--.WTS.-- KSPORT Coilover Kit Honda New Jazz GE8
Results 1 to 7 of 7
  • Short URL:  http://modifika.si/114990
    1 Wk 3 Days 2 Hrs 57 Mins 1 Sec
    KSPORT KONTROL PRO COILOVER KIT FOR HONDA NEW JAZZ GE8
    Ksports Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. Made from high quality 6061 Aluminum with T6 for increased hardness.
    Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
    Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
    The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavitations are a lot less common in a Monotube design, which results in a better ride.
    The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
    1. 36 levels of adjustable dampening
    2. Made from high quality 6061 aluminum with T6 for increased hardness
    3. Compression/Rebound adjustable
    4. Adjustable spring perch for height adjustment
    5. Adjustable body allowing maximum suspension travel
    6. Monotube high pressure design reduces oil leakage
    7. Electroplated body for protection from corrosion and rust
    8. One year limited warranty
    Price: USD950,00 (exclude installation and settings)
    Minat???
    Call,
    Coki - de Auto Motorsport
    CDMA: 021.9866.1978
    GSM: 0815.1330.1978
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    naikin dulu..
    CP : Coki Siboro
    batavia city
    1 Mth 3 Wks 3 Days 7 Hrs 54 Mins 2 Secs
    Smile
    bos ada coilover buat odssey RB1 ga? merknya apa? pm saya yach tq
    Quote Originally Posted by Hoen View Post
    kalo mau ksport bisa bos, tp by order aja..
    kontak hp saya aja langsung ya bos. thx
    CP : Coki Siboro
    naikin terus sampe laku..
    CP : Coki Siboro
    CP : Coki Siboro
    7 Hrs 8 Mins 20 Secs
    klo ke rupiah jdi berapa boss?
  1. --selling-- KSPORT COILOVER KIT
    By coki.de auto in forum Per & Shockbreaker
    Last Post: 15th August 2015, 02:50
  2. Replies: 90
    Last Post: 18th May 2013, 17:12
  3. [selling] Coilover Kit KSPORT
    By coki.de auto in forum Bursa Kaki Lainnya
    Last Post: 3rd December 2012, 18:36
  4. WTS::: Ksport Kontrol Pro Coilover V2.2 Golf GTI Mk5
    By roadstaz in forum Per & Shockbreaker
    Last Post: 11th December 2011, 13:59
  5. SOLD-- KSPORT Coilover Kit Honda Jazz GE8--SOLD
    Last Post: 23rd January 2010, 13:51
