[PERFORMANCE PARTS] Honda Civic 7thGen VTi & VTi-S 2001-2005
Results 1 to 10 of 69
  • Short URL:  http://modifika.si/105333
    1 Wk 3 Days 3 Hrs 26 Mins 4 Secs
    HONDA CIVIC 7TH GEN 01-05 PERFORMANCE PARTS
    Thread ini khusus untuk performance parts:
    Type of Car:
    Honda New Civic 7th Gen
    Chassis Code:
    S5A/ES1
    Engine Code:
    D17A or F17
    Year:
    2001-2005
    Simota AeroForm Type II Intake Suction Kit
    Right on your Honda Civic ES Engine Bay, improve your Civic engine performance and catchy look..!
    Connecting Rods
    Brands Available:
    • K1 Technology H-Beam
    • Crower Force Induction I-Beam
    • Eagle H-Beam
    Piston
    Brands: Wiseco Piston Complete Kit with Ring
    Size Available:
    • STD 75,00mm Compression Ratio 8,8:1
    • Oversize 75,50mm Compression Ratio 8,8:1
    Exhaust Manifold
    • Stainless Turbo Manifold with External 38mm Wastegate & T3 Turbo Flange
    • Stainless Tubular Turbo Manifold with External 44mm Wastegate & T3 Turbo Flange
    • HKS Cast Iron Turbo Manifold T25 Flange with Internal Wastegate
    Camshaft NA & Turbo
    Brands: Crower Camshaft
    Type Available:
    • Crower Camshaft Stage 2 - NA Semi-Race
    Duration@0.10 253in 236ex Lobe 227in 217ex Lift 9,80in 9,37ex
    • Crower Camshaft Stage 2 - Turbo
    Duration@0.10 243in 232ex Lobe 237in 218ex Lift 10,23in 9,40ex
    • Crower Camshaft Stage 3 - NA Full Drag Race
    Duration@0.10 261in 243ex Lobe 250in 237ex Lift 10,80in 10,23ex
    Valve Spring and Retainer Kit
    Brands Available:
    • Crower Valve Spring and Titanium Retainer Kit
    • Supertech Stainless Valve Spring and Titanium Retainer Kit
    • Supertech Superclean Chrome Silicone Vanadium Steel Valve Spring
    • Comp Cams Single Valve Spring
    Block Guard
    Brands: Supertech Block Guard
    Multi Layer Steel Head Gasket
    Brands: Cometic Head Gasket
    Thickness Available: .027 inch/0,7mm
    Head Studs Kit
    Brands: ARP Bolts
    Type: ARP Head Studs Kit
    Performance Clutch & Flywheel
    Brands: ACT and EXEDY
    Type Available:
    • ACT Heavy Duty with 4 Puck Disc Pads
    • ACT Extreme with 4 Puck Disc Pads
    • ACT Flywheel Pro-Lite (9lbs) & Super-Lite (11lbs)
    High Performance Main & Rod Bearings
    Brands:
    • ACL Race Series Main & Duraglide Rods Bearings
    • Toga Performance Main & Rods Race Bearings
    High Performance Brake System
    Type: Crossdrilled Rotor Front & Rear Disc Rotor
    • Runstop Curve Slot Rotor OEM Size Front Rotor
    • Runstop Curve Slot Rotor OEM Size Rear Rotor
    • Runstop Curve Slot Rotor Over Size 320mm Front Rotor
    Type: High Performance Brake Pads
    • NA-P Front Brake Pads, Working Temperature up to 800 deg C
    • NB-P Front Brake Pads, Working Temperature up to 400 deg C
    • NB-P Rear Brake Pads, Working Temperature up to 400 deg C
    • Delphi Lockhead Front Brake Pads
    Coilover Kit
    KSPORT Made in USA Coilover Kit. Kontrol Pro/Street Type Fully Adjustable Coilover Kit featured Hi-Low & 36klik Soft-Hard with Front Pillowball Uppermount.
    Lower Control Arm
    KSPORT Made in USA Lower Control Arm. Improve handling & reducing body roll.
    Chassis Tuning
    Brands: Ultra Racing
    Bars Available:
    • Front Bar 2 Points
    • Front Lower Bar 4 Points
    • Rear Lower Bar 4 Points
    • Rear Bar 2 Points
    • Side Lower Bar (Right & Left)
    • Fender Bar 3 Points
    • Room Bar
    • Rear Sway/Anti Roll Bar 16mm & 19mm
    • Front Sway/Anti Roll Bar 19mm
    ...under construction!
    KNOWLEDGE IS HORSEPOWER
    .:: de Auto Motorsport ::.
    Jalan Raya Pemuda No.14
    Rawamangun - Jakarta Timur
    CP : Coki Siboro
    SMS/Call : 0815.1330.1978
    updated..!
    CP : Coki Siboro
    SYD-AUS
    3 Wks 5 Days 6 Hrs 59 Mins 28 Secs
    turbo kitnya brapaan cok.??
    terima beres tinggal ngegas doank deh pokoknya gw,, sapa tau ada rejeki gt,, hhee,,,
    Quote Originally Posted by specialfx View Post
    bikin malu aja nanya disini..
    langsung ke hp gw dong!!! :p
    CP : Coki Siboro
    SYD-AUS
    Quote Originally Posted by coki.de auto View Post
    jiahahahaa,,,
    ya sapa tau yg laen ada yg pengen nanya jg,, gw wakilin deh,, hhee,,,
    5 Days 17 Hrs 39 Mins 7 Secs
    Cok mau nanya juga nih...
    block guart berapayah sama head gasket 0.60inch....
    Quote Originally Posted by *night_walker* View Post
    head gasket cometic nya yang available disana buat d17 tinggal yang 0,27 bos..
    block guard supertech lumayan mahal dibanding block guard yang gak bermerk, kalo yang gak bermerk aja udah 1jtan, ini harga nya sedikit diatas itu bos.
    CP : Coki Siboro
    Solo spirit of Java
    2 Hrs 53 Mins 45 Secs
    strurbar ultra racing nya harga berapaan bos?
    Quote Originally Posted by antox_upstairs View Post
    udah di pm bos. thx
    CP : Coki Siboro
    B*TOWN
    1 Day 8 Hrs 8 Mins 23 Secs
    wow gile lengkap abis
    bos header dc sport 421 berapa?
    klo camshaft sama piston itu nambah hp banyak bos?
    gua kaga ngarti mesin sih bos hehe
GT Radial Datsun 300x250
  1. Replies: 113
    Last Post: 9th June 2015, 16:45
  2. Replies: 5
    Last Post: 23rd March 2014, 21:55
  3. [WTB] Honda Civic VTi/ VTi-S 2001-2005
    By guesscoklat in forum Honda
    Last Post: 8th August 2011, 04:27
  4. WTB : Coilover buat HONDA CIVIC 2001-2005 / HONDA STREAM
    By halimsatria in forum Jual Beli Interior & Aksesoris Lainnya
    Last Post: 22nd March 2011, 07:53
