FS: StopTech ST40 BBK buat Evo Part # 83.622.4600.51
  • Short URL:  http://modifika.si/109587
    無限 & ドラえもん
    FS: Stoptech Part #: 83.622.4600.51 buat lancer evo 2003-2006
    rotor 332x32
    warna hitam calipernya
    kondisi komplit
    minat? call 022 70207388
    Stoptech Big Brake Kits give your vehicle that Supercar look and feel, and exceed stock performance in two areas. First, larger rotors increase heat capacity. Second, stiffer calipers and stainless steel lines reduce system compliance.
    The key, however, is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio. If the brake upgrade you select adds too much front torque (as many do), you reduce your car’s ability to utilize the tractive capacity of all of the tires to the maximum practical extent (even on ABS equipped cars) and you therefore create performance sacrifices. In addition, too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate, which limits a driver’s control of brake input on the race track.
    Advantages of StopTech over other brake upgrades:
    * Shorter Stopping Distances
    * Better Brake Modulation
    * Firmer Brake Pedal
    * Less Brake Fade
    Feature Benefit Summary:
    * Balanced Brake Upgrades� with optimum brake bias offer the shortest stopping distance with the best pedal feel
    * StopTech’s patented AeroRotors� with the best airflow available result in better cooling, less fade and longer rotor and pad life
    * The stiffest aftermarket calipers with patented bridge result in better clamping under hard braking and less pad taper
    * Track testing of new applications ensures optimum performance
    Style of Caliper: Black StopTech ST-40 4-Piston Caliper
    Rotor Size: 332x32
    Style of Rotor: Slotted Rotor
    無限 & ドラえもん
    up lagi buat evo..
  1. JUAL Big Brake KIT StopTech 355mm Front Black just Like new
    By AKW.777 in forum Bursa Kaki Lainnya
    Last Post: 14th October 2012, 12:28
  2. Jual : Power Amplifier 4 Channel Phoenix Gold XS 4600
    By d3cibel in forum Power Amplifier
    Last Post: 5th December 2011, 19:45
  3. [Ask} Big Brake Kit Stoptech
    By PenghancurBaja in forum Diskusi Kaki-Kaki
    Last Post: 18th September 2008, 18:01
  4. Replies: 2
    Last Post: 16th June 2008, 12:24
  5. Ada yg udah pernah beli rem Stoptech di Sphinx Hobbies
    By Ruzh in forum Diskusi Kaki-Kaki
    Last Post: 30th June 2007, 10:24
