Tuning steps
Results 1 to 6 of 6
Thread: Tuning steps
  • Short URL:  http://modifika.si/105173
    Tuning steps
    Sorry, i don't know where to post this thread
    About tuning steps, which is 1st, 2nd, 3rd...next and next and next and last ?
    Considering that u have all the equipment, the HU, the amp, the driver, the cables and so on...so what's next ?
    set the amp gain first ? or angling the driver first ? what about EQ and T/A, is it the 3rd step ? 4th step ?
    Jakarta, Bandung
    4 Days 8 Hrs 16 Mins 55 Secs
    Dunno the correct method, but here's what i do:
    1. Locate driver placement that won't interfere with driving capabilities and safety.
    2. Adjust gain in amplifier just to make sure the sounds comes up
    3. Turn off all feature in HU, and start angling driver til i get optmum sound.
    4. Adjust gain in amplifier correctly. I usually do this using zero bit/no signal at max HU volume.
    5. Set TA if required
    6. Crossover slopes, EQ
    7. Repeat 3 hours a day in 3 years
    The idea is to do the "hard" setting first - things that related to physical condition (such as TA)
    Then go with the soft setting...
    The Altair - HiFi Speaker
    http://www.facebook.com/polishing.garage
    2 Days 7 Hrs 59 Mins 3 Secs
    steps are:
    -angling (midrange and/or tweeter placement)
    -crossover (cutting frequency for each driver)
    -checking the phase (each driver)
    -time allignment/correction (including amp gain setting)
    -EQ
    IMHO
    detail is on this page:
    http://www.modifikasi.com/showthread.php?t=91588
    i also learn lot from this forum
    ohh..already have the topic. THX guys
    Quote Originally Posted by flamefox850 View Post
    for me
    first set the placement for the speakers...
    place in good angling...
    then set the cables into place, RCA, speakers cable, power cable and so on
    then put the amps
    then turn on, set the cutting freq, set the gain of amp, then check balance, check polarity
    then set the EQ, if you use time alligment, set time alligment first then EQ
  1. Replies: 173
    Last Post: 14th December 2016, 21:02
