ad yg tau or perna pake mono ma m1900xe
Results 1 to 9 of 9
  • Short URL:  http://modifika.si/10220
    http://www.butikjersey.com/
    2 Days 9 Hrs 44 Mins 1 Sec
    karakternya gmana se?thx
    Technical Specification
    * RMS Power Range : 500 Watts
    * Number Of Channels: 1
    * Maximum Power: 1000 Watts
    * Built In Crossovers: Yes
    * Channel Separation: Yes
    Features
    * Mono Block High Performance Amplifier
    * Subsonic filter: 20-50Hz
    * 1 x 500W RMS @ 4-Ohm Mono
    * 1 x 1000W MAX @ 2-Ohm Mono
    * Dimensions (HxWxL):2" x 10" x 13"
    * Variable High/Low Pass Crossover 50-250Hz
    * Variable Bass Boost 0-18db @ 45hz
    * 3-Way Protection Circuitry
    * Full MOSFET circuitry
    * 2-Ohm stereo stable
    * High/Low level inputs
    * Low level outputs
    [/img][/url]
    up
    10 Hrs 21 Mins 37 Secs
    ada yg bisa bantu, ayo ma lover..
    B 89 AEK
    Makassar, Jakarta
    4 Days 17 Hrs 36 Mins 43 Secs
    ngapain ribet.
    beli ajah HDT 1200
    kalo di luar se rantingnya pada tinngi
    3 Mths 11 Hrs 11 Mins 41 Secs
    di sini ma yang bagus tuh HK 4000d sama HK 10000d
    keren nih.....
    Harapan Yang Indah
    1 Wk 6 Days 18 Hrs 15 Mins 4 Secs
    Keknya beda kelas kalo ma HK 1000D... apalagi yg 4000D horor...
    Quote Originally Posted by sigit
    yang horor yang 10000d boss...yang baru....
    7500watt....
    kok maen horor2an, mank film misteri apa..
    B 89 AEK
MBtech Wuling
  1. Power concept HA-704, ada yg perna tau? atau perna pake?
    By sentanoe in forum Diskusi Power Amplifier
    Last Post: 7th April 2010, 03:09
  2. Yg udah perna bayar shop di inet pake CC ?
    By hanif in forum Automotive
    Last Post: 9th April 2009, 00:06
  3. WTS:replika(TW)5zigen.masi baru blum perna pake
    By bethefastest89v in forum Jual Beli Mesin Lainnya
    Last Post: 18th December 2008, 08:54
  4. ada yang perna pake tociko gak???
    By stifler168 in forum Diskusi Kaki-Kaki
    Last Post: 18th September 2008, 03:37
  5. Replies: 17
    Last Post: 24th May 2008, 23:21
