2pcs xtant monoblock audiophile class 1.1i kondisi muluuus no service..........
Results 1 to 10 of 10
  • Short URL:  http://modifika.si/116165
    Talking 2pcs xtant monoblock audiophile class 1.1i kondisi muluuus no service..........
    2pcs xtant monoblock audiophile class 1.1i kondisi muluuus no service................3jt
    new price $349/pc
    Specifications :
    Number of Channels 1
    Watts per Channel 4 Ohm 1 x 100
    # Watts per channel 2 Ohm 1 x 100 Distortion <1% THD Measured at 20-20KHz at rated power all channels driven
    # Signal to Noise Ratio >100dB A-Weighted in 20KHz
    # Frequency Response 17Hz-21KHz +0, -2dB
    # Input Sensitivity 100 mV - 8.5V Unbalanced, 200 mV-17V balanced
    # Operational Voltage 10-16V
    # Dimensions 6.5 L x 5.81" W x 1.63" H
    # Fully Regulated PWM power supply
    Requires 10A Fuse
    "Small wonder: At a svelte 6 x 1 5/8 x 5 inches, it isn't much bigger than your typical CD jewel case - diminutive enough for such hideaway mounting positions as under the dash, under a seat, in a glove box, or even in a center console."
    -Mike Mettler, Editor in Chief, Mobile Entertainment Magazine as seen in Sound & Vision Magazine, May 2003
    AUDIOPHILE FULL SPECTRUM CLASS D TECHNOLOGY
    The Xtant1.1i adds local and global multiple nested feedback loops with premium MOSFETs and OPAmps for switching stability and audio signal accuracy within the full range spectrum. This results in an extremely high switching speed—over 1MHz.
    Because the switching speed is over 1MHz, we are able to set the output filter frequency high enough to avoid any phase related distortion within the higher frequency range of the audio signal. This enhances the musical reproduction by ensuring the higher frequencies (cymbals and the like) compliment the entire frequency range to bring new realism to the Class D amplifier sound experience.
    The Audiophile Full Spectrum Class D Technology with Xtant’s attention to detail results in a Class D amplifier that sounds better than many audiophile Class A/B amplifiers. It exhibits an extremely low noise floor eliminating the “hiss” common to many Class D amplifiers. The improved dynamic range enables the accurate reproduction of every loud and quiet passage within the musical range. This makes the amplifier exceptionally suited for musical and theater applications.
    Features
    * Xtant amplifiers feature a Fully Regulated, Pulse Width Modulated power supply. This power supply technology provides high efficiency and consistent output performance even when battery voltage is less than optimum.
    * The Balanced input circuit increases common mode noise rejection and eliminates ground loop noise while allowing for 100mv to 17 volts of signal input. This circuit also makes interfacing with any factory head-unit easy.
    * Both Thermal and Overcurrent protection are incorporated into Xtant amplifiers. In the event of a problem, the amplifier will reduce its power to maintain operation.
    * These small footprint mono-block amplifiers are ideal for vehicles that have limited space and allows for unlimited installation creativity in any application. The mono-block concept also allows for easy audio and/or video system configuration (2-, 3-, 4-, 5-, 6-, or 7-Channel).
    call
    081388575788
    PangkaL Paha
    2 Wks 5 Days 7 Hrs 27 Mins 47 Secs
    apanya nich peratamax om?
    ngempanin nya pake pertamax...?
    up.............
    PangkaL Paha
    ngempanin begituan koq pake pertamax,, halahh
    city of light
    2 Days 19 Hrs 31 Mins 53 Secs
    lah iki dodol power opo dodol kerang?? wuakakakakaakkaka :o:p
    5 Hrs 8 Mins 34 Secs
    [QUOTE=GASOLINE;4493793]2pcs xtant monoblock audiophile class 1.1i kondisi muluuus no service................3jt
    new price $349/pc
    Specifications :
    Requires 10A Fuse
    Yogyakarta
    1 Day 11 Hrs 37 Mins 55 Secs
    Quote Originally Posted by b2okane View Post
    Gw ke dua???? bekas Kane????:o:o:o Gak sudi.....:smt074
    SEARCHautofamily
    1 Day 9 Hrs 21 Mins 40 Secs
    brp bro nettnya?
    pm yah..
    Bantu upppp.....pak kris
Tekiro Mega Glodok Kemayoran
  1. WTS: Xtant Hexagonal Type-X 12" + Monoblock Xtant 2x100 2 Channel
    By netekdenkow in forum Speaker - SubWoofer
    Last Post: 8th November 2010, 17:21
  2. Replies: 2
    Last Post: 31st December 2009, 11:34
  3. Replies: 73
    Last Post: 25th August 2009, 14:39
