WTS : WHITE FERIO SPOONSPORT
Results 1 to 10 of 55
  • Short URL:  http://modifika.si/114793
    8 Hrs 23 Mins 20 Secs
    Mo jual FERIO th 96 full spek JDM , engine , interior , eksterior , kaki kaki semua JDM asli .......
    Body masih orisinil tanpa di rubah .... warna putih asli no repaint .....
    Contact person : 0816670970
    Suspension System
    Tanabe street spec fix type
    RSR coil spring
    Vision front adjustable chamber arm
    Vision rear adjustable chamber arm
    Vision rear adjustable rear toe arm
    J'S racing roll center adjuster (ball joint)
    Spoonsports wheel 16 x 7
    Bridgestone potenza G III 195/50/16
    Spoonsports wheel lug nut (blue color)
    OEM honda civic type R rear anti roll bar/rear stabilizer
    Body Reinforcement
    Tanabe front strut bar
    OEM honda civic EK4 front chassis bar
    J'S racing inner fender bar
    Tanabe rear strut bar
    Alex trunk bar
    Sergeant rear chassis bar
    Tanabe front lower arm bar
    Tanabe rear lower arm bar
    Do-luck rear cross bar
    Brake system
    Brembo max front slotted rotor
    Ferodo front brake pad
    Ferodo rear brake pad
    APP brake hose
    Spoonsports reservoir tank cover
    Cusco master cylinder brake stopper
    Intake & exhaust
    Spoonsports air cleaner & HKS hybrid air filter
    Spoonsports carbon fiber direct air flow pipe
    Billion thermo cloth
    4-2-1 kansai sports exhaust manifold system (dari header sampai sebelum muffler)
    Buddyclub racing spec IV muffler (silent type)
    Power Unit
    P2J D15B cylinder head (SOHC 3 stage VTEC) with dual VTEC solenoid
    Cometic 2 ply thin head gasket
    Cusco oil catch tank
    Spoonsports magnetic drain bolt set
    P2J D15B injector
    Buddyclub volt stabilizer & ground wire
    Carbing radiator cooling plate
    Mugen reservoir tank cover
    Pivot spark earth
    Pivot ignition earth
    Pivot raizin spark type S
    Pherma cool oil cooler 150 HP remote type
    Apexi AFC neo
    Buddyclub oil cap
    J'S racing engine torque damper
    Tein engine hood damper
    Silver's max power fuel magnetic system
    Silver's air power
    NGK power cable
    HKS super fire racing spark plug
    Sard silicone hose
    Drive train
    OEM honda LSD kit
    Spoonsports clutch slave hose
    Buddyclub quick shifter
    OEM honda civic estillo EG6 flywheel
    Cooling system
    Billion radiator hose set
    Spoonsports radiator stay
    Buddyclub radiator cap
    Spoonsports thermoswitch
    Spoonsports thermostat
    Spoonsports heat barrier tape
    Greedy breather tank set
    Interior & exterior
    Spoonsports steering wheel
    HKB steering boos kit
    Triple Z quick release
    Spoonsports shift knob (duracon type)
    Mugen pedal set
    Carbing foot rest
    Custom honda floor mat
    OEM honda civic type R EK9 shift boot red stiching
    Pivot 5 in 1 gauge
    Apexi RSM + G sensor
    OEM honda S2000 engine start button
    Mugen rear wing
    Modulo honda access rear spoiler
    Modulo honda access front spoiler
    Modulo honda access door side visor
    OEM honda civic type R EK9 front grill
    OEM honda stream fog lamp + switch
    Philips crystal vision head lamp bulb + fog lamp bulb + wuerth stabilizer + relay
    Custom painted black chrome head lamp honda civic type R EK9 JDM style
    Buddyclub shoulder pad
    Spoonsports aero wing arm
    Spoonsports blue wide mirror
    Spoonsports window sticker
    Spoonsports mark sticker
    Spoonsports team sticker
    Type one sticker
    Advan sticker
    Custom semi leather seat cover black color with red stiching JDM style
    Full interior & exterior with polarg B1 hybrid bulbs (blue color)
    LLumar super black side&rear window film
    LLumar BM35 front window film
  2. 36Goal.com
    pertamax gan...
    bka brp nh??
    www.bisaboy.com
    4 Mths 1 Wk 1 Day 23 Hrs 27 Mins 10 Secs
    mantab..buka brp bos?pm harganya bos..thx ya
    3 Hrs 41 Mins 16 Secs
    pm harganya bos
    SYD-AUS
    3 Wks 3 Days 10 Hrs 8 Mins 43 Secs
    lha bknnya ud SOLD ya.??:confused::confused:
    Up... belom laku boss ...........mobilnya masih di SOLO .....
    Warna putih asli , BUKAN repaint .... jarang ada ..................
    Klo mau liat speknya ada di thread yg lama , silakan di klik ........
    Quote Originally Posted by Hardian1987 View Post
    pm harganya bos
    Buka harga 115jt nego , itu barang2 yg std masih ada semua komplit , semua barang yg dipasang asli jepun ngga ada yg replika .........TQ
    6 Days 10 Hrs 18 Mins 45 Secs
    PM Nett ya Bos...
    Quote Originally Posted by bangsatsat View Post
    hebaat boz....
    bntu up yeh.. hehehe...
  1. jdm•garage : plate japan [ ..95 ] spoonsport !! 1pc sale murah!
    By renzv in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 15th January 2014, 13:02
  2. Replies: 150
    Last Post: 30th April 2013, 13:59
  3. WHITE CIVIC FERIO
    By speedfreaks in forum Honda
    Last Post: 13th March 2013, 02:52
  4. White Ferio Spoonsport
    By bangsatsat in forum Honda
    Last Post: 4th November 2009, 13:28
