tweeter TEChnology LS29NEO ( scan speak d6000 italian version ) kondisi muluuuuuus...
  • Short URL:  http://modifika.si/116443
    Talking tweeter TEChnology LS29NEO ( scan speak d6000 italian version ) kondisi muluuuuuus...
    tweeter TEChnology LS29NEO ( scan speak d6000 italian version ) kondisi muluuuuuus..................1,8jt
    harga baru : 289,00 EUR
    TECnology LS29 neo / scan speak d6000,tweeter w/ grill has a 1" coated textile dome and a neodymium magnet system. This speaker uses a compact self shielding Symmetric Drive magnet system, utilizing three powerful neodymium magnets. The cavity under the voice coil is coupled to the chamber through eight holes in the top plate. Pure cotton is used as damping material. The textile diaphragm is carefully hand coated. The reproduction is very dynamic and open, with low levels of compression. Perfect for A/V.
    TECHNICAL DATA:
    Sensitivity 2.83V/1M 90.5dB
    Free air resonance Fs 750 Hz
    DC resistance 3.5 ohm
    V.C. inductance 0.02 mH
    Power 12dB@Hz 150W@2.7K
    Effective cone area 8 cm2
    V.C. diameter 28 mm
    Lin. & max. excursion 0.25 / 1.3mm
    Force factor BL Product 2.7 Tm
    Moving mass incl. air 0.4 g
    Net weight 0.13 kg
    Outside diameter: 59.5mm
    Cut out: 41mm
    Depth: 29mm
    25.4mm = 1" = 2.54cm
    up..................
  1. FS> Tweeter ScanSpeak d6000 n midrange Scan Speak 12M..........
    By ryosaiba in forum Speaker - SubWoofer
    Last Post: 16th May 2011, 23:18
  2. WTS : Tweeter Scan Speak D6000
    By ndra82 in forum Speaker - SubWoofer
    Last Post: 11th March 2010, 14:57
  3. Replies: 13
    Last Post: 27th October 2009, 01:36
  4. [SOLD]: Tweeter Scan Speak D6000
    By gendutz in forum Speaker - SubWoofer
    Last Post: 10th October 2009, 12:29
  5. tweeter scan speak D6000 vs phass AT28 evo
    By vtjoe512 in forum Diskusi Speaker
    Last Post: 24th May 2008, 12:08
