OPTimum New Products!!! NOW AVAILABLE !!!!
Results 1 to 10 of 36
  • Short URL:  http://modifika.si/101885
    http://www.detailermart.com
    3 Days 9 Hrs 25 Mins 56 Secs
    OPTimum Finish:
    High intensity shine and zero marring on all paints!
    Optimum Finish is a finishing polish like no other. Formulated for OEM use, Optimum Finish Polish leaves all paints with the ultimate gloss, reflection, and shine – even soft paints and black paint. Optimum Finish Polish is more than a finishing polish – it’s paint perfection in a bottle.
    With so many types of clear coat on the market today, Optimum wanted a final finish polish that would work on the softest, most sensitive clears, but also be able to do some corrective work and have some range on a harder type of clear coat. You may ask why you need a final finish polish when the Optimum II polish can take care of almost ALL vehicles and still finish perfectly. Where these 2 products differ is that Optimum Final Finish will take care of any minute hazing, marring, or minor swirls that can just drive you crazy on certain blacks and softer, sensitive clear coats.
    Optimum Final Finish will make the paint "POP" and the slickness is second to none. This is NOT a glaze or filler. The sub-micron abrasives will correct, but not "over-correct", leaving the paint absolutely perfect. You can buff extensively and the polish will keep cutting if you need a little more correction. When you are ready for that perfect final finish, the polish will back down and give you the ultimate gloss, reflection and shine. The polishing agents are encapsulated in proprietary polymers that protect the paint from dry buffing and prevent dusting. Simply put, Optimum Finish gives you the perfect finish every time.
    You may not need this polish on every single vehicle as the final step, but once you see the final result, you will be addicted to Optimum Final Finish. Your customers will be amazed at the final result.
    As with all Optimum polishes, this incredibly smooth, long working, zero dust formula is body shop safe, VOC compliant, and will work with any buffer, any buffing pad, and on any paint surface. It's virtually impossible to make a mistake with this product. The Optimum Final Finish will turn you into an all-star detailer, and every vehicle into a show car! Optimum Final Finish buffs wet and finishes off even wetter. Optimum Final Finish lays the foundation for a perfect, glossy finish once wax is applied.
    To apply Optimum Final Finish, use light to medium buffing pressure with a finishing foam pad. For high speed buffers, 1000-1400 RPM will provide excellent swirl removal and a flawless finish. The polish is aggressive enough to remove 2500 sand scratches, but fine enough to produce perfect results even with a high speed buffer. For orbital buffers, use a medium to light cutting pad with moderate speed and pressure for desired results. Always use enough polish to create a barrier between the buffing pad and the paint surface. Wipe off residue by misting either water or Optimum Car Wax and gently wiping off with a Cobra Microfiber Towel.
    Optimum Final Finish polish will create that special, flawless appearance. Don't forget, this product will correct those minor imperfections, not hide or fill them. The look that you obtain from this polish is a true, corrected, super wet look. Once you try it, you’ll want to finish every vehicle Optimum Final Finish.
    Available 32 oz size.
    another excellent product from
    OPTimum Polish II
    Updated for 2009! Optimum Polish II now cuts faster to give your vehicle a smoother, more brilliant finish in less time.
    Optimum Polish II has been revised for better performance in OEM applications, which means it works fast! Optimum Polish was already regarded by many as the "perfect polish". Now its even better.
    If we could create the perfect polish, it would be really easy to use and fix just about any paint problem. Some hobbyists live for long afternoons spent compounding and polishing, but some of us want to get the desired results quickly and spend the rest of the afternoon cruising in our shiny, clean cars. Optimum read our minds when they created Optimum Polish. That’s it. That’s the whole name, because they only make one polish. They packed all the paint-improving, swirl-removing power they could into one versatile formula that really works!
    Optimum Polish II is a thick cream loaded with proprietary polymers and microfine polishing agents that quickly remove – not hide – scratches and swirls to restore your paint to pristine condition. It can be used as a light compound, a swirl remover, and a finishing polish! You might be wondering how one product can serve so many purposes. Well, an integral part of achieving specific polishing results is what pad you use. Optimum Polish II is designed to be used with a machine polisher and the desired pad to deliver the results you want, whatever they may be. If you want to remove light scratches, use a light cutting pad with this polish. If you are interested in refining the paint before you apply wax, use a polishing pad. Your pad selection dictates how aggressively this polish works!
    According to Optimum Polymer technologies, Optimum Polish II will remove 1500 sand scratches and lighter at 1000-1400 RPM. Faster buffer speed is not needed with this product. When using a light cut foam pad at 1000-1400 RPM the polish will remove 2000 and lighter sand scratches on most paint surfaces. A final finishing foam pad will remove swirl marks at 1000-1400 RPM. Always apply enough polish to maintain a layer of lubrication between the paint surface and the pad. Wipe off residue by misting the surface with Optimum Car Wax.
    Optimum Polish II is a very gentle formula. It will not contribute to new swirls. Use it by hand for pre-wax cleaning or final polishing.
    Optimum Polish II meets all VOC regulations and is body shop safe.
    Remove scratches and swirls, and refine your paint with one product. Optimum Polish II’s paint safe proprietary formula allows you to control the aggressiveness of the polish so you always get the desired result.
    available in 32oz size
    53 Mins 25 Secs
    Bos, ada versi bahasa indo nya ga?
    bedanya apa dgn versi yg lama?
    OP II mnawarkan "cut" yang leibh dibanding OP sebelumnya...tetapi tetap less dusting (no dusting bisa dibilang), long working time and LSP Ready..
    53 Mins 25 Secs
    Quote Originally Posted by maestrotyper View Post
    harganya sama ga dgn yang versi pertama?
    untuk harga nanti di announce lagi..oh ya ini pake original bottle 32oz
    2 Days 3 Hrs 1 Min
    gak jual uk 160z bos kek yg udah2....?
    untuk saat ini blom boss andi, mgk bisa sharing ama temen yang lain yang mau beli 16oz nya..
    mgk jg nanti saya sediain yang 16oz jg
    2 Days 3 Hrs 1 Min
    gw mau dong yg OP II tp yg 16oz aja,klu yg 32oz bingung mau bwt apaan...btw brp hrgna?
    bisa kan om david yg baik hati..kabarin yah klu dah dtg..
    nanti diannounce kalo sudah datang barangnya berikut harganya
Mega Glodok Kemayoran MBtech
  1. WTS : Products Ex Display and Used Products
    By CARTENS in forum Power Amplifier
    Last Post: 21st February 2011, 14:48
