K20A (FD2) CIVIC TypeR TODA EXHAUST MANIFOLD
Results 1 to 7 of 7
  • Short URL:  http://modifika.si/106441
    Jakarta Barat
    1 Wk 1 Day 12 Hrs 10 Mins 3 Secs
    Barang udah lagi jalan...
    Qt cuma pesen 1 neh, jadi siapa cepat dia dapat..
    In order to get the best performance, engine power, efficiency, this exclusive exhaust manifold design takes into consideration not only the special characteristics of the K20A engine but also the results of an extensive bench testing program.
    -The standard catalyst can be installed, when TODA high power muffler system and TODA optional short front pipe are installed. (Instead the rear pipe of TODA header can NOT be used.)
    -A bench test (Equal length 4-2-1 + Taper) design
    -Racing high flow junctions design
    Each section of the manifold has optimized pipe lengths, diameters and angles as well as high flow junctions.
    -With the service adapter for A/F sensor
    -Made of light weight stainless steel for both durability and looks
    -Flange manufactured by high precision machining center
    Pict:
    0811117996- Cris
  2. 36Goal.com
    4 Hrs 8 Mins 20 Secs
    wow!!!!
    huuh kapan ya punya k series..
    nice item..
    bantu up bos!!!
    Jakarta Barat
    Ayo dung d beli neh boz..
    masuk ada 2..
    yg 1 dah laku..
    Jakarta Barat
    up!!!!!!!!
    jakarta utara
    3 Hrs 43 Mins 12 Secs
    wah manteb bnget ni
    brap bos ?
    iiiiiiiiiiiiiiiiiiiiiiiiiiiiindomieeeeeeeeeeSBY
    WKWKWKWKWWKWKWKWKWKWKWKWKWKW
    GUE BANTU LOE DENGAN PIC2 NYAAAAAAAAAAAAAA WKWKWKWKWKWKWKWKWKWKWKWKWKWKWKWKWKWKWKWKW
    NAPA KAGAK DATENGIN SEKALIAN,MUFFLER SETNYA PALING CUMAN :1050 USD
    SEMUGA MEMBANTU PIC INI DAN BIAR CEPET LAKU OK,,,,,,,,,,,,,,,,,,,,,,,,,,
    Palembang.
    6 Days 10 Hrs 51 Mins 52 Secs
    jah gokillll ni barang
    bantu up aja la boos
    SOHC VTEC
Mitsubishi Vkool
  1. Replies: 7
    Last Post: 4th October 2013, 18:43
  2. JUAL Spedometer TypeR + Engine start TypeR + Sarung S. knob typeR + emblem TypeR
    By lionel in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 30th April 2013, 06:52
  3. WTB : FD2R (K20A) exhaust manifold...thx guys..
    By fd2r in forum Jual Beli Mesin Lainnya
    Last Post: 4th September 2009, 16:29
