AWG Copper Wire Table
Rgotogel Gelap.net 36Goal.com
Results 1 to 8 of 8
  • Short URL:  http://modifika.si/107304
    3 Mins 58 Secs
    Talking AWG Copper Wire Table
    Saya lampirkan dalam bentuk zip file aja ya, susah juga, udah diubah jadi word, rtf, pdf ukuran file nya gak bisa lebih kecil dari ketentuan.
    Semoga berguna.
    3 Mins 58 Secs
    Om Unscac, delete aja dulu deh, formatnya jadi ancur gitu...
    1 Day 19 Hrs 23 Mins 54 Secs
    klo di foto aja gimana ...
    5 Days 4 Hrs 44 Mins 10 Secs
    Quote Originally Posted by oncen View Post
    Tadi saya nemu tabel kabel tembaga AWG beserta dimensinya, siapa tahu berguna..
    AWG Diam. (mils) Circular mils Ohms/1000ft Current Carrying Fusing Current Feet per Pound
    0 460 212000 0.05 - - 1.56
    0 410 168000 0.063 - - 1.96
    0 365 133000 0.077 - - 2.4826
    0 324.85 105531 0.096 - - 3.1305
    1 289.3 83694 0.1264 119.6 - 3.947
    2 257.6 66358 0.1593 94.8 - 4.977
    3 229.4 52624 0.2009 75.2 - 6.276
    4 204.3 41738 0.2533 59.6 - 7.914
    5 181.9 33088 0.3915 47.3 - 9.98
    6 162 26244 0.4028 37.5 668 12.58
    7 144.3 20822 0.508 29.7 561 15.87
    8 128.5 16512 0.6405 23.6 472 20.01
    9 114.4 13087 0.8077 18.7 396 25.23
    10 101.9 10384 1.018 14.8 333 31.82
    11 90.7 8226 1.284 11.8 280 40.12
    12 80.8 6529 1.619 9.33 235 50.59
    13 72 5184 2.042 7.4 197 63.8
    14 64.1 4109 2.575 5.87 166 80.44
    15 57.1 3260 3.247 4.65 140 101.4
    16 50.8 2581 4.094 3.69 117 127.9
    17 45.3 2052 5.163 2.93 98.4 161.3
    18 40.3 1624 6.51 2.32 82.9 203.4
    19 35.9 1289 8.21 1.84 69.7 256.5
    20 32 1024 10.35 1.46 58.4 323.4
    21 28.5 812 13.05 1.16 - 407.8
    22 25.3 640 16.46 0.918 41.2 514.12
    23 22.6 511 20.76 0.728 - 648.4
    24 20.1 404 26.17 0.577 29.2 817.7
    25 17.9 320 33 0.458 - 1031
    26 15.9 253 41.62 0.363 20.5 1300
    27 14.2 202 52.48 0.288 - 1639
    28 12.6 159 66.17 0.228 14.4 2067
    29 11.3 128 83.44 0.181 - 2607
    30 10 100 105.2 0.144 10.2 3287
    31 8.9 79 132.7 0.114 - 4145
    32 8 64 167.3 0.09 - 5227
    33 7.1 50.125 211 0.072 - 6591
    34 6.3 39.75 266 0.057 5.12 8310
    35 5.6 31.5 335 0.045 4.28 10480
    36 5 25 423 0.036 3.62 13210
    37 4.45 19.83 533 0.028 - 16660
    38 3.97 15.7 673 0.022 2.5 21010
    39 3.5 12.47 848 0.018 - 26500
    40 3.14 9.89 1070 0.014 1.77 33410
    41 2.8 7.842 - - 1.52 -
    42 2.494 6.219 - - 1.28 -
    43 2.221 4.932 - - 1.06 -
    44 1.978 3.911 - - 0.916 -
    45 1.761 3.102 - - - -
    46 1.568 2.46 - - - -
    47 1.397 1.951 - - - -
    48 1.244 1.547 - - - -
    49 1.107 1.227 - - - -
    50 0.986 0.973 - - - -
    diubah ke grafik dulu aja bos.
    JOIN THE UnSCAC'S!!!!
    New Avexis FU6s on:
    E-MAIL: unscac@yahoo.com
    Whatsapp, Cell : 082141139097
    Line: Hwely
    Please DON'T sent via PM!!!
    Cabin Gain
    3 Hrs 48 Mins 57 Secs
    Gpp .. wong maksudnya mau share .. kok !
    1.> Kalau Windows : Buka Webnya .. tekan Alt+Print Screen -> buka Paint -> Paste disana -> Edit2 sedikit untuk ukuran gambarnya -> Save.
