[ASK] Sub 8" high excursion
  • Short URL:  http://modifika.si/108816
    2 Mins 40 Secs
    para audio guru sekalian
    minta advis merk dan tipe subwoofer 8 inchi yang ekivalen (spec mendekati atau lebih baik) dari spec MCM Audio Select Part #: 55-2421:
    # Power capacity: 120W/240W RMS/peak
    # Frequency response: 25Hz ~ 1KHz
    # Nominal impedance: 4Ω
    # Voice coil diameter: 2"
    # Magnet weight: 47oz.
    # Sensitivity: 87dB W/M
    # Fs: 25.7Hz
    # Re: 3.4Ω
    # Le: 2.47mH
    # Qms: 14.0
    # Qes: 0.22
    # Qts: 0.22
    # Vas: 30.43 liters
    # Mms: 59.78g
    # Xmax: 8mm (one-way)
    # Magnet gap height: 8mm
    # BL: 12.99
    # Piston diameter: 163mm
    MCM Audio Select Part #: 55-2421 harganya USD 35 tapi adanya di amrik doang.
    sebelumnya terimakasih.
    Quote Originally Posted by fauzip View Post
    # Fs: 25.7Hz
    # Re: 3.4Ω
    # Le: 2.47mH
    # Qms: 14.0
    # Qes: 0.22
    # Qts: 0.22
    # Vas: 30.43 liters
    # Mms: 59.78g
    # BL: 12.99
    emang nya subs yg ini jamin bagus boss ?
    bb pin : 2855D02F
    gile XMAXnya tinggi jg yaa
    JKT-PIK
    1 Mth 2 Wks 5 Hrs 30 Mins 1 Sec
    Kalau yg di cari "HIGH-EXCURSION" bisa coba check IMAGE DYNAMICS ID8 D4/D2 Ver.2....
    Excursion-nya 15.0 mm (One Way Linear)...thanks...
    Rgrds,
    ZIG3N
  1. Replies: 26
    Last Post: 14th March 2011, 12:50
  2. Replies: 4
    Last Post: 25th April 2010, 23:37
  3. Replies: 5
    Last Post: 21st January 2010, 15:12
