--- RACING PARTS...!
Results 1 to 10 of 81
  • Short URL:  http://modifika.si/113699
    Thumbs up --- RACING PARTS...!
    VARIOUS PERFORMANCE PARTS
    Disini berisi macem2 part2 racing dengan jumlah yg terbatas dan akan selalu diupdate.. Barangnya 100% baru dan original semua. Performance Parts yg akan kami post adalah parts2 yg ready stock, kalau ada yg bos-bos minat tapi tidak ada, kita bisa bantu order.
    Kebanyakan parts2 nya kita import sendiri (ACT, JR Project, B & M, Mugen, J's Racing, Megan Racing, DC Sports, SKUNK2, Eagle, Supertech, Comp Cams, BLOX Racing, Fidanza, HKS, NGK, etc) dengan harga yg kompetitif tentu nya..
    -Coki de Auto Motorsport-
    0815.1330.1978
    021-9866.1978
    CAMSHAFT
    Merk : Competition Camshaft USA (COMP CAMS)
    Tipe Mesin : Honda with P-08 Head SOHC VTEC
    Durasi : In 260 deg - Ex 268 deg
    NOTE: SOLD OUT..!
    VALVE SPRING/PER KLEP
    Merk : Comp Cams USA
    Tipe : Single Spring
    Tipe Mesin : Honda Civic SOHC VTEC
    NOTE: SOLD OUT..!
    Merk : Supertech
    Tipe : Single Valve Spring & Titanium Retainer Kit
    NOTE: SOLD OUT..!
    Merk : HKS
    Tipe Mesin : Mitsubishi Lancer Evolution 4G63T I-VII
    Harga : 2,950,000 rp.
    ADJUSTABLE CAM GEAR
    Merk : SKUNK2 RACING
    Tipe : Tuner Series (Blue)
    Aplikasi : Honda Civic D15 & D16 SOHC
    NOTE: SOLD OUT..!
    Merk : AEM Tru-Time
    Aplikasi : Honda B-Series DOHC
    Color Available : Black
    Harga : 2,750,000 rp. (set 2pcs)
    BLOCK GUARD
    Merk : Supertech Block Guard
    Tipe Mesin : Honda Civic SOHC D16
    Harga : 1,350,000 rp.
    Tipe Mesin : Honda Civic SOHC D17 01-05
    NOTE: SOLD OUT..!
    CONNECTING RODS
    Merk : Eagle
    Tersedia Untuk:
    Honda Civic D16 SOHC
    Honda Civic D17 SOHC
    Honda B16 DOHC
    Harga : 4,500,000 - 5,500,000 rp.
    BEARINGS / METAL DUDUK - JALAN
    Merk : ACL
    Parts : Main & Rod Bearings Set
    Tipe Mesin :
    Honda Civic D16 SOHC (Race Series & Duraglide Series)
    Honda Civic D17 SOHC (Race Series & Duraglide Series)
    Honda B16 DOHC (Race Series)
    VALVE SEAL / SEAL KLEP
    Merk : Toga Performance JPN
    Tipe : Super Valve Seals Set Vitron Hi Temp Rubber (16 pcs)
    Mobil : Honda Civic D16, D15, D17, B16A, H22, F22, F23, etc
    NOTE: SOLD OUT..!
    ARP BOLTS
    Merk : ARP Pro Series
    Parts : ARP Flywheel Bolts Kit (6 pcs)
    Mobil : Honda Civic SOHC D15 & D16
    Harga : 850,000 rp.
    HI-PERFORMANCE FUEL PUMP
    Merk : Walbro (buy the original only & beware of imitation..!)
    Tipe : Hi-Flow 255 L/H
    Mobil : Walbro Fuel Pump with Installation Kit Honda Civic 92-01
    Harga : 1,750,000 rp.
    FUEL RAIL
    Merk : AEM
    Application : Honda B16/B18
    Harga : 1,700,000 rp.
    FUEL PRESSURE REGULATOR
    Merk : BLOX Racing
    Available Color : Black
    Mobil : FPR Kit for Honda Civic 92-00
    Harga : 900,000 rp.
    Merk : TOMEI
    Availabe Type : Type S
    Tipe : Universal
    Merk : SARD
    Available Color : Silver
    Tipe : Universal
    Harga : 1,500,000 rp.
    Merk : AEM
    Tipe : Universal
    NGK RACING SPARK PLUG WIRE
    Keterangan : Kabel Busi NGK
    Mobil : Honda B-Series DOHC VTEC (R8 USDM)
    Harga : 1,250,000
    Mobil : Honda Civic B-Series DOHC VTEC (R09 JDM-Power Cable)
    Harga : 1,450,000
    Aplikasi : Honda Civic D16 Non-VTEC Head (R8 USDM)
    Harga : 1,250,000
    UNIVERSAL AIR FILTER
    Merk : HKS
    Tipe : Super Mega Flow - Reloaded (USDM)
    Ukuran : 200-100mm
    Keterangan : 2 Layer Red Foam Filter with Red Plate
    Harga : 1,600,000.
