Most powerful engine ever made...
Results 1 to 10 of 33
  • Short URL:  http://modifika.si/10084
    In your dreams...
    4 Hrs 28 Mins 49 Secs
    The Wartsila-Sulzer RTA96-C turbocharged two-stroke diesel engine is the most powerful and most efficient prime-mover in the world today. The Aioi Works of Japan's Diesel United, Ltd built the first engines and is where some of these pictures were taken.
    It is available in 6 through 14 cylinder versions, all are inline engines. These engines were designed primarily for very large container ships. Ship owners like a single engine/single propeller design and the new generation of larger container ships needed a bigger engine to propel them.
    The cylinder bore is just under 38" and the stroke is just over 98". Each cylinder displaces 111,143 cubic inches (1820 liters) and produces 7780 horsepower. Total displacement comes out to 1,556,002 cubic inches (25,480 liters) for the fourteen cylinder version.
    Some facts on the 14 cylinder version:
    Total engine weight: 2300 tons (The crankshaft alone weighs 300 tons.)
    Length: 89 feet
    Height: 44 feet
    Maximum power: 108,920 hp at 102 rpm
    Maximum torque: 5,608,312 lb/ft at 102rpm
    Fuel consumption at maximum power is 0.278 lbs per hp per hour (Brake Specific Fuel Consumption). Fuel consumption at maximum economy is 0.260 lbs/hp/hour. At maximum economy the engine exceeds 50% thermal efficiency. That is, more than 50% of the energy in the fuel in converted to motion.
    For comparison, most automotive and small aircraft engines have BSFC figures in the 0.40-0.60 lbs/hp/hr range and 25-30% thermal efficiency range.
    Even at its most efficient power setting, the big 14 consumes 1,660 gallons of heavy fuel oil per hour.
    bearings
    krukas
    piston+conrod
    blok silinder
    Honoured Member
    Ja-STUCK-arta
    51 Mins 23 Secs
    olinya brapa ribu liter tuh??????
    krik krik krik krik ...
    In your dreams...
    Quote Originally Posted by zestarm
    yg pasti kliatannya gak diisi pake botolan...
    adanya pake convoyan truk oli...
    straped tightly in a cefiro
    15 Mins 46 Secs
    hehehe
    pistonnya muat ga ya di mobil gw..
    pertanyaan bodoh.. huehuehuehe
    In your dreams...
    Quote Originally Posted by mimo
    hehehe
    beratan 1 pistonnya dari cefi lo mo... hahahaa...
    kenapa yah container pake mesin ginian?? kenapa gak pake mesin nuklir kaya kapal selam russia??
    didalem ruang mesin ada tangganya...mesin gw ko gak ada tangganya ya??
    pondok aren,,,
    eh buset,,gede bgt mesinnya,,,,,
    kl mo mesin segede ini pake turbo,,turbonya segede keong mas TMII kl yah,,,hahahhh,,,
    stage of solitairy..
    2 Days 14 Hrs 59 Mins 1 Sec
    Mesin kapal sih wajar lah segitu.
    Kapalnya aja kan segede lapangan bola.
    Mesin2 buat ngedorong rig juga rata2 segede gitu.
    Bahannya full billet semua pula.
    JKT48 BSD48
    Re: Most powerful engine ever made...
    bearings
    krukas
    piston+conrod
    blok silinder
    [/quote]
    kecil ya mesinnya.....
    My Old Project
    http://honda-tech.com/zerothread?id=1654882
    http://www.modifikasi.com/forum/viewtopic.php?t=22865
    021-99992722
    guyss maaf banget kalo telp ga keangkat, just leave ur msg by sms
    3 Mths 11 Hrs 11 Mins 41 Secs
    ngebautnya gmn tuh???
NGK Busi GT Radial
  1. Replies: 78
    Last Post: 16th April 2013, 16:38
  2. [AutoNews] Mazda MX-5 GT Small But Powerful
    By bosmobil in forum Automotive
    Last Post: 25th March 2011, 15:18
  3. BMW M52/M50 engine..how to be a powerful engine?
    By Bon'z in forum Diskusi Mesin
    Last Post: 2nd March 2011, 14:53