    2.> Panggil misal http://www.modupload.com/ -> Pilih filenya -> Start Upload -> Ambil nama Link untuk gambarnya di Copy saja (Ctrl+C).
    3.> Edit Posting anda -> Insert Image -> Paste (CTRL+V) -> OK.
    Yang report kalau lebih dari 1 screen di web nya... selamat berjuang !
    Cabin Gain
    Semoga berguna.
    Waduh .. masih ga bisa juga ya bro ... padahal gampang kok ..
    Ini saya buat cuman sebentar :
    Langkahnya : Buka Attachment dari anda .. block excelnya yang ada data di bawah -> tekan CTRL+C (Copy) -> Buka Microsoft Paint : tekan CTRL+V (Paste) -> Edit Ukuran dikit -> Selesai.
    General Notes:
    The wire size is different between the American Wire Gage [AWG] and the British standard. The table above only lists the AWG standard.
    AWG [American Wire Gauge] may also be called the Brown and Sharpe (B&S) Wire Gauge.
    The Birmingham Wire Gauge [BWG] is used for steel armor wire.
    Watch for round-off errors, as many numbers were rounded. Use the table as a guide.
    The weight [pound per foot] does not include wire insulation. The weight of the wire is critical in some applications.
    Circular mils is the diameter squared in mils.
    The editor has never seen the American Wire Gauge [AWG]
    Current Notes:
    The current shown per wire size listed above is based on 1 amp/ 700 Circular mils, other tables provide different current per wire size, and different current for open air ~ check your local electrical code for the correct current capacity [Ampacity]. The 1 amp/ 700 Circular mils seems to be the most conservative, other sites provide/allow for 1 amp per 200 or 300 Circular mil. For shot wire lengths use 1A/200 Circular mil, for longer wire runs use 300 Circular mil, and for very long wire runs use the table above, 1 amp / 700 Circular mil.
    The current rating is listed based on permissible voltage drop and not conductor heating.
    The ability of a wire to carry a given amount of current is affected by a number of additional factors, which are not accounted for in the AWG table above. The ambient temperature of the surrounding air, wire insulation, and number of other wires bundled together [provided below].
    Ampacity relates to the ability of the conductor to carry current [amps] before the cable over heats. There are hundreds of Ampacity tables for many different conditions. The numbers above are but one example. Ampacity Tables for many conditions:
    IEEE Standard 835, IEEE Standard Power Cable Ampacity Tables
    IEEE Standard 848, Procedure for the Determination of the Ampacity Derating of Fire Protected Cables
    ICEA P-54-440, NEMA Pub. No. WC 51 - Ampacities of Cables in Open-Top Trays.
    The National Electrical Code [NEC] requires their own cable sizing for premises wiring. Refer to the NEC rules to determine building wiring, as this page relates to electronic equipment wiring. For reference, the ampacity of copper wire at 300C for common wire sizes
    14 AWG may carry a maximum of 20 Amps in free air, or 15 Amps as part of a 3 conductor cable.
    12 AWG may carry a maximum of 25 Amps in free air, or 20 Amps as part of a 3 conductor cable.
    10 AWG may carry a maximum of 40 Amps in free air, or 30 Amps as part of a 3 conductor cable.
    8 AWG may carry a maximum of 70 Amps in free air, or 50 Amps as part of a 3 conductor cable.
    The wire fusing [melting] current is based on the material the wire is made of, the diameter of the wire and the melting point of the the material. The wire fusing current of a wire is provided in tables as constant current or as [a larger] current for some given amount of time.
    This formula is used on a few different sites [un-verified]; I=Ad(3/2) @ d is in inches, A is a constant: A = 10,244 for Copper. A = 7,585 for Aluminum.
    I have listed a number of values for fusing current in the table above, for selected AWG sizes.
    3 Mins 58 Secs
    Wah, thanks ya om Tendean, kemarin saya sudah coba seperti itu, tapi hasilnya dalam bitmap masih gak bisa memenuhi batasan minimal di forum ini. Yah, saya yang gaptek nih. Btw thanks ya.
    Cabin Gain
    Save As Typenya JPEG saja .. ! jangan BMP (BitMap)
    Kalau punya Microsoft Office Picture Manager / Microsoft Photo Editor bisa di Rezise / dikecilkan dikit x % begitu.
  1. Replies: 52
    Last Post: 16th February 2014, 15:06
  2. Neon wire, glow wire, atau EL wire. Cari suppliernya
    By ACC in forum Diskusi Aksesoris
    Last Post: 17th July 2013, 01:05