    Merk : HKS
    Tipe : Super Power Flow - Reloaded
    Ukuran : 200-100mm
    Keterangan : 2 Layer Green Foam Filter with Gold Plate
    Harga : 1,400,000 rp.
    SUPER90 RACING THROTTLE BODY
    Keterangan: Super90 Racing Big Bore Throttle Body. Made of High Quality Billet Alumunium T6-AL6061
    Tersedia Untuk:
    Honda Civic D16 SOHC (70mm)
    Honda Civic B16 DOHC VTEC (70mm)
    NOTE: SOLD OUT..!
    ACT CLUTCH KIT
    Keterangan Mobil : Honda Civic D16 Estilo/Genio 212mm
    Item dalam 1 Set ACT Clutch Kit nya:
    - Plat Kopling 4-Puck with Spring
    - Dekrup Heavy Duty (berat nambah 30%an dari standar)
    - Dek Laher
    - Laher Flywheel
    - Alignment Tool
    Harga : 5,999,000 rp.
    Keterangan Mobil : Honda Civic D17
    - Plat Kopling 4-Puck Solid Disc
    Harga : 5,500,000 rp.
    Keterangan Mobil : Honda B16 EG & B18C
    NOTE: SOLD OUT..!
    Keterangan Mobil : Toyota Yaris & New Vios
    NOTE: SOLD OUT..!
    HIGH PERFORMANCE ALUMUNIUM RACE RADIATOR
    JR PROJECT 3 ROW HONDA CIVIC 92-00
    Dimension: 360x350x52mm
    Inlet : 28mm
    Outlet : 28mm
    Row : 3 Rows
    NOTE: SOLD OUT..!
    Installed Pictures on Honda Civic Ferio:
    Installed Pictures on Honda Civic Estillo:
    FORGED RACING 2 ROW HONDA CIVIC 92-00 B16A/B DOHC MT
    Dimension: 410x360x40mm
    Row : 2 Rows
    FORGED RACING 2 ROW MITSUBISHI EVO 1-3 MT
    Dimension: 640x430x60mm
    Row : 2 Rows
    Harga : 3,400,000 rp.
    INTERCOOLER
    Tersedia 3 Tipe & Ukuran:
    * Tube & Fin Type
    Dimensi: 600x300x76 mm
    Inlet: 3 in
    Outlet: 3 in
    Harga : 3,750,000 rp
    * Bar & Plate Type
    Dimensi: 550x180x65 mm
    Inlet: 2,25 in
    Outlet: 2,25 in
    NOTE: SOLD OUT..!
    * Bar & Plate Type
    Dimensi: 460x160x90 mm
    Inlet: 2,5 in
    Outlet: 2,5 in
    NOTE: SOLD OUT..!
    * Bar & Plate Type
    Dimensi: 330x150x60 mm
    Inlet: 2 in
    Outlet: 2 in
    Harga : 1,250,000 rp.
    BOOST CONTROLLER
    Merk : HKS
    Tipe : Variable Boost Controller - Manual
    Aplikasi : For Use with External Wastegate
    Harga : 1,450,000 rp.
    BLOW OFF VALVE
    Merk : GReddy
    Tipe : Type RS Universal
    Harga : 2,500,000
    Merk : BLITZ
    Tipe : Super Sound - Dual Drive
    Harga : 2,250,000
    UNIVERSAL MUFFLER
    Merk : Megan Racing USA
    Tipe : Stainless Universal Muffler
    Ukuran : Inlet 2,5in & Tail 4in
    Keterangan : Termasuk Silencer
    Merk : DC SPORTS
    Tipe : Stainless Universal Muffler - Straight Tip
    Ukuran : Inlet 2,5in & Tail 4,5in
    Tipe : Mega Power Universal Muffler
    Ukuran : Inlet 2,25in & Tail 4in
    Harga : 2,850,000 rp.
    Tipe : Mega Power J-SPEC Universal Muffler
    Ukuran : Inlet 3in & Tail 5in
    Harga : 3,000,000 rp.
    RACING LUG NUTS
    Merk & Tipe : BLOC Racing Forged 7075 Alumunium
    Warna : Hitam
    Jumlah Set : 16 Buah
    Ukuran : 12x1.50
    Daftar Mobil yg Pasti Bisa : Honda, Toyota, Mitsubishi, dll
    Daftar Mobil yg Pasti Tidak Bisa : Nissan & Suzuki
    SHORT SHIFTER
    Merk : Fidanza
    Tipe Mobil : Honda Civic D17 2001-2005
    Harga : 700,000 rp.
