WTA ARC Audio Foose FD2100
Results 1 to 10 of 18
  • Short URL:  http://modifika.si/104255
    jakarta selatan
    3 Days 2 Hrs 6 Mins 55 Secs
    harga ARC Audio Foose FD2100 brapaan ya???ni gantinya 2100xxk ya??ok ga si ni power??
    bb pin : 2855D02F
    yg ganti 2100 tuh FD2200 (wattnya sama2 2x100)
    bb pin : 2855D02F
    # 12dB stereo crossover with x10 range switch, 55Hz to 5.5KHz
    # High/low/full range selector switch
    # Mono/stereo/bridged select feature
    # 18dB bass control at 45Hz
    # Protection against: reverse voltage, over voltage, speaker short, and thermal overload
    # Heavy duty construction
    Specifications:
    # Output power: 100x2 @4 ohms, 185x2 @2 ohms, & 360x1 @4 ohms bridged
    # Transient distortion: < 0.1% @ 4ohms
    # Frequency response: 20Hz - 20Khz
    # S/N ratio (A wtg): >98dB
    # Bass boost: + 18dB@45Hz
    # Input sensitivity: 250mV - 2.5V
    # Crossover: 55Hz - 5.5KHz variable 12 dB
    # Fuse: 45A x1
    # Dimensions: 10 3/8" x 16 3/4" X 2 3/8"
    FD 2200 - ARC Audio 2 Channel 370 Watt Amplifier FD2200 FD-2200
    http://www.woofersetc.com/index.cfm?...roduct_ID=6856
    bb pin : 2855D02F
    Output power : 100x2@4 ohms, 180x2@2 ohms, and 360x1 @ 4 ohms bridged
    Transient distortion : < 0.1% @4ohms
    Frequency response: 20Hz-20Khz
    S/N ratio(A wtg) : > 98dB
    Bass boost : + 18dB @45Hz
    Input sensitivity : 250mV - 2.5V
    Crossover : 55Hz-5.5KHz variable 12dB
    Fuse : 45A x1
    ARC 2100 XXK
    http://www.autosound-design.com/product.detail_111940_th_1012611
    bb pin : 2855D02F
    - 12dB stereo crossover with x10 range switch, 55Hz to 5.5KHz
    - High/low/full range selector switch
    - Mono/stereo/bridged select feature
    - 18dB bass control at 45Hz
    - Protection against: reverse voltage, over voltage, speaker short, and thermal overload
    - Heavy duty construction
    - Output power : 50x2@4ohms, 95x2@2ohms, and 190x1 4ohms bridged
    - Transient distortion : < 0.1% @4ohms
    - Frequency response: 20Hz-20Khz
    - S/N ratio(A wtg) : > 100dB
    - Bass boost : + 18dB @45Hz
    - Input sensitivity : 250mV - 2.5V
    - Crossover : 55Hz-5.5KHz variable 12dB
    - Fuse : 25A x1
    - Dimensions : 10 3/8 " x 13" x 2 3/8"
    ARC FD2100
    http://www.autosound-design.com/product.detail_111940_th_998032
    14 Hrs 14 Mins 25 Secs
    Quote Originally Posted by jlu_mike View Post
    nomernya di seri fd emang bikin bingung
    Cliport Car Audio Bandung
    Gw pake FD2200 buat angkat sub ScanSpeak 23W Ok bagt tuh bro.
    jakarta selatan
    kalo bwt speaker gmn bro??
    1 Wk 5 Days 6 Hrs 13 Mins 42 Secs
    bagus kok.. two thumbs up
    6 Hrs 49 Mins 52 Secs
    gw pake fd2200 utk drive sub mtx.. manstap ...!
MBtech Venom 300x250
  1. jual paket audio, ada arc foose 2X100wrms
    By kingkong in forum Power Amplifier
    Last Post: 3rd June 2011, 11:28
  2. FS ARC FD2200 FOOSE
    Last Post: 28th January 2011, 01:29
  3. Replies: 19
    Last Post: 11th February 2010, 12:31
  4. Chip Foose Replica
    By mbezzz in forum Ragam Ukuran
    Last Post: 19th January 2010, 17:25
  5. [SOLD OUT] ARC FD4100 by Foose Design.
    By seraphim in forum Power Amplifier
    Last Post: 12th November 2009, 09:50
