined aluminium front plate with moderate horn loading
    ensures linear frequency response and reasonable efficiency.
    The central part of the horn is made from chrome plated precision machined brass.
    A substantial injection moulded rear chamber made from zinc eliminates unwanted
    chamber wall resonances and conducts heat away from the magnet system.
    The rear chamber and the front plate are Nextel painted to obtain a durable and attractive
    finish.
    Outside diameter 110.3mm
    Cut out 75mm
    Depth 37.5mm
    25.4mm = 1" = 2.54cm
    up....................
Venom 300x250 GT Radial
  1. WTS: Seas Excel & Sub Crescendo
    By n0k14 in forum Speaker - SubWoofer
    Last Post: 15th November 2012, 09:51
  2. Replies: 24
    Last Post: 23rd May 2010, 02:21
  3. Ultra high-end SEAS EXCEL CRESCENDO (sold,thanks modcom....)
    Last Post: 9th December 2009, 05:36
  4. [WTA] Crescendo Vs Seas Orchestra Vs Peerless
    By monokorobo in forum Diskusi Speaker
    Last Post: 14th June 2009, 16:27
  5. Karakter SS R7000 & Seas Crescendo
    By satiragi09 in forum Diskusi Speaker
    Last Post: 14th June 2009, 07:02