    Merk : Fidanza
    Tipe Mobil : Honda Civic D-Series 1988-2000 (Nova, Estilo, Ferio, dll)
    Harga : 700,000 rp.
    AUTOMATIC TRANSMISSION/ATF COOLER KIT
    Most Automatic Transmission Failure Caused by OVERHEATING Transmission Oil..!
    Benefits:
    - Improve Gear Shift/Change Responds
    - Longer Life Span of the Transmission Oil
    - Lesser Power Loss due to Transmission Oil Heat
    - Better Fuel Economy
    Merk : B & M (Made in USA)
    Tipe : Universal
    Keterangan : Komplit Kit dengan selang2, bracket, fittings, dll
    NOTE: SOLD OUT..!
    Merk : Hayden - Rapid Cool (USA)
    Tipe : Universal
    SPARK PLUG / BUSI
    Merk : NGK Racing
    Keterangan :
    - Harga Untuk Tiap Set 4pcs
    - Iriway (Japanese Market) & Iridium IX (USA Market)
    Tipe :
    Iriway 7 ---> 700rb
    Iriway 8 ---> 750rb
    Iriway 9 ---> 800rb
    Iridium IX BKR7EIX ---> 600rb
    Iridium IX BKR8EIX ---> 625rb
    Iridium IX BKR9EIX ---> 650rb
    PEDAL SET
    Merk : Sparco
    Tipe : Corsa - Manual Transmission
    Harga : 650,000 rp.
    BRAKE LINE
    Merk : Russell Made in USA
    Tipe Mobil : Honda Stream 2001-2005 1.7L
    Keterangan : 1 Set Brake Line untuk 4 Roda
    Harga : 1,850,000 rp.
    Tipe Mobil : Honda Civic 2001-2005 D17
    Keterangan : 1 Set Stainless Brake Line untuk Roda Depan
    RADIATOR CAP
    Merk : HKS
    Tekanan : 108 kPa (1,1 kgf)
    Keterangan Mobil : Honda, Toyota, Mitsubishi, Suzuki
    Harga : 375,000 rp.
    RESERVOIR TANK COVER
    Merk : SKUNK2
    Keterangan :
    Skunk2 Reservoir Covers help prevent fluid leakage from Brake and Clutch Reservoirs.
    Skunk2 Reservoir Covers are fire retardant to help protect master resevoirs from engine fire
    Harga : 175,000 rp.
    Karena stock untuk parts2 tersebut diatas tidak banyak, bagi yg minat serius bisa langsung kontak ke handphone saya atau datang langsung ke bengkel dengan nomor telepon dan alamat lengkap ada di signature dibawah ini.
    *) note : Harga2 tersebut diatas tidak termasuk pemasangan atau pengiriman..!
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    1 Mth 3 Wks 3 Days 17 Hrs 12 Mins 49 Secs
    slurrrppppp.... sedap banget nih barang......
    "High performance is like a church, it's an expensive non profit organization w/ no gaurantees" - Carroll Shelby
    Quote Originally Posted by retilo93 View Post
    hhuahaha
    minta simpenin 1 sama si epi bos!!
    CP : Coki Siboro
    update pics!!
    CP : Coki Siboro
    1 Min 25 Secs
    Ini berat gak yaaa???
    Kalo full aluminium sih seharusnya enteng yaaa???
    Quote Originally Posted by AtDp View Post
    ada yang mau pinjemin timbangan?? hahahah
    beratnya sekitar 3kg aja.
    CP : Coki Siboro
    Quote Originally Posted by coki.de auto View Post
    gile... manteb amat ya...
    dah 3 row cuman 3 kg lagi.....
    1 Min 25 Secs
    Tapi yang penting juga utk pendinginannya sih yaaa...
    Sudah terbukti kan tuh di estilo, temperatur-nya dah gak naek2 lagi....
    MANTEB....
    Indonesia
    2 Days 10 Hrs 28 Mins 24 Secs
    MANTEB....
    situ dah pake ya bos?
    1 Min 25 Secs
    Quote Originally Posted by homeboy View Post
    Temen gue dah pake di estilo-nya....
    Manteb katanya, tidak pernah khawatir masalah overheat... hehehehehe
GT Radial NGK Busi
  1. WTB> PARTS RACING FOR D16
    By SatanJr91 in forum Jual Beli Mesin Lainnya
    Last Post: 27th May 2011, 20:12
  2. parts racing cb5 / evo 3 gti
    By evo3 GTi ijo in forum Diskusi Mesin
    Last Post: 11th April 2010, 12:38
