wta visaton al 170 a & visaton ke 25 sc
  • Short URL:  http://modifika.si/101256
    Talking wta visaton al 170 a & visaton ke 25 sc
    halo bos2 modcom semua,ada yang pernah pakai atau tau review dari temen2 ga soal visaton ke 25 sc tweeter dan al 170 a midbass...
    mohon penerangannya ya bos2 modcom semua...
    thanks a lot ya bos2 semua.......
    KE 25 SC 8 OHM
    Art. No. 1191
    Magnetically shielded 25 mm (1") high end dome tweeter made of ceramic for crystal clear, perfectly reproduced sound even at high volume settings and with no distortion. The pole piece perforation coupled with the flow-optimised rounded shape, the damping in the cavity and the ventilated voice coil carrier guarantee a very low resonance frequency. A completely new feature is the integrated impedance linearising function using an LRC element. This means that the dome can be easily integrated in a network of crossovers. The protective grille is fitted on the inside with an acoustic low-pass filter in the shape of a transparent ring, which does not begin to operate until 25 kHz are achieved, when it damps any material-borne resonance. The grille has the added advantage of improving omnidirectional sound distribution at higher frequencies.
    AL 170 8 OHM
    Art. No. 1302
    17 cm (6.5") High-End low midrange driver with stiff, anodized aluminium cone, solid aluminium die-cast basket and elastic rubber surround. Extremely low electrical and mechanical losses due to vented pole plate, vented damper and capton voice-coil. Extremely long cone displacement due to long stroke voice coil. Suitable as low-midrange driver for 2-, 3- and 4-way high-end applications up to 2500 Hz.
    halo bos2 modcom semua,ada yang pernah pake nich driver ga yach?
    kalo ada yang tau mohon penerangannya soal karakternya yach bos..
    up dulu dech.....................,anyone?
  1. Replies: 21
    Last Post: 6th February 2012, 13:52
  2. WTS: Legatia L1, L3 dan Midbass Visaton dll
    By iswara in forum Diskusi Speaker
    Last Post: 29th October 2010, 09:32
  3. visaton
    By FeeL in forum Diskusi Crossover
    Last Post: 13th January 2008, 19:53
  4. VISATON Midrange
    By eci in forum Diskusi Speaker
    Last Post: 8th August 2006, 13:27
  5. Visaton
    By fluxengine in forum Diskusi Speaker
    Last Post: 7th May 2006, 21:07
